Home » Eclipse Projects » GEF » notification and refreshVisuals
notification and refreshVisuals [message #149645] Wed, 01 September 2004 20:20 Go to next message
Originally posted by: david_michonneau.hotmail.com
What is the recommended approach to handle numerous model notifications in
GEF? For instance if I get 10 notifications on a model element, I would like
to avoid the overhead of calling refreshVisuals 10 times.
Looking at the way the repaint optimization is done, I was thinking of doing
something similar for refreshVisuals: have a DeferredRefreshManager mark
EditParts as dirty when their refreshVisuals is called. Then I could extend
the DeferredUpdateManager to call the RefreshManager before painting so that
all EditParts are refreshed, but only once per EditPart. Is that a good
approach or is there a better way to do it?
David
Re: notification and refreshVisuals [message #149665 is a reply to message #149645] Wed, 01 September 2004 20:53 Go to previous messageGo to next message
You could handle the notifications more intelligently and call
refreshLabel(), refreshIcon(), etc. Have you identified any performance
problems?
You could create a refresh manager. Just be aware that stale
editparts/figures are more dangerous than stale pixels on the screen. You
need to make sure all notifications use this manager, and you may need to
preserve order for some types of notifications, such as removing a child and
adding it to a new parent.
"David Michonneau" <david_michonneau@hotmail.com> wrote in message
news:ch5anr$r9o$1@eclipse.org...
like
doing
extend
that
> David
Re: notification and refreshVisuals [message #149672 is a reply to message #149665] Wed, 01 September 2004 21:21 Go to previous messageGo to next message
Actually I haven't identified any performance problem, but we are creating
the notification design now, and it is a concern that we have. Do you
believe there will be no performance issue at all, based on your experience
with GEF?
Handling the notifications more intelligently seems a good solution, but I'm
afraid it will generate a huge amount of code and code paths.
David
"Randy Hudson" <none@us.ibm.com> wrote in message
news:ch5cm1$uae$1@eclipse.org...
> problems?
and
> > Hi,
in
> like
> doing
> extend
> that
> > Thanks,
> > David
Re: notification and refreshVisuals [message #149680 is a reply to message #149672] Wed, 01 September 2004 23:31 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
It's usually not an issue. Having the simple optimizations is usually
enough:
1) The set methods in your model should ensure that something is indeed
being changed before firing notification.
2) The listener in your edit part should invoke refreshVisuals() or
refreshChildren() only if it's a property that can affect the look or the
layout, resp.
3) Your figure or refreshVisuals() should call repaint only if a visual
property has changed.
news:ch5eb0$1jo$1@eclipse.org...
experience
> with GEF?
I'm
> David
> > problems?
You
to
> and
> > > Hi,
notifications
> in
would
> > like
> > doing
mark
> > extend
so
> > that
good
> > > Thanks,
> > > David
Re: notification and refreshVisuals [message #149723 is a reply to message #149672] Thu, 02 September 2004 17:30 Go to previous message
The only performance concern I I have seen is to avoid calling
refreshChildren() all the time, especially in tree Editparts. Instead, call
addChild(...) and removeChild(...) as appropriate. This is the difference
of O(n) and O(1) times the number of children changing.
experience
> with GEF?
I'm
> David
Previous Topic:Painting order of figure and its children
Next Topic:paint optimization
Current Time: Wed Feb 05 15:54:56 GMT 2025
Powered by FUDForum. Page generated in 0.78181 seconds
