Home » Language IDEs » C / C++ IDE (CDT) » Debugging issues...
| Debugging issues... [message #154408] |
Thu, 15 September 2005 14:47  |
Originally posted by: jerryrodgers.comcast.net
I am having problems being able to debug my C++ executable under Eclipse. I
was able to run/break/inspect variables etc directly under GDB and DDD. I
am a newbie to C/C++ to begin with but have been using Eclipse fror Java for
many years.
I am able to make and run the C++ program from within Eclipse (as long as I
do not have any break points set) wihtout any problems - The problem is when
I select Run - Debug and I set a break point however as soon as it stops it
ends up termintaing - all I get is this in the console. I pretty much
accepted the defaults for debugging - I selected GDB as the debugger and
have Stop at main() on startup selected.
Stopped due to shared library event
mi_cmd_stack_list_frames: No stack.
Also if I am quick about when I select run - debug - and then try to step I
get this error.
Eclipse Target request failed: {R,T}xThread Terminated
Any ideas where I am going wrong?
thanks,
Jerry Rodgers
| Re: Debugging issues... [message #154771 is a reply to message #154686] |
Wed, 21 September 2005 10:42   |
Originally posted by: mikhailk.qnx.com
Jerry,
I didn't use RPM to install gdb, so unfortunately I can't answer to your
question. But I believe, if you just download the zipped file and unzip it,
it would work fine.
Mikhail
"Jerry Rodgers" <jerryrodgers@comcast.net> wrote in message
news:dgnj47$tfp$1@news.eclipse.org...
> Thanks Mikhail,
> Sorry to be so slow about all this - I am new to this enviornment too. I
> grabbed an RPM for redhat from centos and when I ran the --test option I
> got the following errors. Does this mean that I need to uninstall what is
> there now? Or issue some other switch on the rpm command or does it mean I
> can not install this rpm on this machine because of this conflict?
> Thnks,
> Jerry
> [jrodgers@jdevunix jrodgers]$ rpm -iv --test gdb-6.3.0.0-0.30.1.i386.rpm
> warning: gdb-6.3.0.0-0.30.1.i386.rpm: V3 DSA signature: NOKEY, key ID
> 025e513b
> Preparing packages for installation...
> file /usr/bin/gdb from install of gdb-6.3.0.0-0.30.1 conflicts with
> file from package gdb-5.
> 3.90-0.20030710.40
> file /usr/bin/gdbserver from install of gdb-6.3.0.0-0.30.1
> conflicts with file from package
> gdb-5.3.90-0.20030710.40
> file /usr/share/info/annotate.info.gz from install of
> gdb-6.3.0.0-0.30.1 conflicts with file
> from package gdb-5.3.90-0.20030710.40
> file /usr/share/info/gdb.info-1.gz from install of
> gdb-6.3.0.0-0.30.1 conflicts with file fr
> file /usr/share/info/gdb.info.gz from install of gdb-6.3.0.0-0.30.1
> file /usr/share/info/gdbint.info-1.gz from install of
> file /usr/share/info/gdbint.info.gz from install of
> file /usr/share/info/stabs.info-1.gz from install of
> file /usr/share/info/stabs.info.gz from install of
> "Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
> news:dgf1p2$7o0$1@news.eclipse.org...
>>I don't think you will have problems using gdb 6.3 with your projects. You
>>can simply download the binary from the RedHat site.
>> news:dgcv4n$jd9$1@news.eclipse.org...
>>> Hi Mikhail,
>>> What is the relationship between gdb and gcc? Can I upgrade to the
>>> current version of gdb while still using the older version of gcc that
>>> my code currently relies on? How do I upgrade gcc? Is there an rpm from
>>> redhat or do I need to down load the current 6.3 version and use "make"
>>> to build it?
>>> thanks for the help,
>>> Jerry
>>> news:dgci41$2o7$1@news.eclipse.org...
>>>> It looks like gdb is crashing. Try a newer version of gdb.
>>>> The messages you see in the gdb console reflect the internal activity
>>>> and are not "real" errors.
>>>> news:dgcfv4$vb9$1@news.eclipse.org...
>>>>>I wanted to include that I am using
>>>>> GNU gdb Red Hat Linux (5.3.90-0.20030710.40rh)
>>>>> Eclipse 3.1.0 - Build 120050627-1435
>>>>> CDT 3.0.0
>>>>> GCC - gcc version 2.96 20000731 (Red Hat Linux 7.3 2.96-113)
>>>>> -Jerrry
>>>>> news:dgcfl8$utd$1@news.eclipse.org...
>>>>>> Hi,
>>>>>> Eclipse. I was able to run/break/inspect variables etc directly under
>>>>>> GDB and DDD. I am a newbie to C/C++ to begin with but have been using
>>>>>> Eclipse fror Java for many years.
>>>>>> long as I do not have any break points set) wihtout any problems -
>>>>>> The problem is when I select Run - Debug and I set a break point
>>>>>> however as soon as it stops it ends up termintaing - all I get is
>>>>>> this in the console. I pretty much accepted the defaults for
>>>>>> debugging - I selected GDB as the debugger and have Stop at main() on
>>>>>> startup selected.
>>>>>> step I get this error.
>>>>>> thanks,
>>>>>> Jerry Rodgers
| Re: Debugging issues... [message #154803 is a reply to message #154771] |
Wed, 21 September 2005 13:16   |
I am at a loss - I upgraded the GDB and still no luck when I hit a break
point the program is terminated with the following error. with no break
points set the program runs fine via Eclipse - GDB and DDD all still work
for debugging. Do you have any other ideas? Thanks for all your help.
>>> Eclipse console error
>>> Upgraded GDB
GNU gdb Red Hat Linux (6.3.0.0-0.30.1rh)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "i386-redhat-linux-gnu".
(gdb)
-Jerry
news:dgrrhs$obi$1@news.eclipse.org...
> Jerry,
> it, it would work fine.
> Mikhail
>> Thanks Mikhail,
>> I can not install this rpm on this machine because of this conflict?
>> Thnks,
>> Jerry
>> 025e513b
>> with file from package gdb-5.
>> 3.90-0.20030710.40
>> gdb-6.3.0.0-0.30.1 conflicts with file from
>>>You can simply download the binary from the RedHat site.
>>>> Hi Mikhail,
>>>> to build it?
>>>> Jerry
>>>>>> CDT 3.0.0
>>>>>> -Jerrry
>>>>>>> Hi,
>>>>>>> under GDB and DDD. I am a newbie to C/C++ to begin with but have
>>>>>>> been using Eclipse fror Java for many years.
>>>>>>> thanks,
>>>>>>> Jerry Rodgers
| Re: Debugging issues... [message #154811 is a reply to message #154803] |
Wed, 21 September 2005 13:20   |
AHHHH - A clue.... I just happened to have the breakpoints tab selected and
was able to break and step through code - HOWEVER when I then selected the
variables tab (the whole of debugging for me from within Eclipse) I crashed
with the errors below...
Does this info help?
-Jerry
news:dgs4ic$6th$1@news.eclipse.org...
>>>> Upgraded GDB
> are
> conditions.
> details.
> (gdb)
> -Jerry
>> Jerry,
>> Mikhail
>>> Thanks Mikhail,
>>> is there now? Or issue some other switch on the rpm command or does it
>>> mean I can not install this rpm on this machine because of this
>>> conflict?
>>> Thnks,
>>> Jerry
>>> 025e513b
>>> 3.90-0.20030710.40
>>>>> Hi Mikhail,
>>>>> from redhat or do I need to down load the current 6.3 version and use
>>>>> "make" to build it?
