Can't build oomph [message #1517717] |
Fri, 19 December 2014 17:57 |
I wanted to build oomph and therefore cloned the repository, checked out on master branch and called mvn compile, but I get the following error:
Failed to execute goal org.eclipse.tycho:tycho-packaging-plugin:0.21.0:build-qualifier-aggregator (default-build-qualifier-aggregator) on project org.eclipse.oomph.gitbash: Execution default-build-qualifier-aggregator of goal org.eclipse.tycho:tycho-packaging-plugin:0.21.0:build-qualifier-aggregator failed: Project org.eclipse.oomph:org.eclipse.oomph.gitbash:eclipse-plugin:1.0.0-SNAPSHOT does not have expanded version -> [Help 1]
Can you please tell me what I am doing wrong?
Thanks in advacne
Cheers
Markus
Re: Can't build oomph [message #1518509 is a reply to message #1517717] |
Sat, 20 December 2014 04:47 |
Hi Markus,
I'm afraid I can only use Maven if it's working. I'm really not a Maven expert and we've never had problems like yours.
We call Maven locally with these parameters:
-Dbuild.id=Unknown
-Dgit.commit=Unknown
-Dgit.branch=Unknown
-DskipTests=true
-Denv=win64
clean
verify
Cheers
/Eike
http://www.esc-net.de
Am 19.12.2014 um 18:57 schrieb Markus Oley:
> version -> [Help 1]
> Thanks in advacne
> Cheers
> Markus
Cheers
/Eike
Re: Can't build oomph [message #1519435 is a reply to message #1518509] |
Sat, 20 December 2014 17:25 |
Hi Eike,
thanks for your answer, that was exactly the problem. I dind't know these parameters, so now it is working. If I want to contribute anything, can I send a pullrequest on the master branch or should I use another branch?
Cheers
Markus
Re: Can't build oomph [message #1520634 is a reply to message #1519435] |
Sun, 21 December 2014 09:39 |
Ed Merks Messages: 33264 Registered: July 2009 |
Markus,
Use Gerrit for contributions and keep in mind that commits are of the
form "[buzilla-id] ..." so open a bugzilla for tracking purposes.
On 20/12/2014 6:25 PM, Markus Oley wrote:
> Hi Eike,
> use another branch?
> Cheers
> Markus
Ed Merks
FUDForum. Page generated in 0.03751 seconds
