Re: Manipulate model from two or more editors [message #154244 is a reply to message #154210] |
Tue, 09 October 2007 07:34 |
Originally posted by: trommas.yahoo.com
Shared Editing domain is one possibility. There are lots of threads here
on that subject.
Tomas
Feng wrote:
> I have an Ecore model which has say 20 classes. I generate an editor
> based on GMF which touches about half of those classes. If I only want
> to edit these classes then I should be all set since GMF takes care of
> serialization and deserialization. However, I do need to manipulate all
> of the classes (including the ones maintained by GMF editor) in another
> UI form based editor. How should I do it? I was thinking connect both
> editors to the serialized XML file so that I don't need to modify GMF
> editor. But then I will have two memory representations of the same
> object, which will cause sync problem down the load and it's vastly
> inefficient. Any help appreciated.
FUDForum. Page generated in 0.03897 seconds