>>>>> Jerry
>>>>>>> CDT 3.0.0
>>>>>>> -Jerrry
>>>>>>>> Hi,
>>>>>>>> to step I get this error.
>>>>>>>> thanks,
>>>>>>>> Jerry Rodgers
| Re: Debugging issues... [message #154819 is a reply to message #154811] |
Wed, 21 September 2005 13:44   |
The messages below are not errors and have no relation to the problem. gdb
crashes when the CDT debugger tries to retrieve a variable-related
information.
If you want to dig deeper and find out which gdb command is causing the
problem, get the gdb trace. On how to do it see the CDT Debugger FAQ #5.
news:dgs4pc$781$1@news.eclipse.org...
> and was able to break and step through code - HOWEVER when I then selected
> the variables tab (the whole of debugging for me from within Eclipse) I
> crashed with the errors below...
> -Jerry
>> Hi,
>>>>> Upgraded GDB
>> are
>> conditions.
>> details.
>> (gdb)
>> -Jerry
>>> Jerry,
>>> Mikhail
>>>> Thanks Mikhail,
>>>> I grabbed an RPM for redhat from centos and when I ran the --test
>>>> option I got the following errors. Does this mean that I need to
>>>> uninstall what is there now? Or issue some other switch on the rpm
>>>> command or does it mean I can not install this rpm on this machine
>>>> Thnks,
>>>> Jerry
>>>> 025e513b
>>>> 3.90-0.20030710.40
>>>>>> Hi Mikhail,
>>>>>> that my code currently relies on? How do I upgrade gcc? Is there an
>>>>>> rpm from redhat or do I need to down load the current 6.3 version and
>>>>>> use "make" to build it?
>>>>>> Jerry
>>>>>>> activity and are not "real" errors.
>>>>>>>> CDT 3.0.0
>>>>>>>> -Jerrry
>>>>>>>>> Hi,
>>>>>>>>> thanks,
>>>>>>>>> Jerry Rodgers
| Re: Debugging issues... [message #154852 is a reply to message #154819] |
Wed, 21 September 2005 14:42   |
Below is the LENGTHY output from the debug session. I set a break point on
the very first line within my main method - recorded that output and if you
search below for JMR you will see where the debug info stops before I
then clicked on the variables tab and caused the debugger to crash. I kinda
see what is happening but not sure what steps to take - it looks like when
the variables tab is clicked it does some sort of discovery process with gdb
and determines the type of all the variables and what their signatures are
etc and it looks like it stops on a variable this is of type CGI - I don't
really see any error though just a gdb exit... ?
Again thanks for sticking with me on this - I greatly appreciate the help.
[root@jdevunix eclipse]# ./starteclipse.sh
Start VM: /usr/local/java/jre/bin/java
-Xms40m
-Xmx256m
-jar /usr/local/eclipse/./startup.jar
-os linux
-ws gtk
-arch x86
-launcher /usr/local/eclipse/./eclipse
-name Eclipse
-showsplash 600
-exitdata 78009
-debug file:/usr/local/eclipse/.options
-vm /usr/local/java/jre/bin/java
-vmargs
-Xms40m
-Xmx256m
Install location:
Configuration file:
file:/usr/local/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/usr/local/eclipse/plugins/org.eclipse.osgi_3.1.0.jar
Framework classpath:
Splash location:
/usr/local/eclipse/plugins/org.eclipse.platform_3.1.0/splash .bmp
runCommand:
</usr/local/eclipse/./eclipse><-name><Eclipse><-showsplash ><600>< /usr/local/eclipse/plugins/org.eclipse.platform_3.1.0/splash .bmp >
Debug options:
file:/usr/local/eclipse/.options loaded
Time to load bundles: 15
Starting application: 729
[1,127,327,219,055]
gdb --cd=/home/jrodgers/makesystem/bbs_main/cpp_cgi_apps --command=.gdbinit
-q -\
nw -tty /dev/pts/1 -i mi
/home/jrodgers/makesystem/bbs_main/cpp_cgi_apps/cgi_source/b otrevmatch
[1,127,327,219,105] 1-gdb-set confirm off
[1,127,327,219,106] 1^done
[1,127,327,219,120] (gdb)
[1,127,327,219,130] 2-gdb-set width 0
[1,127,327,219,141] 2^done
[1,127,327,219,141] (gdb)
[1,127,327,219,142] 3-gdb-set height 0
[1,127,327,219,142] 3^done
[1,127,327,219,142] (gdb)
[1,127,327,219,155] 4-interpreter-exec console echo
[1,127,327,219,157] 4^done
[1,127,327,219,169] 5-gdb-show prompt
[1,127,327,219,168] (gdb)
[1,127,327,219,181] 5^done,value="(gdb) "
[1,127,327,219,184] 6-stack-list-frames
[1,127,327,219,191] (gdb)
[1,127,327,219,204] &"mi_cmd_stack_list_frames: No stack.\n"
[1,127,327,219,205] 6^error,msg="mi_cmd_stack_list_frames: No stack."
[1,127,327,219,347] 7-gdb-set auto-solib-add on
[1,127,327,219,352] (gdb)
[1,127,327,219,376] 7^done
[1,127,327,219,376] 8-gdb-set stop-on-solib-events 0
[1,127,327,219,376] (gdb)
[1,127,327,219,384] 8^done
[1,127,327,219,384] 9-gdb-set stop-on-solib-events 1
[1,127,327,219,385] (gdb)
[1,127,327,219,392] 9^done
[1,127,327,219,572] 10-environment-cd
[1,127,327,219,573] (gdb)
[1,127,327,219,573] 10^done
[1,127,327,219,729] 11-environment-directory
/home/jrodgers/makesystem/bbs_main/cpp_cgi_apps /home/j\
rodgers/makesystem/bbs_main/cpp_cgi_apps/autom4te.cache
/home/jrodgers/makesystem/bbs_main/cpp_cgi_a\
pps/cgi_source
/home/jrodgers/makesystem/bbs_main/cpp_cgi_apps/cgi_source/. deps
[1,127,327,219,734] (gdb)
[1,127,327,219,749]
11^done,source-path=" /home/jrodgers/makesystem/bbs_main/cpp_cgi_apps:/home/jrodg\
ers/makesystem/bbs_main/cpp_cgi_apps/autom4te.cache:/home/jr odgers/makesystem/bbs_main/cpp_cgi_apps/\
cgi_source:/home/jrodgers/makesystem/bbs_main/cpp_cgi_apps/c gi_source/.deps:$cdir:$cwd "
[1,127,327,219,760] 12 info threads
[1,127,327,219,769] (gdb)
[1,127,327,219,769] &"info threads\n"
[1,127,327,219,769] &"No registers.\n"
[1,127,327,219,770] 12^error,msg="No registers."
