Home » Modeling » GMF (Graphical Modeling Framework) » ContributionItemService problem
ContributionItemService problem [message #146551] |
Tue, 14 August 2007 15:43 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: zzhangh.cn.ibm.com
I want to add an editor action to my gmf editor and I found
contributionItemProviders extension point can be used for this purpose.
However I tried to mimic logic example without success, the
"CustomContributionItemProvider" class's createTool() method was never get
called and of course no editor action showed up.
I listed the plugin.xml fragment below, anyone can give some suggestion?
<extension
id="contribution1"
name="contribution1"
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
class="com.my.CustomContributionItemProvider">
<Priority
name="Low">
</Priority>
<partContribution
class="com.ibm.crl.bo.rule.diagram.part.RuleDiagramEditor">
<partAction
id="exampleAction"
menubarPath="/file/print"
toolbarPath="/">
</partAction>
</partContribution>
</contributionItemProvider>
</extension>
Hao
Re: ContributionItemService problem [message #150288 is a reply to message #149079] |
Wed, 12 September 2007 07:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Cherie,
My current situation is, I can contribute items from generated xxx.diagram
plugin, as logic and taipan examples did, but I can't contribute any item
in an outer plugin project, say xxx.diagram.custom which I created by
myself and depends xxx.diagram project. And I found no example for this
situation, yet I do need this because my actions has been defined in the
xxx.diagram.custom project and I don't want to modify much codes in
The other fact is if I implement IContributionItemProvider directly rather
than inherit AbstractContributionItemProvider, the
contributeToActionBars() method can get called when editor opens, so I
guess likely there is some logic in AbstractContributionItemProvider not
suitable for contributionItemProvider defined in outer plugin.. I'm trying
to locate..
Cherie Revells wrote:
> Hao,
> Did you get this working yet?
> Regards,
> Cherie
> Hao Zhang wrote:
>> Hi,
>> get called and of course no editor action showed up.
>> <extension
>> id="contribution1"
>> <Priority
>> name="Low">
>> </Priority>
>> <partContribution
>> <partAction
>> id="exampleAction"
>> toolbarPath="/">
>> </partAction>
>> </partContribution>
>> </extension>
>> Regards,
>> Hao
Re: ContributionItemService problem [message #150315 is a reply to message #150288] |
Wed, 12 September 2007 08:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Axel Guckelsberger![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=info%40guite.de) Messages: 354 Registered: July 2009 |
Hi Hao,
I am facing exactly the same situation: I want to add a new action to
menubar and toolbar, but defined within an external plugin.
I also wonder at which point the visual aspects are defined (i.e. the
toolbar icon).
Please let us know if you cope with this problem.
Hao Zhang schrieb:
> Hi Cherie,
> xxx.diagram plugin, as logic and taipan examples did, but I can't
> contribute any item in an outer plugin project, say xxx.diagram.custom
> which I created by myself and depends xxx.diagram project. And I found
> no example for this situation, yet I do need this because my actions has
> been defined in the xxx.diagram.custom project and I don't want to
> modify much codes in xxx.diagram project.
> rather than inherit AbstractContributionItemProvider, the
> trying to locate..
>> Hao,
>> Regards,
>> Cherie
>> Hao Zhang wrote:
>>> Hi,
>>> purpose. However I tried to mimic logic example without success, the
>>> never get called and of course no editor action showed up.
>>> <extension
>>> id="contribution1"
>>> <Priority
>>> name="Low">
>>> </Priority>
>>> <partContribution
>>> <partAction
>>> id="exampleAction"
>>> toolbarPath="/">
>>> </partAction>
>>> </partContribution>
>>> </extension>
>>> Regards,
>>> Hao
Re: ContributionItemService problem [message #150887 is a reply to message #150315] |
Sun, 16 September 2007 06:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hao Zhang![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bjzhanghao%4021cn.com) Messages: 161 Registered: July 2009 |
Axel,
Cherie helped me out, the key is to add
checkPluginLoaded="false"
in my contribution item provider extension, hope this also helps for you.
Hao
"Axel Guckelsberger" <info@guite.de>
??????:fc86tl$auq$1@build.eclipse.org...
> Hi Hao,
> toolbar icon).
> Hao Zhang schrieb:
>> Hi Cherie,
>> trying to locate..
>>> Hao,
>>> Regards,
>>> Cherie
>>> Hao Zhang wrote:
>>>> Hi,
>>>> suggestion?
>>>> <extension
>>>> id="contribution1"
>>>> <Priority
>>>> name="Low">
>>>> </Priority>
>>>> <partContribution
>>>> <partAction
>>>> id="exampleAction"
>>>> toolbarPath="/">
>>>> </partAction>
>>>> </partContribution>
>>>> </extension>
>>>> Regards,
>>>> Hao
Re: ContributionItemService problem [message #150898 is a reply to message #150887] |
Sun, 16 September 2007 09:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hao,
I solved it by overriding the ActionBarAdvisor XPand template.
Hao Zhang schrieb:
> Axel,
> Regards,
> Hao
>> Hi Hao,
>> toolbar icon).
>> Hao Zhang schrieb:
>>> Hi Cherie,
>>> trying to locate..
>>>> Hao,
>>>> Regards,
>>>> Cherie
>>>> Hao Zhang wrote:
>>>>> Hi,
>>>>> suggestion?
>>>>> <extension
>>>>> id="contribution1"
>>>>> <Priority
>>>>> name="Low">
>>>>> </Priority>
>>>>> <partContribution
>>>>> <partAction
>>>>> id="exampleAction"
>>>>> toolbarPath="/">
>>>>> </partAction>
>>>>> </partContribution>
>>>>> </extension>
>>>>> Regards,
>>>>> Hao
Current Time: Sat Aug 17 19:26:58 GMT 2024
Powered by FUDForum. Page generated in 0.03932 seconds
