Home » Eclipse Projects » GEF » KeyListeners in ClassDiagram Using Draw2d
KeyListeners in ClassDiagram Using Draw2d [message #147685] |
Mon, 16 August 2004 06:47 |
Originally posted by: mazharshaikh.iopsis.com
I have created a class diagram using the Reference article mentioned
in GEF. I also added the functionality of Grabhandle and Dragging of
ClassDiagram using connection, decorations and etc using Draw2d API. Its all
working fine.
Now i want to add the Functionality as follows ::
1) When I create a classdiagram through grabhandle and others ... So i
needed a functionality that will allow me to select multiple classdiagram
when pressed Key of "CONTROL" and i can drag all the selected classdiagram.
2) Since all the classdiagrams are visible..so if we go on creating many
classdiagrams using grabhandle.. it shows many classdiagrams with
connections and all others.
So i need a functionality that will allow me to Hide the classDiagram , when
another class diagram is created through grabhandle. And when clicked on
View all it should display all classdiagrams .. otherwise only the created
classdiagram should be visible, rest all hidden.
Re: KeyListeners in ClassDiagram Using Draw2d [message #147707 is a reply to message #147685] |
Mon, 16 August 2004 14:24 |
"Mazhar" <mazharshaikh@iopsis.com> wrote in message
news:cfpkte$i3m$1@eclipse.org...
> Hello,
mentioned
all
> working fine.
classdiagram.
These functions are available in the GEF plug-in. Why don't you just use
GEF instead of re-implement it?
Re: KeyListeners in ClassDiagram Using Draw2d [message #147841 is a reply to message #147707] |
Tue, 17 August 2004 05:20 |
I m not getting the exact exmples to search for ...
Is there any option through Draw2d ??
can u provide any direction or sample to do in Draw2d or GEF ??
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cfqfu1$vdt$1@eclipse.org...
> > Hello,
> mentioned
> all
> > working fine.
classdiagram
> classdiagram.
Re: KeyListeners in ClassDiagram Using Draw2d [message #147881 is a reply to message #147841] |
Tue, 17 August 2004 13:56 |
The example is avialable from the download page.
http://download.eclipse.org/tools/gef/downloads/drops/R-3.0- 200406251257/index.php
news:cfs480$a01$1@eclipse.org...
> Hello,
> > > Hello,
> > mentioned
Its
> > all
> > > working fine.
> classdiagram
> > classdiagram.
use
Re: KeyListeners in ClassDiagram Using Draw2d [message #148182 is a reply to message #147881] |
Thu, 19 August 2004 09:41 |
But i have the requirement to do the coding in Draw2d API .. I have created
the classDiagram with the help of Draw2d API and added the functionality of
Dragging and Grabhandle ...Now I want the functionality of the following..
1) Keylistener when Pressed "CONTROL" and multiple classdiagrams r selected
with CONTROL should only be dragged .
2) Window Select features on the classdiagram.
can u provide any sample or direction of how to proceed ??
news:cft2kv$rh0$1@eclipse.org...
> > Hello,
> > > > Hello,
> > > mentioned
> Its
> > > all
> > > > working fine.
i
> > classdiagram
> > > classdiagram.
> use
Re: KeyListeners in ClassDiagram Using Draw2d [message #148207 is a reply to message #148182] |
Thu, 19 August 2004 13:45 |
news:cg1s8n$b6p$1@eclipse.org...
> Hello,
created
of
selected
> can u provide direction of how to proceed ??
Yes, you go back to the people who made the draw2d requirement and tell them
you need to use GEF also.
Re: KeyListeners in ClassDiagram Using Draw2d [message #148303 is a reply to message #148207] |
Mon, 23 August 2004 06:51 |
Yes, Know i will use GEF for the functionality of Window select and Hiding
of class Digram ..
So do i did to re-implement my full code of ClassDiagram using Draw2d API
into GEF .. or any other solution is there ??
Can u provide me any sample or direction of how to proceed further ??
news:cg2ap2$3pn$1@eclipse.org...