[1,127,327,219,792] 13-data-list-register-names
[1,127,327,219,809] (gdb)
[1,127,327,219,809]
13^done,register-names=["eax","ecx","edx","ebx","esp ","ebp","esi","edi","eip","e\
flags","cs","ss","ds","es","fs","gs","st0","st1 ","st2","st3","st4","st5","st6","st7","fctrl", "fstat"\
,"ftag","fiseg","fioff","foseg","fooff","fop","xmm0 ","xmm1","xmm2","xmm3","xmm4","xmm5","xmm6","xmm7\
","mxcsr","orig_eax","mm0","mm1","mm2","mm3","mm4 ","mm5","mm6","mm7"]
[1,127,327,219,836] 14-break-insert botrevmatch.cpp:18
[1,127,327,219,913] (gdb)
[1,127,327,219,915]
14^done,bkpt={number="1",type="breakpoint",disp="keep",enabled= "y",addr="0x08049\
9f9",func="main",file="botrevmatch.cpp",line="18",times= "0"}
[1,127,327,219,927] 15-break-insert -t main
[1,127,327,219,942] (gdb)
[1,127,327,219,943]
15^done,bkpt={number="2",type="breakpoint",disp="del",enabled= "y",addr="0x080499\
[1,127,327,219,943] 16-exec-run
[1,127,327,219,952] (gdb)
[1,127,327,219,953] 16^running
[1,127,327,219,958] (gdb)
[1,127,327,220,082] ~"Stopped due to shared library event\n"
[1,127,327,220,119] 16*stopped,thread-id="0"
[1,127,327,220,121] 17 info program
[1,127,327,220,137] (gdb)
[1,127,327,220,138] &"info program\n"
[1,127,327,220,164] ~"\tUsing the running image of child process 6235.\n"
[1,127,327,220,165] ~"Program stopped at 0xb75f82b0.\n"
[1,127,327,220,165] ~"It stopped at a breakpoint that has since been
deleted.\n"[1,127,327,220,174] ~"Type \"info stack\" or \"info registers\"
for more information.\n"
[1,127,327,220,174] 17^done
[1,127,327,220,176] 18 info sharedlibrary
[1,127,327,220,191] (gdb)
[1,127,327,220,192] &"info sharedlibrary\n"
[1,127,327,220,192] ~"From To Syms Read Shared Object
Library\n"
[1,127,327,220,193] ~"0xb75cb9e0 0xb75d3f24 Yes
/usr/lib/libz.so.1\n"
[1,127,327,220,211] ~"0xb759f5d0 0xb75bdf30 Yes
/usr/lib/libstdc++-libc6.2-2.so.3\n"
[1,127,327,220,212] ~"0xb7568500 0xb757fdac Yes
/lib/tls/libm.so.6\n"
[1,127,327,220,221] ~"0xb7443540 0xb753f1c8 Yes
/lib/tls/libc.so.6\n"
[1,127,327,220,221] ~"0xb75ebc30 0xb75fd49f Yes
/lib/ld-linux.so.2\n"
[1,127,327,220,221] 18^done
[1,127,327,220,234] 19-exec-continue
[1,127,327,220,249] (gdb)
[1,127,327,220,249] 19^running
[1,127,327,220,263] (gdb)
[1,127,327,220,279] ~"Stopped due to shared library event\n"
[1,127,327,220,288] 19*stopped,thread-id="0"
[1,127,327,220,288] 20 info sharedlibrary
[1,127,327,220,288] (gdb)
[1,127,327,220,289] &"info sharedlibrary\n"
[1,127,327,220,289] ~"From To Syms Read Shared Object
Library\n"
[1,127,327,220,299] ~"0xb75cb9e0 0xb75d3f24 Yes
[1,127,327,220,307] ~"0xb759f5d0 0xb75bdf30 Yes
[1,127,327,220,308] ~"0xb7568500 0xb757fdac Yes
[1,127,327,220,308] ~"0xb7443540 0xb753f1c8 Yes
[1,127,327,220,323] ~"0xb75ebc30 0xb75fd49f Yes
[1,127,327,220,323] 20^done
[1,127,327,220,324] 21-exec-continue
[1,127,327,220,332] (gdb)
[1,127,327,220,332] 21^running
[1,127,327,220,341] (gdb)
[1,127,327,220,355] ~"Stopped due to shared library event\n"
[1,127,327,220,371] 21*stopped,thread-id="0"
[1,127,327,220,385] 22 info sharedlibrary
[1,127,327,220,385] (gdb)
[1,127,327,220,385] &"info sharedlibrary\n"
[1,127,327,220,386] ~"From To Syms Read Shared Object
Library\n"
[1,127,327,220,394] ~"0xb75cb9e0 0xb75d3f24 Yes
[1,127,327,220,394] ~"0xb759f5d0 0xb75bdf30 Yes
[1,127,327,220,413] ~"0xb7568500 0xb757fdac Yes
[1,127,327,220,414] ~"0xb7443540 0xb753f1c8 Yes
[1,127,327,220,414] ~"0xb75ebc30 0xb75fd49f Yes
[1,127,327,220,414] 22^done
[1,127,327,220,415] 23-exec-continue
[1,127,327,220,423] (gdb)
[1,127,327,220,424] 23^running
[1,127,327,220,431] (gdb)
[1,127,327,220,452]
23*stopped,reason="breakpoint-hit",bkptno="1",thread-id= "0",frame={addr="0x08049\
9f9",func="main",args=[],file="botrevmatch.cpp",line="18 "}
[1,127,327,220,472] 24 info threads
[1,127,327,220,484] (gdb)
[1,127,327,220,484] &"info threads\n"
[1,127,327,220,501] 24^done
[1,127,327,220,516] 25-stack-info-depth
[1,127,327,220,516] (gdb)
[1,127,327,220,517] 25^done,depth="1"
[1,127,327,220,530] 26-stack-list-frames 0 1
[1,127,327,220,530] (gdb)
[1,127,327,220,543]
26^done,stack=[frame={level="0",addr="0x080499f9",func="main ",file="botrevmatch.\
cpp",line="18"}]
[1,127,327,220,547] 27-data-list-changed-registers
[1,127,327,220,557] (gdb)
[1,127,327,220,557]
27^done,changed-registers=["0","1","2","3","4","5 ","6","7","8","9","10","11","12\
","13","15","24","26","40","41"]
[1,127,327,220,572] 28 info sharedlibrary
[1,127,327,220,583] (gdb)
[1,127,327,220,583] &"info sharedlibrary\n"
[1,127,327,220,596] ~"From To Syms Read Shared Object
Library\n"
[1,127,327,220,596] ~"0xb75cb9e0 0xb75d3f24 Yes
[1,127,327,220,597] ~"0xb759f5d0 0xb75bdf30 Yes
[1,127,327,220,611] ~"0xb7568500 0xb757fdac Yes
[1,127,327,220,611] ~"0xb7443540 0xb753f1c8 Yes
[1,127,327,220,612] ~"0xb75ebc30 0xb75fd49f Yes
[1,127,327,220,612] 28^done
[1,127,327,221,050] (gdb)
>>>>> JMR CLICKED ON VARIABLES TAB <<<<<<<<<<
[[1,127,327,266,170] 29-stack-list-arguments 0 0 0
[1,127,327,266,171] 29^done,stack-args=[frame={level="0",args=[]}]
[1,127,327,266,171] (gdb)
[1,127,327,266,172] 30-stack-list-locals 0
[1,127,327,266,189]
30^done,locals=[name="SECURITY_PASSWORD",name="CGI_KEY_LISTINGID ",name="CGI_KEY_\
DEBUG",name="listingId",name="matchedBotCommaList",name= "debug_mode",name="cgi"]
[1,127,327,266,189] (gdb)
[1,127,327,266,218] 31-var-create - * SECURITY_PASSWORD
[1,127,327,266,219] 31^done,name="var1",numchild="1",type="TString"
[1,127,327,266,219] (gdb)
[1,127,327,266,238] 32 ptype TString
[1,127,327,266,256] &"ptype TString\n"
[1,127,327,266,256] ~"type = class TString {\n"
[1,127,327,266,256] ~" private:\n"
[1,127,327,266,256] ~" unsigned char *data;\n"
[1,127,327,266,256] ~" char *work;\n"
[1,127,327,266,256] ~" int len;\n"
[1,127,327,266,256] ~" int capacity;\n"
[1,127,327,266,257] ~" bool changed;\n"
[1,127,327,266,257] ~"\n"
[1,127,327,266,257] ~" public:\n"
[1,127,327,266,257] ~" ~TString(void);\n"
