"Processing Dirty Regions" error on WTP 0.7.1 [message #144895] |
Fri, 21 October 2005 21:19 |
Originally posted by: glen.db.verizon.net
Hello, running either 0.7.0 or 0.7.1 (using the all-in-one downloads for
both these versions of WTP) both give me a popup error "An internal
error occurred during: 'Processing Dirty Regions'" whenever I edit an
XML file. What version of WTP do I need to fix this (0.6 does not have
this error, but I would like something more recent.)
Also, is there a convenient way to search this newsgroup--the newsgroup
archives do not appear to have a search function.
Glen
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #147575 is a reply to message #144895] |
Thu, 17 November 2005 19:52 |
You might want to check your workspace's .metadata/.log file for the
full stack trace. It might help to explain why the error is
occurring or at least give you a starting point for opening a bug.
I suggest you check 1.0M8 or the upcoming 1.0M9 to see if the
problem is still happening.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: "Processing Dirty Regions" error on WTP 0.7.1 [message #148364 is a reply to message #148254] |
Tue, 22 November 2005 20:38 |
Eric Celerse wrote:
> Hello,
> I have tried the 1.0M9 and it's the same problem.
> Here is my workspace's .metadata/.log file (in the attached file.).
Do you have a version of Xerces in your jre/lib/ext folder or
another org.apache.xerces plugin installed?
- Nitin
_
Nitin Dahyabhai
FUDForum. Page generated in 0.03527 seconds
