Buttons with no labels and toolbar with no icons [message #151656] |
Thu, 11 May 2006 15:46 |
Originally posted by: programmer.nashclan.net
I'm running eclipse 3.1.1 on my Dell Windows XP Pro machine with no problem.
I just got a new IBM (Lenovo) ThinkCentre, also with Windows XP Pro on it.
It came with the following JRE pre-installed:
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2)
Classic VM (build 1.4.2, J2RE 1.4.2 IBM Windows 32 build cn142-20040926 (JIT
enabled: jitc))
When I run Eclipse, the "Workspace Launcher" dialog has no text on the
buttons or the checkbox. If I choose the button that should say "OK", the
IDE opens up and all of the toolbar icons are black squares.
However, if instead I click "Browse" and choose a workspace directory (even
if its the same one), then the toolbar icons are fine.
I tried checking the "do not ask again" checkbox, and now my icons are
always blacked out.
Does anyone know why this is happening? Is there a workaround (other than
havening to change workspaces every time)? Do I need a different JRE?
Chris Nash
Re: Buttons with no labels and toolbar with no icons [message #151751 is a reply to message #151656] |
Thu, 11 May 2006 19:01 |
Originally posted by: jefmyers.us.ibm.com
This very weird problem sounds vaguely familiar. I'd suggest posting in
the eclipse.platform.swt newsgroup, as you're likely to get more
information from the SWT developers there. A screenshot if you can make
it would be helpful as well.
Hope this helps,
- Jeff
Re: Buttons with no labels and toolbar with no icons [message #151846 is a reply to message #151751] |
Thu, 11 May 2006 23:56 |
"Jeff Myers" <jefmyers@us.ibm.com> wrote in message
news:e401lm$fhk$1@utils.eclipse.org...
> Hope this helps,
> - Jeff
A google search turned up two other people with the same problem but no
answers. :(
I'll do as you suggest and post on the other group.
FUDForum. Page generated in 0.09503 seconds