[1,127,327,266,257] ~" TString(void);\n"
[1,127,327,266,257] ~" TString(TString const &);\n"
[1,127,327,266,257] ~" TString(char const *);\n"
[1,127,327,266,257] ~" bool operator==(TString const &) const;\n"
[1,127,327,266,258] ~" bool equals(TString const &) const;\n"
[1,127,327,266,258] ~" bool equalsIgnoreCase(TString const &) const;\n"
[1,127,327,266,258] ~" bool operator!=(TString const &) const;\n"
[1,127,327,266,258] ~" TString & operator=(TString const &);\n"
[1,127,327,266,258] ~" TString & operator=(char const *);\n"
[1,127,327,266,258] ~" void assign(TString const &);\n"
[1,127,327,266,258] ~" void assign(char const *);\n"
[1,127,327,266,258] ~" void assign(char const *, int);\n"
[1,127,327,266,258] ~" TString & operator+=(TString const &);\n"
[1,127,327,266,259] ~" TString & operator+=(char const *);\n"
[1,127,327,266,259] ~" TString & operator+=(char);\n"
[1,127,327,266,259] ~" void append(TString const &);\n"
[1,127,327,266,259] ~" void append(char const *);\n"
[1,127,327,266,259] ~" void append(char);\n"
[1,127,327,266,259] ~" void append(int, char const *);\n"
[1,127,327,266,259] ~" unsigned char & operator[](int) const;\n"
[1,127,327,266,259] ~" int compare(TString const &) const;\n"
[1,127,327,266,260] ~" int compareIgnoreCase(TString const &) const;\n"
[1,127,327,266,260] ~" int compare(TString const &, int, int) const;\n"
[1,127,327,266,260] ~" int compareIgnoreCase(TString const &, int, int)
const;\n"
[1,127,327,266,260] ~" int compareMiddle(TString const &, int, int)
const;\n"
[1,127,327,266,260] ~" bool containsNonPrintable(bool) const;\n"
[1,127,327,266,260] ~" bool isDigit(int) const;\n"
[1,127,327,266,260] ~" int getDigit(int) const;\n"
[1,127,327,266,260] ~" bool isLetter(int) const;\n"
[1,127,327,266,261] ~" int find(TString const &, int) const;\n"
[1,127,327,266,261] ~" int findIgnoreCase(TString const &, int) const;\n"
[1,127,327,266,261] ~" int find_first_of(TString const &, int) const;\n"
[1,127,327,266,261] ~" int find_first_not_of(TString const &, int)
const;\n"
[1,127,327,266,261] ~" int rfind(TString const &) const;\n"
[1,127,327,266,261] ~" int find_last_of(TString const &) const;\n"
[1,127,327,266,261] ~" TString substr(int) const;\n"
[1,127,327,266,261] ~" TString substr(int, int) const;\n"
[1,127,327,266,262] ~" TString substrByPosition(int, int) const;\n"
[1,127,327,266,262] ~" void insert(int, char const *);\n"
[1,127,327,266,262] ~" void insert(int, TString const &);\n"
[1,127,327,266,262] ~" void replace(int, int, TString const &);\n"
[1,127,327,266,262] ~" void erase(int, int);\n"
[1,127,327,266,262] ~" void remove(char);\n"
[1,127,327,266,262] ~" char * c_str(void) const;\n"
[1,127,327,266,262] ~" int length(void) const;\n"
[1,127,327,266,263] ~" int size(void) const;\n"
[1,127,327,266,263] ~" void reserve(int);\n"
[1,127,327,266,263] ~" void eraseAll(void);\n"
[1,127,327,266,263] ~" void toUpperCase(void);\n"
[1,127,327,266,263] ~" void toLowerCase(void);\n"
[1,127,327,266,263] ~" TString removeNonAlphaNumeric(void) const;\n"
[1,127,327,266,263] ~" TString makeDiomoSafe(void) const;\n"
[1,127,327,266,264] ~" TString removeNonAlpha(void) const;\n"
[1,127,327,266,264] ~" TString removeNonNumeric(void) const;\n"
[1,127,327,266,264] ~" TString URLEncode(bool);\n"
[1,127,327,266,264] ~" TString compact(void);\n"
[1,127,327,266,264] ~" int isEmailAddress(void);\n"
[1,127,327,266,264] ~" TString toHTML(void);\n"
[1,127,327,266,281] ~" bool endsWith(TString const &) const;\n"
[1,127,327,266,281] ~" bool startsWith(TString const &) const;\n"
[1,127,327,266,282] ~"}\n"
[1,127,327,266,282] 32^done
[1,127,327,266,282] (gdb)
[1,127,327,266,375] 33-var-create - * CGI_KEY_LISTINGID
[1,127,327,266,375] 33^done,name="var2",numchild="1",type="TString"
[1,127,327,266,376] (gdb)
[1,127,327,266,376] 34 ptype TString
[1,127,327,266,381] &"ptype TString\n"
[1,127,327,266,381] ~"type = class TString {\n"
[1,127,327,266,381] ~" private:\n"
[1,127,327,266,381] ~" unsigned char *data;\n"
[1,127,327,266,381] ~" char *work;\n"
[1,127,327,266,381] ~" int len;\n"
[1,127,327,266,381] ~" int capacity;\n"
[1,127,327,266,382] ~" bool changed;\n"
[1,127,327,266,382] ~"\n"
[1,127,327,266,382] ~" public:\n"
[1,127,327,266,382] ~" ~TString(void);\n"
[1,127,327,266,382] ~" TString(void);\n"
[1,127,327,266,382] ~" TString(TString const &);\n"
[1,127,327,266,382] ~" TString(char const *);\n"
[1,127,327,266,382] ~" bool operator==(TString const &) const;\n"
[1,127,327,266,383] ~" bool equals(TString const &) const;\n"
[1,127,327,266,383] ~" bool equalsIgnoreCase(TString const &) const;\n"
[1,127,327,266,383] ~" bool operator!=(TString const &) const;\n"
[1,127,327,266,383] ~" TString & operator=(TString const &);\n"
[1,127,327,266,383] ~" TString & operator=(char const *);\n"
[1,127,327,266,383] ~" void assign(TString const &);\n"
[1,127,327,266,383] ~" void assign(char const *);\n"
[1,127,327,266,383] ~" void assign(char const *, int);\n"
[1,127,327,266,383] ~" TString & operator+=(TString const &);\n"
[1,127,327,266,384] ~" TString & operator+=(char const *);\n"
[1,127,327,266,384] ~" TString & operator+=(char);\n"
[1,127,327,266,384] ~" void append(TString const &);\n"
[1,127,327,266,384] ~" void append(char const *);\n"
[1,127,327,266,384] ~" void append(char);\n"
[1,127,327,266,384] ~" void append(int, char const *);\n"
[1,127,327,266,384] ~" unsigned char & operator[](int) const;\n"
[1,127,327,266,384] ~" int compare(TString const &) const;\n"
[1,127,327,266,385] ~" int compareIgnoreCase(TString const &) const;\n"
[1,127,327,266,385] ~" int compare(TString const &, int, int) const;\n"
[1,127,327,266,385] ~" int compareIgnoreCase(TString const &, int, int)
const;\n"
[1,127,327,266,385] ~" int compareMiddle(TString const &, int, int)
const;\n"
[1,127,327,266,385] ~" bool containsNonPrintable(bool) const;\n"