> > Hello,
> created
> of
following..
> selected
them
Re: KeyListeners in ClassDiagram Using Draw2d [message #148411 is a reply to message #148397] |
Tue, 24 August 2004 12:43 |
Originally posted by: gaslade.yahoo.com
I you trawl through this newsgroup you will find numerous postings
regarding examples and where to find them..... it will take you 5 mins
to do this.
Guy
Mazhar wrote:
> Hello,
> I have check this site. I have also checked the examples of GEF but
> it is difficult to understand the full code.
> Can u provide any ONE example in GEF that will help me to draw the
> classdigram and put the required functionality of Dragging, Key Select and
> Window Select using GEF ??
> news:cgdhev$edj$1@eclipse.org...
>> http://www-106.ibm.com/developerworks/opensource/library/os- gef/
>>news:cgc3ot$r52$1@eclipse.org...
>>>Hello,
> Hiding
>>>of class Digram ..
> API
Re: KeyListeners in ClassDiagram Using Draw2d [message #148506 is a reply to message #148411] |
Wed, 25 August 2004 05:12 |
Hello Sir,
I have checked the newsgroup, I wanted the perfect example of
classdiagram Using GEF ... I have implemented the whole code Using draw2d
and now i wanted it using GEF ..
Can u provide me any samples or directions regarding the above question...
"Guy Slade" <gaslade@yahoo.com> wrote in message
news:cgfd0b$4k5$1@eclipse.org...
> to do this.
> Guy
> Mazhar wrote:
> > Hello,
but
and
> >>>Hello,
> > Hiding
> >>>of class Digram ..
> > API
Re: KeyListeners in ClassDiagram Using Draw2d [message #148629 is a reply to message #148506] |
Wed, 25 August 2004 15:31 |
Pratik Shah Messages: 1077 Registered: July 2009 |
There's no example of conversion from Draw2D to GEF, if that's what you
mean. But it shouldn't be too difficult to figure out once you understand
how GEF works and the MVC pattern it employs. You should be able to reuse
chunks of your code (esp. the Model and some, if not most, of the View).
Start out by reading some documentation (Redbook?) and then look at the code
of a simple example: the new shapes example in the repository.
news:cgh6o0$tna$1@eclipse.org...
> Hello Sir,
of
> > to do this.
> > Guy
> > Mazhar wrote:
> > > Hello,
GEF
> but
> and
> > >>>Hello,
> > > Hiding
> > >>>of class Digram ..
> > > API
Re: KeyListeners in ClassDiagram Using Draw2d [message #148701 is a reply to message #148629] |
Thu, 26 August 2004 05:58 |
Can u provide any one example on GEF which has the Functinality of
"Dragging' , "Window Select" and "Hiding of Diagrams" .. I have checked the
examples of Logic and Flow but the code is difficult to understand ...
Can u provide any sample or direction ??
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cgib7h$uog$1@eclipse.org...
code
> > Hello Sir,
> of
draw2d
question...
> > > to do this.
> > > Guy
> > > Mazhar wrote:
> > > > Hello,
> GEF
> > but
Select
> > and
> > > >>>Hello,
> > > > Hiding
> > > >>>of class Digram ..
Draw2d
> > > > API
Re: KeyListeners in ClassDiagram Using Draw2d [message #148734 is a reply to message #148701] |
Thu, 26 August 2004 15:21 |
Dragging: org.eclipse.gef.examples.shapes example is available on the GEF
CVS repository. To find out how you can connect to the respository, look at
the FAQ on your website. Code to start looking at: getDragTracker() for
EditParts.
I am not sure what you mean by "Window Select."
Hiding of Diagrams: You can hide items on the palette (which is also a GEF
viewer) via the customize dialog. Set a breakpoint in
DefaultEntryPage#handleHiddenSelected and follow the trail to see how it
does this.
news:cgjtqg$769$1@eclipse.org...
