Home » Language IDEs » C / C++ IDE (CDT) » Hacking error messages
Re: Hacking error messages [message #150180 is a reply to message #150073] |
Wed, 27 July 2005 21:33 |
Patrick Turley Messages: 43 Registered: July 2009 |
Member |
--------------050009000303020407060301
Actually - I was wrong. It's not too bad. For those of you who happen to
use Green Hills and Eclipse, the script is attached.
My understanding is that Green Hills is actually a bit hostile to
Eclipse. I'd be curious to know if there actually *is* anyone who uses
them together (besides me).
name="MyBuilder"
Content-Disposition: inline;
filename="MyBuilder"
# This script builds Green Hills projects and converts the messages to a form
# the Eclipse GCC error parser can recognize.
# The following excerpt comes from GCCErrorParser.java:
# // Known patterns.
# // (a)
# // filename:lineno: description
# // (b)
# // filename:lineno:column: description
# // (c)
# // In file included from b.h:2,
# // from a.h:3,
# // from hello.c:3:
# // c.h:2:15: missing ')' in macro parameter list
# // (d)
# // In file included from hello.c:3:
# // (e)
# // h.c: In function `main':
# // h.c:41: `foo' undeclared (first use in this function)
# // h.c:41: (Each undeclared identifier is reported only once
# // h.c:41: for each function it appears in.)
# // h.c:41: parse error before `char'
# // h.c:75: `p' undeclared (first use in this function)
# From what little experience I've had with the Green Hills C compiler, it
# introduces messages with a line of the following format:
# <file>, line <line>: <type> #<ID>: <message>
# Where:
# <type> is "error" or "warning" or something.
# <ID> is an identifier for the given message.
# Example:
# "main.c", line 42: error #69-D: stupid mistake
# The Green Hills programs seem to wrap long error messages to following lines.
# For example:
# "main.c", line 42: error #69-D: This is a long explanation
# of the stupid mistake you made.
# stupid ?= mistake;
# It appears that the only way you can find the end of the message is to look
# for the line that contains nothing but white space and the caret (^). That
# line, and the previous line are not actually part of the message.
# Global Variables
# Usage.
Usage="$0 [<GHArgs> ... ]"
# The path to the GHS gbuild command.
GHSBuilder='C:/GHS/arm407/gbuild.exe'
# This is the master pattern output lines that introduce a message.
# \1: File
# \2: Line number
# \3: Message type
# \4: Message ID
# \5: Message
MasterPattern='^"\([^"][^"]*\)", line \([0-9][0-9]*\): \([a-z][a-z]*\) #\([^:][^:]*\): \(.*\)$'
# Build, and pipe the output to sed.
${GHSBuilder} $@ 2>&1 |\
sed -n -e "
# Check if this line introduces a message. If not, print this line and move
# on to the next.
/${MasterPattern}/!{
p
b
# If control arrives here, this line is a message. Copy this line to the
# hold space.
h
# The current line is safely tucked away in the hold space. We now want to
# accumulate lines until we find one that contains nothing but white space
# and a caret.
:Accumulate
# Get the next line and append it to the hold space. Note that this
# inserts a newline character, which will be handy later.
n
H
# If the current line contains nothing but white space and a caret,
# we're done accumulating.
/^[ ]*^[ ]*/b FinishedAccumulating
# Go back for more.
b Accumulate
:FinishedAccumulating
# When control arrives here, we've finished accumulating everything in the
# hold space. We can now start pulling stuff back out. Copy the hold space
# to the pattern space.
g
# Remove the source code and caret lines from the pattern space.
s/\(.*\)\n.*\n.*/\1/
# Remove all newlines.
s/\n//g
# Remove redundant spaces.
s/ */ /g
# Reformat this message to GCC pattern (a).
s/${MasterPattern}/\1:\2: \5/g
# Print the re-formatted message. Eclipse should be able to recognize this.
p
# We don't want to throw away the source code and caret lines. Retrieve the
# hold space again.
g
# Remove all but the source code and caret lines from the pattern space.
s/.*\n\(.*\n.*\)/\1/
# Print the source code and caret lines.
p
--------------050009000303020407060301--
Re: Hacking error messages [message #150249 is a reply to message #150180] |
Thu, 28 July 2005 22:01 |
Member |
--------------020203040002080902000401
A greatly improved version.