[1,127,327,266,385] ~" bool isDigit(int) const;\n"
[1,127,327,266,385] ~" int getDigit(int) const;\n"
[1,127,327,266,386] ~" bool isLetter(int) const;\n"
[1,127,327,266,386] ~" int find(TString const &, int) const;\n"
[1,127,327,266,386] ~" int findIgnoreCase(TString const &, int) const;\n"
[1,127,327,266,386] ~" int find_first_of(TString const &, int) const;\n"
[1,127,327,266,386] ~" int find_first_not_of(TString const &, int)
const;\n"
[1,127,327,266,386] ~" int rfind(TString const &) const;\n"
[1,127,327,266,386] ~" int find_last_of(TString const &) const;\n"
[1,127,327,266,387] ~" TString substr(int) const;\n"
[1,127,327,266,387] ~" TString substr(int, int) const;\n"
[1,127,327,266,387] ~" TString substrByPosition(int, int) const;\n"
[1,127,327,266,387] ~" void insert(int, char const *);\n"
[1,127,327,266,387] ~" void insert(int, TString const &);\n"
[1,127,327,266,387] ~" void replace(int, int, TString const &);\n"
[1,127,327,266,387] ~" void erase(int, int);\n"
[1,127,327,266,387] ~" void remove(char);\n"
[1,127,327,266,388] ~" char * c_str(void) const;\n"
[1,127,327,266,388] ~" int length(void) const;\n"
[1,127,327,266,388] ~" int size(void) const;\n"
[1,127,327,266,388] ~" void reserve(int);\n"
[1,127,327,266,388] ~" void eraseAll(void);\n"
[1,127,327,266,388] ~" void toUpperCase(void);\n"
[1,127,327,266,388] ~" void toLowerCase(void);\n"
[1,127,327,266,389] ~" TString removeNonAlphaNumeric(void) const;\n"
[1,127,327,266,389] ~" TString makeDiomoSafe(void) const;\n"
[1,127,327,266,389] ~" TString removeNonAlpha(void) const;\n"
[1,127,327,266,389] ~" TString removeNonNumeric(void) const;\n"
[1,127,327,266,389] ~" TString URLEncode(bool);\n"
[1,127,327,266,389] ~" TString compact(void);\n"
[1,127,327,266,389] ~" int isEmailAddress(void);\n"
[1,127,327,266,390] ~" TString toHTML(void);\n"
[1,127,327,266,402] ~" bool endsWith(TString const &) const;\n"
[1,127,327,266,402] ~" bool startsWith(TString const &) const;\n"
[1,127,327,266,402] ~"}\n"
[1,127,327,266,403] 34^done
[1,127,327,266,403] (gdb)
[1,127,327,266,423] 35-var-create - * CGI_KEY_DEBUG
[1,127,327,266,423] 35^done,name="var3",numchild="1",type="TString"
[1,127,327,266,423] (gdb)
[1,127,327,266,426] 36 ptype TString
[1,127,327,266,429] &"ptype TString\n"
[1,127,327,266,429] ~"type = class TString {\n"
[1,127,327,266,429] ~" private:\n"
[1,127,327,266,430] ~" unsigned char *data;\n"
[1,127,327,266,430] ~" char *work;\n"
[1,127,327,266,430] ~" int len;\n"
[1,127,327,266,430] ~" int capacity;\n"
[1,127,327,266,430] ~" bool changed;\n"
[1,127,327,266,430] ~"\n"
[1,127,327,266,430] ~" public:\n"
[1,127,327,266,431] ~" ~TString(void);\n"
[1,127,327,266,431] ~" TString(void);\n"
[1,127,327,266,431] ~" TString(TString const &);\n"
[1,127,327,266,431] ~" TString(char const *);\n"
[1,127,327,266,431] ~" bool operator==(TString const &) const;\n"
[1,127,327,266,431] ~" bool equals(TString const &) const;\n"
[1,127,327,266,431] ~" bool equalsIgnoreCase(TString const &) const;\n"
[1,127,327,266,431] ~" bool operator!=(TString const &) const;\n"
[1,127,327,266,432] ~" TString & operator=(TString const &);\n"
[1,127,327,266,432] ~" TString & operator=(char const *);\n"
[1,127,327,266,432] ~" void assign(TString const &);\n"
[1,127,327,266,432] ~" void assign(char const *);\n"
[1,127,327,266,432] ~" void assign(char const *, int);\n"
[1,127,327,266,432] ~" TString & operator+=(TString const &);\n"
[1,127,327,266,432] ~" TString & operator+=(char const *);\n"
[1,127,327,266,432] ~" TString & operator+=(char);\n"
[1,127,327,266,433] ~" void append(TString const &);\n"
[1,127,327,266,433] ~" void append(char const *);\n"
[1,127,327,266,433] ~" void append(char);\n"
[1,127,327,266,433] ~" void append(int, char const *);\n"
[1,127,327,266,433] ~" unsigned char & operator[](int) const;\n"
[1,127,327,266,433] ~" int compare(TString const &) const;\n"
[1,127,327,266,433] ~" int compareIgnoreCase(TString const &) const;\n"
[1,127,327,266,433] ~" int compare(TString const &, int, int) const;\n"
[1,127,327,266,433] ~" int compareIgnoreCase(TString const &, int, int)
const;\n"
[1,127,327,266,434] ~" int compareMiddle(TString const &, int, int)
const;\n"
[1,127,327,266,434] ~" bool containsNonPrintable(bool) const;\n"
[1,127,327,266,434] ~" bool isDigit(int) const;\n"
[1,127,327,266,434] ~" int getDigit(int) const;\n"
[1,127,327,266,434] ~" bool isLetter(int) const;\n"
[1,127,327,266,434] ~" int find(TString const &, int) const;\n"
[1,127,327,266,434] ~" int findIgnoreCase(TString const &, int) const;\n"
[1,127,327,266,434] ~" int find_first_of(TString const &, int) const;\n"
[1,127,327,266,435] ~" int find_first_not_of(TString const &, int)
const;\n"
[1,127,327,266,435] ~" int rfind(TString const &) const;\n"
[1,127,327,266,435] ~" int find_last_of(TString const &) const;\n"
[1,127,327,266,436] ~" TString substr(int) const;\n"
[1,127,327,266,437] ~" TString substr(int, int) const;\n"
[1,127,327,266,437] ~" TString substrByPosition(int, int) const;\n"
[1,127,327,266,437] ~" void insert(int, char const *);\n"
[1,127,327,266,437] ~" void insert(int, TString const &);\n"
[1,127,327,266,437] ~" void replace(int, int, TString const &);\n"
[1,127,327,266,437] ~" void erase(int, int);\n"
[1,127,327,266,437] ~" void remove(char);\n"
[1,127,327,266,437] ~" char * c_str(void) const;\n"
[1,127,327,266,438] ~" int length(void) const;\n"
[1,127,327,266,438] ~" int size(void) const;\n"
[1,127,327,266,438] ~" void reserve(int);\n"
[1,127,327,266,438] ~" void eraseAll(void);\n"
[1,127,327,266,438] ~" void toUpperCase(void);\n"
[1,127,327,266,438] ~" void toLowerCase(void);\n"
[1,127,327,266,438] ~" TString removeNonAlphaNumeric(void) const;\n"
[1,127,327,266,439] ~" TString makeDiomoSafe(void) const;\n"
[1,127,327,266,439] ~" TString removeNonAlpha(void) const;\n"
[1,127,327,266,439] ~" TString removeNonNumeric(void) const;\n"
