Home » Language IDEs » Java Development Tools (JDT) » Too large source ??
Too large source ?? [message #151495] Tue, 30 March 2004 03:26 Go to next message
Originally posted by: frode.halvorsen.hoco.no
I am testing som DCOM-bridge software (J-Integra), and did one of the
samples against Excel.
After importing the JAVA-classes into Eclipse, one of the generated classes
is too big :
The code for the static initializer is exceeding the 65535 bytes limit
When doing a manual javac on the same file it compiles fine.
Can this limit be set higfher to avoid this in eclipse ?
Frode Halvorsen
Re: Too large source ?? [message #151564 is a reply to message #151495] Tue, 30 March 2004 05:32 Go to previous messageGo to next message
Sorry this limit can be configured. But it means that we should optimize
your test case. Can you please open a bug report against JDT Core and attach
your test case? If you cannot attach the test case, can you describe in
details what the code in the static initializer looks like?
Jerome
"Frode Halvorsen" <frode.halvorsen@hoco.no> wrote in message
news:c4bamn$oq1$1@eclipse.org...
classes
> is too big :
> Frode Halvorsen
Re: Too large source ?? [message #151572 is a reply to message #151564] Tue, 30 March 2004 05:33 Go to previous messageGo to next message
Of course I meant: "this limit CANNOT be configured"
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:c4bi2o$3g0$1@eclipse.org...
attach
> Jerome
> classes
> > is too big :
> > Frode Halvorsen
Re: Too large source ?? [message #151596 is a reply to message #151495] Tue, 30 March 2004 09:01 Go to previous message
Originally posted by: olivier_thomannNO.ca.ibm.comSPAM
Le Tue, 30 Mar 2004 10:26:21 +0200, "Frode Halvorsen"
You might be really close to the 64K limit with javac and slightly
above with Eclipse compiler.
No. This is a VM limitation. Could you please open a bug report
against JDT/Core where you provide the source code in a zip file?
Then we should be able to tell you why javac compiles fine and not
Eclipse compiler.
Olivier
Previous Topic:Kudos on M8!
Next Topic:3.0M8 keeps asking for a workspace...
Current Time: Mon Sep 15 12:52:17 EDT 2025
Powered by FUDForum. Page generated in 0.03667 seconds