name="MyBuilder"
# // (a)
# // (b)
# // (c)
# // from a.h:3,
# // (d)
# // (e)
# Also, if the GCC parser sees a message description that begins with the word
# "Warning" or "warning", it will remove that word from the message and create a
# warning marker. Otherwise, it will create an error marker.
# Where:
# Example:
# For example:
# line and the previous line are not actually part of the message.
# From what little experience I've had with the Green Hills linker, it
# [elxr] (<type>) <description>
# Where:
# Example:
# [elxr] (error) symbol frob.borz.bix multiply defined in
# plen.o
# garsh.o
# Global Variables
# Usage.
GHSBuilder='C:/GHS/arm407/gbuild.exe -noreasons'
# This is the pattern for output lines that introduce compiler messages.
# \1: File
# \2: Line number
# \3: Message type
# \4: Message ID
# \5: Message
CompilerMasterPattern='^"\([^"][^"]*\)", line \([0-9][0-9]*\): \([a-z ][a-z ]*\) #\([^:][^:]*\): \(.*\)$'
CompilerWarningPattern='^"\([^"][^"]*\)", line \([0-9][0-9]*\): warning #\([^:][^:]*\): \(.*\)$'
# This is the pattern for output lines that introduce linker messages.
# \1: Message type
# \2: Message
LinkerPattern='^\[elxr\] (\([a-z ][a-z ]*\)) \(.*\)$'
# Banners.
CompilerWarningBanner='i\
==== Compiler Warning ================================================\
CompilerErrorBanner='i\
==== Compiler Error ==================================================\
LinkerErrorBanner='i\
==== Linker Error ====================================================\
# Build and pipe the result to sed.
tr -d '\r' |\
sed -n -e "
# Check if this line introduces a compiler message.
/${CompilerMasterPattern}/{
# hold space.
h
# to accumulate lines until we find one that contains nothing but white
# space and a caret.
:CompilerAccumulate
n
H
/^[ ]*^[ ]*\$/b CompilerDone
# Go back for more.
b CompilerAccumulate
:CompilerDone
# the hold space. We can now start pulling stuff back out. Copy the hold
# space to the pattern space.
g
s/\n//g
s/ */ /g
# Figure out what kind of message this is.
/${CompilerWarningPattern}/{
# If control arrives here, this is a warning message. Print the
# corresponding banner.
${CompilerWarningBanner}
# Reformat this message and insert "warning" at the beginning of the
# description. The GCC error parser will remove the string and
# create a warning marker.
s/${CompilerMasterPattern}/\1:\2: warning \5/
# Branch off and print the message.
b PrintCompilerMessage
# Reformat the message.
${CompilerErrorBanner}
s/${CompilerMasterPattern}/\1:\2: \5/
# Control arrives here when we're ready to print the compiler message.
:PrintCompilerMessage
# this.
p
# the hold space again.
g
p
# Go back for more.
b
# Check if this line introduces a linker message.
/${LinkerPattern}/{
# Control arrives here if another linker message terminated the previous
# one.
: AnotherLinkerMessage
# hold space.
h
# to accumulate lines until we find something that terminates this
# message.
:LinkerAccumulate
# Get the next line.
n
# Two things will terminate a linker message:
# 1) Another linker message.
# 2) A blank line.
/${LinkerPattern}/b LinkerDone
/^[ ]*\$/b LinkerDone
# If control arrives here, this line belongs to the message we've
# already started. Append it to the hold space. Note that this
H
# Go back for more.
b LinkerAccumulate
:LinkerDone
# the hold space. We can now start pulling stuff back out. Swap the hold
# and pattern space. We swap, instead of just copying the hold space to
# the pattern space, because the pattern space may now actually hold the
# first part of the next linker message.
x
# Print the message.
${LinkerErrorBanner}
p
# Swap the hold and pattern space again.
x
# Now, the pattern space contains the line that terminated the current
# message. If it's a blank line, then go back to scanning messages.
/^[ ]*/b
# If control arrives here, we have the first line of another linker
# message in the pattern space. Go back to process it.
b AnotherLinkerMessage
# If control arrives here, this line is not part of a message. Print it and
# go back for more.
p
--------------020203040002080902000401--
Current Time: Sun Oct 06 10:31:44 GMT 2024
Powered by FUDForum. Page generated in 0.03704 seconds