[1,127,327,266,439] ~" TString URLEncode(bool);\n"
[1,127,327,266,439] ~" TString compact(void);\n"
[1,127,327,266,439] ~" int isEmailAddress(void);\n"
[1,127,327,266,439] ~" TString toHTML(void);\n"
[1,127,327,266,440] ~" bool endsWith(TString const &) const;\n"
[1,127,327,266,440] ~" bool startsWith(TString const &) const;\n"
[1,127,327,266,440] ~"}\n"
[1,127,327,266,440] 36^done
[1,127,327,266,441] (gdb)
[1,127,327,266,460] 37-var-create - * listingId
[1,127,327,266,460] 37^done,name="var4",numchild="1",type="TString"
[1,127,327,266,461] (gdb)
[1,127,327,266,462] 38 ptype TString
[1,127,327,266,465] &"ptype TString\n"
[1,127,327,266,465] ~"type = class TString {\n"
[1,127,327,266,466] ~" private:\n"
[1,127,327,266,466] ~" unsigned char *data;\n"
[1,127,327,266,466] ~" char *work;\n"
[1,127,327,266,466] ~" int len;\n"
[1,127,327,266,466] ~" int capacity;\n"
[1,127,327,266,466] ~" bool changed;\n"
[1,127,327,266,466] ~"\n"
[1,127,327,266,466] ~" public:\n"
[1,127,327,266,466] ~" ~TString(void);\n"
[1,127,327,266,467] ~" TString(void);\n"
[1,127,327,266,467] ~" TString(TString const &);\n"
[1,127,327,266,467] ~" TString(char const *);\n"
[1,127,327,266,467] ~" bool operator==(TString const &) const;\n"
[1,127,327,266,467] ~" bool equals(TString const &) const;\n"
[1,127,327,266,467] ~" bool equalsIgnoreCase(TString const &) const;\n"
[1,127,327,266,467] ~" bool operator!=(TString const &) const;\n"
[1,127,327,266,467] ~" TString & operator=(TString const &);\n"
[1,127,327,266,467] ~" TString & operator=(char const *);\n"
[1,127,327,266,468] ~" void assign(TString const &);\n"
[1,127,327,266,468] ~" void assign(char const *);\n"
[1,127,327,266,468] ~" void assign(char const *, int);\n"
[1,127,327,266,468] ~" TString & operator+=(TString const &);\n"
[1,127,327,266,468] ~" TString & operator+=(char const *);\n"
[1,127,327,266,468] ~" TString & operator+=(char);\n"
[1,127,327,266,468] ~" void append(TString const &);\n"
[1,127,327,266,468] ~" void append(char const *);\n"
[1,127,327,266,468] ~" void append(char);\n"
[1,127,327,266,469] ~" void append(int, char const *);\n"
[1,127,327,266,469] ~" unsigned char & operator[](int) const;\n"
[1,127,327,266,469] ~" int compare(TString const &) const;\n"
[1,127,327,266,469] ~" int compareIgnoreCase(TString const &) const;\n"
[1,127,327,266,469] ~" int compare(TString const &, int, int) const;\n"
[1,127,327,266,469] ~" int compareIgnoreCase(TString const &, int, int)
const;\n"
[1,127,327,266,469] ~" int compareMiddle(TString const &, int, int)
const;\n"
[1,127,327,266,469] ~" bool containsNonPrintable(bool) const;\n"
[1,127,327,266,470] ~" bool isDigit(int) const;\n"
[1,127,327,266,470] ~" int getDigit(int) const;\n"
[1,127,327,266,470] ~" bool isLetter(int) const;\n"
[1,127,327,266,470] ~" int find(TString const &, int) const;\n"
[1,127,327,266,470] ~" int findIgnoreCase(TString const &, int) const;\n"
[1,127,327,266,470] ~" int find_first_of(TString const &, int) const;\n"
[1,127,327,266,470] ~" int find_first_not_of(TString const &, int)
const;\n"
[1,127,327,266,470] ~" int rfind(TString const &) const;\n"
[1,127,327,266,470] ~" int find_last_of(TString const &) const;\n"
[1,127,327,266,471] ~" TString substr(int) const;\n"
[1,127,327,266,471] ~" TString substr(int, int) const;\n"
[1,127,327,266,471] ~" TString substrByPosition(int, int) const;\n"
[1,127,327,266,471] ~" void insert(int, char const *);\n"
[1,127,327,266,471] ~" void insert(int, TString const &);\n"
[1,127,327,266,471] ~" void replace(int, int, TString const &);\n"
[1,127,327,266,471] ~" void erase(int, int);\n"
[1,127,327,266,471] ~" void remove(char);\n"
[1,127,327,266,472] ~" char * c_str(void) const;\n"
[1,127,327,266,472] ~" int length(void) const;\n"
[1,127,327,266,472] ~" int size(void) const;\n"
[1,127,327,266,472] ~" void reserve(int);\n"
[1,127,327,266,472] ~" void eraseAll(void);\n"
[1,127,327,266,472] ~" void toUpperCase(void);\n"
[1,127,327,266,472] ~" void toLowerCase(void);\n"
[1,127,327,266,472] ~" TString removeNonAlphaNumeric(void) const;\n"
[1,127,327,266,472] ~" TString makeDiomoSafe(void) const;\n"
[1,127,327,266,473] ~" TString removeNonAlpha(void) const;\n"
[1,127,327,266,473] ~" TString removeNonNumeric(void) const;\n"
[1,127,327,266,473] ~" TString URLEncode(bool);\n"
[1,127,327,266,473] ~" TString compact(void);\n"
[1,127,327,266,474] ~" int isEmailAddress(void);\n"
[1,127,327,266,474] ~" TString toHTML(void);\n"
[1,127,327,266,474] ~" bool endsWith(TString const &) const;\n"
[1,127,327,266,474] ~" bool startsWith(TString const &) const;\n"
[1,127,327,266,474] ~"}\n"
[1,127,327,266,474] 38^done
[1,127,327,266,475] (gdb)
[1,127,327,266,494] 39-var-create - * matchedBotCommaList
[1,127,327,266,495] 39^done,name="var5",numchild="1",type="TString"
[1,127,327,266,495] (gdb)
[1,127,327,266,495] 40 ptype TString
[1,127,327,266,498] &"ptype TString\n"
[1,127,327,266,498] ~"type = class TString {\n"
[1,127,327,266,498] ~" private:\n"
[1,127,327,266,498] ~" unsigned char *data;\n"
[1,127,327,266,499] ~" char *work;\n"
[1,127,327,266,499] ~" int len;\n"
[1,127,327,266,499] ~" int capacity;\n"
[1,127,327,266,499] ~" bool changed;\n"
[1,127,327,266,499] ~"\n"
[1,127,327,266,505] ~" public:\n"
[1,127,327,266,505] ~" ~TString(void);\n"
[1,127,327,266,505] ~" TString(void);\n"
[1,127,327,266,505] ~" TString(TString const &);\n"
[1,127,327,266,505] ~" TString(char const *);\n"
[1,127,327,266,505] ~" bool operator==(TString const &) const;\n"
[1,127,327,266,506] ~" bool equals(TString const &) const;\n"
[1,127,327,266,506] ~" bool equalsIgnoreCase(TString const &) const;\n"
[1,127,327,266,506] ~" bool operator!=(TString const &) const;\n"
[1,127,327,266,506] ~" TString & operator=(TString const &);\n"
[1,127,327,266,506] ~" TString & operator=(char const *);\n"
[1,127,327,266,506] ~" void assign(TString const &);\n"
[1,127,327,266,506] ~" void assign(char const *);\n"