> Hello,
the
understand
reuse
> code
> > > Hello Sir,
example
> > of
> draw2d
> question...
mins
> > > > to do this.
> > > > Guy
> > > > Mazhar wrote:
> > > > > Hello,
of
> > GEF
> > > but
> Select
> > > and
> > > > >>>Hello,
and
> > > > > Hiding
> > > > >>>of class Digram ..
> Draw2d
> > > > > API
further
Re: KeyListeners in ClassDiagram Using Draw2d [message #148894 is a reply to message #148734] |
Mon, 30 August 2004 05:27 |
"Window Select" Functionality means that when we drag the mouse over
some area or the diagram and the figures that are selected ..
Can u provide the example of classDiagram with GEF ??
news:cgkuv6$593$1@eclipse.org...
at
> EditParts.
> does this.
> > Hello,
> the
you
> understand
> reuse
View).
the
> > code
> > > > Hello Sir,
> example
> > > of
> > draw2d
> > question...
> mins
> > > > > to do this.
> > > > > Guy
> > > > > Mazhar wrote:
> > > > > > Hello,
examples
> of
> > > GEF
> > > > but
the
> > Select
> > > > and
> > > > > >>>Hello,
> and
> > > > > > Hiding
> > > > > >>>of class Digram ..
> > Draw2d
> > > > > > API
> further
Re: KeyListeners in ClassDiagram Using Draw2d [message #148949 is a reply to message #148894] |
Mon, 30 August 2004 13:54 |
....... I think we have exhaustively established there there is no
example of classDiagram with GEF!
It's difficult to tell from your incomplete description but it sounds
like you are talking about the marquee selection when you talk about
Window Select. Take another look at the logic example, it uses marquee
selection.... you can point and click somewhere on the free form surface
and then, holding the mouse button down, drag the mouse over an area.
Objects in this area are selected.
Guy
Mazhar wrote:
> Hello,
> at
>>EditParts.
>>does this.
>>>Hello,
>>the
> you
>>understand
>>reuse
> View).
> the
>>>code
>>>>>Hello Sir,
>>example
>>>>of
>>>draw2d
>>>question...
>>mins
>>>>>>to do this.
>>>>>>Guy
>>>>>>Mazhar wrote:
>>>>>>>Hello,
> examples
>>of
>>>>GEF
>>>>>but
> the
>>>Select
>>>>>and
>>>>>>>>>Hello,
>>and
>>>>>>>Hiding
>>>>>>>>>of class Digram ..
>>>Draw2d
>>>>>>>API
>>further
Re: KeyListeners in ClassDiagram Using Draw2d [message #149049 is a reply to message #148949] |
Mon, 30 August 2004 17:06 |
Or, is he talking about changing z-order on select? Who knows, but asking
the right question (the right way) get's you a lot better answers.
> Guy
Re: KeyListeners in ClassDiagram Using Draw2d [message #149143 is a reply to message #149049] |
Tue, 31 August 2004 09:17 |
Originally posted by: amitsaxena.iopsis.com
hello,
Yes, exactly that i wanted .. is there any seperate example for the marquee
in gef .. but it is difficult to understand the whole code of Logic Any
seperate exmple is available ??.
Secondly, i wanted a right click menu on any Object (i.e Figures) and
contains menus of Hide & View ..
So that i can Hide and View all Figures or Objects.
Can u provide any examples or directions ??
news:cgvml0$q1k$1@eclipse.org...
> > Guy
Re: KeyListeners in ClassDiagram Using Draw2d [message #149515 is a reply to message #149143] |
Tue, 31 August 2004 21:13 |
There is a new simple example available in CVS. See the FAQ for loading
code from CVS.
It will be in a build some time next week.
"Amit Saxena" <amitsaxena@iopsis.com> wrote in message
news:ch1fah$e43$1@eclipse.org...
> hello,
marquee
surface
asking
> > > Guy
Current Time: Wed Feb 05 15:45:11 GMT 2025
Powered by FUDForum. Page generated in 0.05641 seconds
