Home » Modeling » GMF (Graphical Modeling Framework) » polyline connection color
polyline connection color [message #153373] Thu, 04 October 2007 04:52 Go to next message
Originally posted by: 14.08.99.gmx.de
I want to change the color of a polyline connection, but it doesn't work
the 2 ways I tried (wich I found in former posts of this ng):
- adding an "Foreground Color RGB Color" to the Figure Descriptor in the
*.gmfgraph
- adding the code snippet below to the <MyPolyline>ViewFactory-Class
LineStyle lineStyle = (LineStyle)
view.getStyle(NotationPackage.Literals.LINE_STYLE);
if (lineStyle != null) {
lineStyle.setLineColor(FigureUtilities.RGBToInteger(
new RGB(255, 0, 0)).intValue());
Maybe it's bcause I'm new ;)
I'm using Eclipse 3.3, GMF Europa 2.0.0.
Guido
Re: polyline connection color [message #153469 is a reply to message #153373] Thu, 04 October 2007 09:55 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
Hi Guido,
I tried the first way you described (and which I think that is better)
and it worked well.
Remember that after changing the gmfgraph file, you have to regenerate
the generatol model (gmfgen) and (later) regenerate the diagram code.
Hope this helps,
Jakub Jurkiewicz
http://eclipser-blog.blogspot.com/
Guido Schwab pisze:
> *.gmfgraph
> Regards,
> Guido
Re: polyline connection color [message #153492 is a reply to message #153469] Thu, 04 October 2007 10:51 Go to previous messageGo to next message
I regenerated both (gmfgen and diagram code).
I wonder about the background-thing, because this works the way I
expected it. But this doesn't change the color of the connection (junst
the decoration). So there has to be another problem with it.
This is the part of the gmfgraph:
<descriptors
name="MyPolylineConnectionFigure">
<actualFigure
xsi:type="gmfgraph:PolylineConnection"
<foregroundColor
xsi:type="gmfgraph:RGBColor"
red="255"/>
<targetDecoration
xsi:type="gmfgraph:PolylineDecoration"
href=" ../../../plugin/org.eclipse.gmf.graphdef/models/classDiagram .gmfgraph#//@figures.0/@figures.2 "/>
</actualFigure>
</descriptors>
I tried it without decoration but still no effect...
Guido
Re: polyline connection color [message #153751 is a reply to message #153373] Fri, 05 October 2007 07:33 Go to previous message
Solution:
"-c" as runtime-arg...
D'oh!
Previous Topic:Proper Way To Hook Into Event Model
Next Topic:how to add copy paste action to the context menu
Current Time: Sun Sep 14 05:16:44 EDT 2025
Powered by FUDForum. Page generated in 0.03637 seconds