[1,127,327,266,506] ~" void assign(char const *, int);\n"
[1,127,327,266,506] ~" TString & operator+=(TString const &);\n"
[1,127,327,266,507] ~" TString & operator+=(char const *);\n"
[1,127,327,266,507] ~" TString & operator+=(char);\n"
[1,127,327,266,507] ~" void append(TString const &);\n"
[1,127,327,266,507] ~" void append(char const *);\n"
[1,127,327,266,507] ~" void append(char);\n"
[1,127,327,266,507] ~" void append(int, char const *);\n"
[1,127,327,266,507] ~" unsigned char & operator[](int) const;\n"
[1,127,327,266,507] ~" int compare(TString const &) const;\n"
[1,127,327,266,507] ~" int compareIgnoreCase(TString const &) const;\n"
[1,127,327,266,508] ~" int compare(TString const &, int, int) const;\n"
[1,127,327,266,508] ~" int compareIgnoreCase(TString const &, int, int)
const;\n"
[1,127,327,266,508] ~" int compareMiddle(TString const &, int, int)
const;\n"
[1,127,327,266,508] ~" bool containsNonPrintable(bool) const;\n"
[1,127,327,266,508] ~" bool isDigit(int) const;\n"
[1,127,327,266,508] ~" int getDigit(int) const;\n"
[1,127,327,266,509] ~" bool isLetter(int) const;\n"
[1,127,327,266,509] ~" int find(TString const &, int) const;\n"
[1,127,327,266,509] ~" int findIgnoreCase(TString const &, int) const;\n"
[1,127,327,266,509] ~" int find_first_of(TString const &, int) const;\n"
[1,127,327,266,510] ~" int find_first_not_of(TString const &, int)
const;\n"
[1,127,327,266,510] ~" int rfind(TString const &) const;\n"
[1,127,327,266,510] ~" int find_last_of(TString const &) const;\n"
[1,127,327,266,510] ~" TString substr(int) const;\n"
[1,127,327,266,510] ~" TString substr(int, int) const;\n"
[1,127,327,266,510] ~" TString substrByPosition(int, int) const;\n"
[1,127,327,266,510] ~" void insert(int, char const *);\n"
[1,127,327,266,511] ~" void insert(int, TString const &);\n"
[1,127,327,266,511] ~" void replace(int, int, TString const &);\n"
[1,127,327,266,511] ~" void erase(int, int);\n"
[1,127,327,266,511] ~" void remove(char);\n"
[1,127,327,266,511] ~" char * c_str(void) const;\n"
[1,127,327,266,511] ~" int length(void) const;\n"
[1,127,327,266,511] ~" int size(void) const;\n"
[1,127,327,266,511] ~" void reserve(int);\n"
[1,127,327,266,512] ~" void eraseAll(void);\n"
[1,127,327,266,512] ~" void toUpperCase(void);\n"
[1,127,327,266,512] ~" void toLowerCase(void);\n"
[1,127,327,266,512] ~" TString removeNonAlphaNumeric(void) const;\n"
[1,127,327,266,512] ~" TString makeDiomoSafe(void) const;\n"
[1,127,327,266,512] ~" TString removeNonAlpha(void) const;\n"
[1,127,327,266,512] ~" TString removeNonNumeric(void) const;\n"
[1,127,327,266,512] ~" TString URLEncode(bool);\n"
[1,127,327,266,513] ~" TString compact(void);\n"
[1,127,327,266,513] ~" int isEmailAddress(void);\n"
[1,127,327,266,513] ~" TString toHTML(void);\n"
[1,127,327,266,513] ~" bool endsWith(TString const &) const;\n"
[1,127,327,266,513] ~" bool startsWith(TString const &) const;\n"
[1,127,327,266,513] ~"}\n"
[1,127,327,266,514] 40^done
[1,127,327,266,514] (gdb)
[1,127,327,266,534] 41-var-create - * debug_mode
[1,127,327,266,534] 41^done,name="var6",numchild="0",type="bool"
[1,127,327,266,534] (gdb)
[1,127,327,266,535] 42-var-create - * cgi
[1,127,327,266,549] 42^done,name="var7",numchild="1",type="CGI"
[1,127,327,266,550] (gdb)
[1,127,327,266,557] 43 ptype CGI
[1,127,327,266,558] &"ptype CGI\n"
[1,127,327,266,558] ~"type = class CGI {\n"
[1,127,327,266,558] ~" private:\n"
[1,127,327,266,558] ~" TPairs data;\n"
[1,127,327,266,558] ~"\n"
[1,127,327,266,558] ~" public:\n"
[1,127,327,266,559] ~" CGI & operator=(CGI const &);\n"
[1,127,327,266,559] ~" ~CGI(void);\n"
[1,127,327,266,587] 44-gdb-exit
news:dgs65k$948$1@news.eclipse.org...
> information.
>> selected the variables tab (the whole of debugging for me from within
>> Eclipse) I crashed with the errors below...
>> -Jerry
>>> Hi,
>>> work for debugging. Do you have any other ideas? Thanks for all your
>>> help.
>>>>>> Upgraded GDB
>>> are
>>> conditions.
>>> details.
>>> (gdb)
>>> -Jerry
>>>> Jerry,
>>>> your question. But I believe, if you just download the zipped file and
>>>> unzip it, it would work fine.
>>>> Mikhail
>>>>> Thanks Mikhail,
>>>>> Thnks,
>>>>> Jerry
>>>>> 025e513b
>>>>> 3.90-0.20030710.40
>>>>>>> Hi Mikhail,
>>>>>>> and use "make" to build it?
>>>>>>> Jerry
>>>>>>>>> CDT 3.0.0
>>>>>>>>> -Jerrry
>>>>>>>>>> Hi,
>>>>>>>>>> problems - The problem is when I select Run - Debug and I set a
>>>>>>>>>> break point however as soon as it stops it ends up termintaing -
>>>>>>>>>> all I get is this in the console. I pretty much accepted the
>>>>>>>>>> defaults for debugging - I selected GDB as the debugger and have
>>>>>>>>>> thanks,
>>>>>>>>>> Jerry Rodgers
| Re: Debugging issues... [message #154891 is a reply to message #154852] |
Wed, 21 September 2005 15:03   |
gdb crashes on the "ptype CGI" command. The lines
43^done
(gdb)
would indicate that ptype was completed.
Unfortunately, this is a bug in gdb and the gdb team only can fix it. We
have seen similar crashes for complex C++ classes.
The possible workaround is to uncheck the "Automatically track the values of
variables" option and enable only those variables that you want to watch. To
access this option, open the "Debugger" tab of the launch configuration
dialog and press the "Advanced" button. Hopefully, this will help.
news:dgs9j5$eb3$1@news.eclipse.org...
> you search below for JMR you will see where the debug info stops
> before I then clicked on the variables tab and caused the debugger to
> crash. I kinda see what is happening but not sure what steps to take - it
> looks like when the variables tab is clicked it does some sort of
> discovery process with gdb and determines the type of all the variables
> and what their signatures are etc and it looks like it stops on a variable
> this is of type CGI - I don't really see any error though just a gdb
> exit... ?
