Home » Archived » BIRT » Getting parameters and setting them so report engine can render report
Getting parameters and setting them so report engine can render report [message #152385] |
Mon, 10 April 2006 18:41  |
So I have gathered my promptable parameters from my report and shown
them in a UI and gotten input from the user. I however I'm at a lost as
to what to do next.
heres my code
IReportRunnable report = reportEngine.openReportDesign(strReportPath);
ModuleHandle MH = eport.getDesignHandle().getModule().getModuleHandle();
List parameters = MH.getFlattenParameters()
//...process the parameter list in a UI
//HELP HERE.....I somehow have to get these parameters in My UI assigned
// so report engine will use them
IRunAndRenderTask task = reportEngine.createRunAndRenderTask(report);
// generate the report
task.run();
At the moment when I go to run I get the following
org.eclipse.birt.report.engine.api.EngineException: Some required
parameter values are not set or set to incompatible data type.
Whats the glue piece I need here to get my prompting parameters assigned
in a way the report task will work with?
Re: Getting parameters and setting them so report engine can render report [message #152412 is a reply to message #152385] |
Mon, 10 April 2006 22:25   |
Mike,
You have two options.
Use the task.setParmaeterValue(ParameterName, Value) Value is Object type
or
task.setParameterValues(parameterMap) /* just a map of name value pairs.
BTW you can use the engine api to retrieve the parameters as well.
I used the following two functions to print out all the parameter info
May be more than you want.
Jason
//info only method
public Hashtable getParameterDetails() throws Exception{
Hashtable parmDetails = new Hashtable();
try{
IGetParameterDefinitionTask task =
this.birtReportEngine.createGetParameterDefinitionTask(
this.currentBirtReport );
Collection params = task.getParameterDefns( true );
Iterator iter = params.iterator( );
while ( iter.hasNext( ) )
IParameterDefnBase param = (IParameterDefnBase) iter.next( );
if ( param instanceof IParameterGroupDefn )
IParameterGroupDefn group = (IParameterGroupDefn) param;
Iterator i2 = group.getContents( ).iterator( );
while ( i2.hasNext( ) )
IScalarParameterDefn scalar = (IScalarParameterDefn)
i2.next( );
//System.out.println("\t" + scalar.getName());
parmDetails.put( scalar.getName(), loadParameterDetails( task,
scalar, group));
else
IScalarParameterDefn scalar = (IScalarParameterDefn) param;
//System.out.println(param.getName());
parmDetails.put( scalar.getName(),loadParameterDetails( task,
scalar, null));
task.close();
} catch (Exception e1) {
logger.log( Level.SEVERE, e1.getMessage());
throw new Exception(e1);
return parmDetails;
private Hashtable loadParameterDetails(IGetParameterDefinitionTask task,
IScalarParameterDefn scalar, IParameterGroupDefn group) throws Exception{
Hashtable parameter = new Hashtable();
try{
if( group == null){
group = new ParameterGroupDefn();
if( scalar == null ){
scalar = new ScalarParameterDefn();
parameter.put("Parameter Group", checkIsNull(group.getName()));
parameter.put("Name", checkIsNull(scalar.getName()));
parameter.put("Help Text", checkIsNull(scalar.getHelpText()));
parameter.put("Display Name", checkIsNull(scalar.getDisplayName()));
//this is a format code such as > for UPPERCASE
parameter.put("Display Format", checkIsNull(scalar.getDisplayFormat()));
if( scalar.isHidden() ){
parameter.put("Hidden", "Yes");
}else{
parameter.put("Hidden", "No");
if( scalar.allowBlank() ){
parameter.put("Allow Blank", "Yes");
}else{
parameter.put("Allow Blank", "No");
if( scalar.allowNull() ){
parameter.put("Allow Null", "Yes");
}else{
parameter.put("Allow Null", "No");
if( scalar.isValueConcealed() ){
parameter.put("Conceal Entry", "Yes"); //ie passwords etc
}else{
parameter.put("Conceal Entry", "No");
switch (scalar.getControlType()) {
case IScalarParameterDefn.TEXT_BOX: parameter.put("Type", "Text Box");
break;
case IScalarParameterDefn.LIST_BOX: parameter.put("Type", "List Box");
break;
case IScalarParameterDefn.RADIO_BUTTON: parameter.put("Type", "Radio
Button"); break;
case IScalarParameterDefn.CHECK_BOX: parameter.put("Type", "Check Box");
break;
default: parameter.put("Type", "Text Box");break;
switch (scalar.getDataType()) {
