Home » Eclipse Projects » GEF » setting Z-order/depth-order of figures
setting Z-order/depth-order of figures [message #148309] Mon, 23 August 2004 11:58 Go to next message
Bernd Kolb is currently offline Bernd KolbFriend
Member
If one figure (e.g label) lies inside another figure (only due to the
physical coordinates) which figure is selected
when mouse click is clicked at location b?
Does the z-order depends on the creation order of the editparts hence
figures?
Is there a possibility to manually change or set or specify the z-order of
the figures?
| a | b | |
Actual situation is as follows:
model A is container for model B & the figure of model B should be rendered
inside figure of model A
but i still want to select model B when clicked.
Best Regards.
Re: setting Z-order/depth-order of figures [message #148312 is a reply to message #148309] Mon, 23 August 2004 13:55 Go to previous messageGo to next message
Originally posted by: word-up.gmx.de
I don't know how to manipulate the "z-order", but you won't have any
problems in your actual situation.
If model A contains model B, then the edit part for A should be the father
of the edit part of B.
regards,
Max
Bernd Kolb wrote:
> figures?
> the figures?
> | a | b | |
> Best Regards.
Re: setting Z-order/depth-order of figures [message #148350 is a reply to message #148309] Mon, 23 August 2004 19:44 Go to previous messageGo to next message
The editparts should be contained too. Children will always be on top of
their parent.
"Bernd Kolb" <b.kolb@kolbware.de> wrote in message
news:cgcm05$s9m$1@eclipse.org...
> figures?
> the figures?
> | a | b | |
rendered
> Best Regards.
Re: setting Z-order/depth-order of figures [message #148403 is a reply to message #148350] Tue, 24 August 2004 12:35 Go to previous messageGo to next message
Member
Model A is container for mobel B
As recommended by you, I should add editpart B to edit part A aswell,
to have the same heirarchy in the editparts as in the models.
Now here is the question.
while instantiating a new model B should it only be added to the
list of children in Model A
OR should it be added to the main contents list
(EditPartViewer::SetContents(..contents..));
From what i Understand
If the model B was added to the main contents then the editpartfactory will
create the edit part for it
during refreshChildren() and then the new edit part will be added to
RootEditpart
(and Not to the parent edit part that is Edit Part A)
If the model B was added to the list of children in model A we have to
manually create an edit part for it
add it to the EditPart A and then add the information to EditPartRegistry
But, in the next refreshChildren(). The model for the EditPart B will not be
found in the
main Contents and so it will be deleted.
So what do I do?
"Randy Hudson" <none@us.ibm.com> schrieb im Newsbeitrag
news:cgdh97$e5h$1@eclipse.org...
> their parent.
> > Hi,
> > figures?
of
> > the figures?
> > | a | b | |
> rendered
> > Best Regards.
Re: setting Z-order/depth-order of figures [message #148418 is a reply to message #148403] Tue, 24 August 2004 14:21 Go to previous messageGo to next message
No, editpart A should be listening for changes in it children property.
when it changes, it should call refreshchildren on itself, which results in
getModleChildren() being called on itself, and B getting created and added
to A. It does *not* involve the viewer, contents, or root.
news:cgfcgf$3to$1@eclipse.org...
will
> RootEditpart
be
> found in the
> So what do I do?
> Regards
of
> > their parent.
> > > Hi,
> > > figures?
z-order
> of
> > > the figures?
> > > | a | b | |
> > rendered
> > > Best Regards.
Re: setting Z-order/depth-order of figures [message #148433 is a reply to message #148403] Tue, 24 August 2004 15:07 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
It should be added as a child of A.
will
> RootEditpart
That is correct.
Not true. This will be done for you just like you described above (if model
B was a child of the main contents).
be
> found in the
> So what do I do?
The correct way is to have Model A's EditPart's getModelChildren() method
return a list that includes model B. Then an EditPart will be created for
it, and won't be removed until model B is no longer a child of A.
> Regards
of
> > their parent.
> > > Hi,
> > > figures?
z-order
> of
> > > the figures?
> > > | a | b | |
> > rendered
> > > Best Regards.
Re: setting Z-order/depth-order of figures [message #148552 is a reply to message #148433] Wed, 25 August 2004 13:17 Go to previous messageGo to next message
Member
Thank you for your replies.
Should Figure of EditPart B also be added to Figure of EditPart A?
Regards.
Re: setting Z-order/depth-order of figures [message #148598 is a reply to message #148552] Wed, 25 August 2004 14:27 Go to previous message
Yes, this happens automatically in addChild(EditPart, index), which calls
addChildVisual().
news:cgi3b8$ee4$1@eclipse.org...
> Regards.
Previous Topic:help--Is there a sample WYSIWYG text editor based on GEF available?
Next Topic:Global summary view
Current Time: Wed Feb 05 16:01:00 GMT 2025
Powered by FUDForum. Page generated in 0.04119 seconds