> -Xms40m
> -Xmx256m
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 78009
> -vmargs
> -Xms40m
> -Xmx256m
> Install location:
> Configuration file:
> Framework located:
> Splash location:
> runCommand:
> Debug options:
> [1,127,327,219,055]
> -q -\
> pps/cgi_source
> [1,127,327,219,749]
> [1,127,327,219,809]
> [1,127,327,219,915]
> [1,127,327,219,943]
> Library\n"
> [1,127,327,220,193] ~"0xb75cb9e0 0xb75d3f24 Yes /usr/lib/libz.so.1\n"
> [1,127,327,220,212] ~"0xb7568500 0xb757fdac Yes /lib/tls/libm.so.6\n"
> [1,127,327,220,221] ~"0xb7443540 0xb753f1c8 Yes /lib/tls/libc.so.6\n"
> [1,127,327,220,221] ~"0xb75ebc30 0xb75fd49f Yes /lib/ld-linux.so.2\n"
> Library\n"
> [1,127,327,220,299] ~"0xb75cb9e0 0xb75d3f24 Yes /usr/lib/libz.so.1\n"
> [1,127,327,220,308] ~"0xb7568500 0xb757fdac Yes /lib/tls/libm.so.6\n"
> [1,127,327,220,308] ~"0xb7443540 0xb753f1c8 Yes /lib/tls/libc.so.6\n"
> [1,127,327,220,323] ~"0xb75ebc30 0xb75fd49f Yes /lib/ld-linux.so.2\n"
> Library\n"
> [1,127,327,220,394] ~"0xb75cb9e0 0xb75d3f24 Yes /usr/lib/libz.so.1\n"
> [1,127,327,220,413] ~"0xb7568500 0xb757fdac Yes /lib/tls/libm.so.6\n"
> [1,127,327,220,414] ~"0xb7443540 0xb753f1c8 Yes /lib/tls/libc.so.6\n"
> [1,127,327,220,414] ~"0xb75ebc30 0xb75fd49f Yes /lib/ld-linux.so.2\n"
> [1,127,327,220,452]
> [1,127,327,220,543]
> cpp",line="18"}]
> [1,127,327,220,557]
> Library\n"
> [1,127,327,220,596] ~"0xb75cb9e0 0xb75d3f24 Yes /usr/lib/libz.so.1\n"
> [1,127,327,220,611] ~"0xb7568500 0xb757fdac Yes /lib/tls/libm.so.6\n"
> [1,127,327,220,611] ~"0xb7443540 0xb753f1c8 Yes /lib/tls/libc.so.6\n"
> [1,127,327,220,612] ~"0xb75ebc30 0xb75fd49f Yes /lib/ld-linux.so.2\n"
> [1,127,327,266,189]
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
> const;\n"
>> gdb crashes when the CDT debugger tries to retrieve a variable-related
>> information.
>>> -Jerry
>>>> Hi,
>>>> break point the program is terminated with the following error. with
>>>> no break points set the program runs fine via Eclipse - GDB and DDD all
>>>> still work for debugging. Do you have any other ideas? Thanks for all
>>>> your help.
>>>>>>> Upgraded GDB
>>>> you are
>>>> conditions.
>>>> details.
>>>> (gdb)
>>>> -Jerry
>>>>> Jerry,
>>>>> Mikhail
>>>>>> Thanks Mikhail,
>>>>>> too. I grabbed an RPM for redhat from centos and when I ran
>>>>>> the --test option I got the following errors. Does this mean that I
>>>>>> need to uninstall what is there now? Or issue some other switch on
>>>>>> the rpm command or does it mean I can not install this rpm on this
>>>>>> Thnks,
>>>>>> Jerry
>>>>>> 025e513b
>>>>>> 3.90-0.20030710.40
>>>>>>>projects. You can simply download the binary from the RedHat site.
>>>>>>>> Hi Mikhail,
>>>>>>>> Jerry
>>>>>>>>>> CDT 3.0.0
>>>>>>>>>> -Jerrry
>>>>>>>>>>> Hi,
>>>>>>>>>>> (as long as I do not have any break points set) wihtout any
>>>>>>>>>>> try to step I get this error.
>>>>>>>>>>> thanks,
>>>>>>>>>>> Jerry Rodgers
| Re: Debugging issues... [message #154913 is a reply to message #154891] |
Wed, 21 September 2005 16:53  |
While that is a major bummer - at least I feel grateful that I know where I
stand now - I'll give your approach a try and just not watch complex types.
thanks much.
-Jerry
news:dgsaq8$gbt$1@news.eclipse.org...
> 43^done
> (gdb)
> of variables" option and enable only those variables that you want to
> watch. To access this option, open the "Debugger" tab of the launch
> configuration dialog and press the "Advanced" button. Hopefully, this will
> help.
>> Hi,
>> on the very first line within my main method - recorded that output and
>> if you search below for JMR you will see where the debug info stops
>> it looks like when the variables tab is clicked it does some sort of
>> variable this is of type CGI - I don't really see any error though just a
>> gdb exit... ?
>> help.
>> -Xms40m
>> -Xmx256m
>> -os linux
>> -ws gtk
>> -arch x86
>> -name Eclipse
>> -showsplash 600
>> -exitdata 78009
>> -vmargs
>> -Xms40m
>> -Xmx256m
>> Install location:
>> Configuration file:
>> Framework located:
>> Splash location:
>> runCommand:
>> Debug options:
>> [1,127,327,219,055]
>> -q -\
>> pps/cgi_source
>> [1,127,327,219,749]
>> [1,127,327,219,809]
>> [1,127,327,219,915]
>> [1,127,327,219,943]
>> registers\" for more information.\n"
>> Library\n"
>> Library\n"
>> Library\n"
>> [1,127,327,220,452]
>> [1,127,327,220,543]
>> cpp",line="18"}]
>> [1,127,327,220,557]
>> Library\n"
>> [1,127,327,266,189]
>> const;\n"
>> const;\n"
>> const;\n"
>> int) const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> int) const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> int) const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> int) const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> int) const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>> const;\n"
>>> information.
>>>> selected and was able to break and step through code - HOWEVER when I
>>>> then selected the variables tab (the whole of debugging for me from
>>>> within Eclipse) I crashed with the errors below...
>>>> -Jerry
>>>>> Hi,
>>>>> all still work for debugging. Do you have any other ideas? Thanks for
>>>>> all your help.
>>>>>>>> Upgraded GDB
>>>>> you are
>>>>> conditions.
>>>>> details.
>>>>> (gdb)
>>>>> -Jerry
>>>>>> Jerry,
>>>>>> and unzip it, it would work fine.
>>>>>> Mikhail
>>>>>>> Thanks Mikhail,
>>>>>>> Thnks,
>>>>>>> Jerry
>>>>>>> ID 025e513b
>>>>>>> conflicts with file from package gdb-5.
>>>>>>> 3.90-0.20030710.40
>>>>>>>>> Hi Mikhail,
>>>>>>>>> an rpm from redhat or do I need to down load the current 6.3
>>>>>>>>> version and use "make" to build it?
>>>>>>>>> Jerry
>>>>>>>>>>> CDT 3.0.0
>>>>>>>>>>> -Jerrry
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> under Eclipse. I was able to run/break/inspect variables etc
>>>>>>>>>>>> directly under GDB and DDD. I am a newbie to C/C++ to begin
>>>>>>>>>>>> with but have been using Eclipse fror Java for many years.
>>>>>>>>>>>> debugger and have Stop at main() on startup selected.
>>>>>>&g
Current Time: Tue Oct 28 03:28:00 EDT 2025
Powered by FUDForum. Page generated in 0.32870 seconds
