Calendar [message #151887] |
Fri, 07 April 2006 12:18 |
Originally posted by: ciolo.mat.uni.torun.pl
I would like to set-up a calendar control for the input Date parameter in
my BIRT report. Any ideas on how to do this ?
Re: Calendar [message #151923 is a reply to message #151887] |
Fri, 07 April 2006 13:42 |
Originally posted by: m.n.com
Is your application browser based? RCP based? ____ based?
Marcin Ciolo wrote:
> Hi
> in my BIRT report. Any ideas on how to do this ?
Re: Calendar [message #151938 is a reply to message #151933] |
Fri, 07 April 2006 14:09 |
Well, if you are using Java to do the UI, and more specifically JSF,
there is a JSF Calendar component.
Marcin Ciolo wrote:
> browser based
Re: Calendar [message #151941 is a reply to message #151938] |
Fri, 07 April 2006 14:21 |
Ok it's some solution, but i use to view report the Birt Report
viever(_frameset) and where i must put the jsf code(in wchich file),
because i don't know.
Re: Calendar [message #152018 is a reply to message #151941] |
Fri, 07 April 2006 16:08 |
Do you current have a web application? Something you are accessing the
reports from? If so, how did you develop it?
FUDForum. Page generated in 1.87192 seconds