case IScalarParameterDefn.TYPE_STRING: parameter.put("Data Type",
"String"); break;
case IScalarParameterDefn.TYPE_FLOAT: parameter.put("Data Type",
"Float"); break;
case IScalarParameterDefn.TYPE_DECIMAL: parameter.put("Data Type",
"Decimal"); break;
case IScalarParameterDefn.TYPE_DATE_TIME: parameter.put("Data Type",
"Date Time"); break;
case IScalarParameterDefn.TYPE_BOOLEAN: parameter.put("Data Type",
"Boolean"); break;
default: parameter.put("Data Type", "Any"); break;
//Get report design and find prompt text
ReportDesignHandle reportHandle = ( ReportDesignHandle )
this.currentBirtReport.getDesignHandle( );
ScalarParameterHandle parameterHandle = ( ScalarParameterHandle )
reportHandle.findParameter( scalar.getName() );
parameter.put("Default Value",
checkIsNull(parameterHandle.getDefaultValue()));
parameter.put("Prompt Text",
checkIsNull(parameterHandle.getPromptText()));
parameter.put("Data Set Expression",
checkIsNull(parameterHandle.getValueExpr()));
if(scalar.getControlType() != IScalarParameterDefn.TEXT_BOX)
//System.out.println("dynamic parameter");
if ( parameterHandle.getContainer( ) instanceof
CascadingParameterGroupHandle ){
Collection sList = Collections.EMPTY_LIST;
parameter.put("Cascaded Parameter", "Yes");
int index = parameterHandle.getContainerSlotHandle( )
.findPosn( parameterHandle );
parameter.put("Cascaded Parameter Index", new Integer(index));
if( index == 0 ){
Object[] keyValue = new Object[0];
String groupName = parameterHandle.getContainer( ).getName( );
task.evaluateQuery( groupName );
//selectionList = task.getSelectionListForCascadingGroup(
groupName, keyValue );
sList = task.getSelectionListForCascadingGroup( groupName,
keyValue );
Hashtable dynamicList = new Hashtable();
for ( Iterator sl = sList.iterator( ); sl.hasNext( ); )
IParameterSelectionChoice sI = (IParameterSelectionChoice)
sl.next( );
Object value = sI.getValue( );
Object label = sI.getLabel( );
//System.out.println( label + "--" + value);
//Display label unless null then display value. Value is the
what should get passed to the report.
dynamicList.put(sI.getValue().toString(),checkIsNull(label)) ;
parameter.put("Selection List", checkIsNull(dynamicList));
}else{
parameter.put("Cascaded Parameter", "No");
Collection selectionList = task.getSelectionList(
scalar.getName() );
if ( selectionList != null )
for ( Iterator sliter = selectionList.iterator( );
sliter.hasNext( ); )
IParameterSelectionChoice selectionItem =
(IParameterSelectionChoice) sliter.next( );
Object value = selectionItem.getValue( );
String label = selectionItem.getLabel( );
dynamicList.put(selectionItem.getValue( ).toString(),checkIsNull(label));
}else{
Iterator iter = parameter.keySet().iterator();
System.out.println("======================Parameter =" +
scalar.getName());
while (iter.hasNext()) {
String name = (String) iter.next();
if( name.equals("Selection List")){
Hashtable selList = (Hashtable)parameter.get(name);
Iterator selIter = selList.keySet().iterator();
while (selIter.hasNext()) {
Object lbl = selIter.next();
System.out.println( "Selection List Entry ===== Key = " + lbl + "
Value = " + selList.get(lbl));
}else{
System.out.println( name + " = " + parameter.get(name));
return parameter;
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:e1emvr$scd$1@utils.eclipse.org...
> So I have gathered my promptable parameters from my report and shown them
> in a UI and gotten input from the user. I however I'm at a lost as to what
> to do next.
> heres my code
> task.run();
Re: Getting parameters and setting them so report engine can render report [message #152591 is a reply to message #152412] |
Tue, 11 April 2006 11:52  |
Once again Thank you so much Jason.
Jason Weathersby wrote:
> Mike,
> or
> Jason
> //info only method
> try{
> i2.next( );
> scalar, group));
> else
> scalar, null));
> task.close();
> return parmDetails;
> try{
> if( group == null){
> }else{
> }else{
> }else{
> }else{
> break;
> break;
> Button"); break;
> break;
> "String"); break;
> "Float"); break;
> "Decimal"); break;
> "Boolean"); break;
> if( index == 0 ){
> keyValue );
> sl.next( );
> }else{
> scalar.getName() );
> }else{
> scalar.getName());
> }else{
> return parameter;
>>to do next.
>>heres my code
>>task.run();
Current Time: Tue Sep 16 10:03:16 EDT 2025
Powered by FUDForum. Page generated in 0.04352 seconds
