spring and birt [message #146487] |
Tue, 21 March 2006 14:01 |
Originally posted by: mishra.vaibhav.gmail.com
Instead of accessing the database directly using jdbc datasources, I want
to use some java api. I tried the samples related to scripted datasource
using POJOs.
Now, the problem is that my application uses spring, and the objects can
not be instantiated directly. Instead they have to be accessed through the
web application context like -
WebApplicationContext ctx =
WebApplicationContextUtils.getRequiredWebApplicationContext( servletContext);
return ctx.getBean(name);
If I could get servletContext somehow in BIRT, this could be used.
However, I could not find the way to do this.
So, I tried another way which does not requires ServletContext -
ClassPathXmlApplicationContext appContext = new
ClassPathXmlApplicationContext(
new String[] { "/WEB-INF/web.xml",
"/WEB-INF/applicationContext.xml",
"/WEB-INF/applicationContext-hibernate.xml" });
BeanFactory factory = (BeanFactory) appContext;
return factory.getBean(name);
The problem is now that when I run the report, BIRT is unable to parse the
web.xml and the cause of exception is -
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT
exception occurred: Error evaluating Javascript expression. Script engine
error: Wrapped
org.springframework.beans.factory.BeanDefinitionStoreExcepti on:
IOException parsing XML document from class path resource
[WEB-INF/web.xml]; nested exception is java.net.ConnectException:
Connection timed out: connect (DataSet[Data Set].__bm_OPEN#2)
Can anyone suggest something why I am getting this connection timeout?
My web.xml contains following lines in the beginning -
<!DOCTYPE web-app PUBLIC
"-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app xmlns="http://java.sun.com/xml/ns/j2ee"
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd" version="2.4">
Vaibhav
Re: spring and birt [message #146703 is a reply to message #146497] |
Wed, 22 March 2006 06:04 |
I am able to get servletContext through the way suggested by you, and
hence the classes which are available through servlet context. Thanks.
Now, I am getting following exception (it says '50 more' at last so I am
unable to determine the cause.
I have following code written in DataSet's methods:
open() [this is working fine]
sampleBean = Packages.sample.ApplicationContext.getBean("sampleBean",
reportContext.getHttpServletRequest().getSession().getServle tContext());
accounts = sampleBean.getAllAccounts();
iter = accounts.iterator();
count=0;
fetch() [I guess there is something wrong with this]
if(!iter.hasNext()) {
return null;
var node = iter.next();
row["username"] = node.getUsername();
row["firstName"] = node.getFirstName();
row["lastName"] = node.getLastName();
row["email"] = node.getEmail();
row["phone"] = node.getPhone();
row["department"] = node.getDepartment();
count++;
return row;
Following is the stack trace as printed on the browser
Error0 : Error.UnhandledScriptError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Unhandled
exception when executing script at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:210)
at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:200)
at
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 119)
at
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRuntime.java:84)
at
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:217)
at
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:135)
at
org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:85)
at
org.eclipse.birt.data.engine.executor.cache.SmartCache.popul ateData(SmartCache.java:276)
at
org.eclipse.birt.data.engine.executor.cache.SmartCache.initI nstance(SmartCache.java:204)
at
org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:134)
at
org.eclipse.birt.data.engine.executor.CachedResultSet.initOd iResultSet(CachedResultSet.java:1613)
at
org.eclipse.birt.data.engine.executor.CachedResultSet.pass(C achedResultSet.java:1432)
at
org.eclipse.birt.data.engine.executor.CachedResultSet.popula teResultSet(CachedResultSet.java:234)
at
org.eclipse.birt.data.engine.executor.CachedResultSet.<init >(CachedResultSet.java:125)
at
org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.java:83)
at
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :183)
at
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.exe cute(PreparedQuery.java:711)
at
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:110)
at
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:210)
at
org.eclipse.birt.report.engine.executor.QueryItemExecutor.op enResultSet(QueryItemExecutor.java:62)
at
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:122)
at
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:187)
at
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:69)
at
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
at
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
at
org.eclipse.birt.report.services.ReportEngineService.runAndR enderReport(Unknown
Source) at
org.eclipse.birt.report.viewer.aggregation.layout.EngineFrag ment.doService(Unknown
Source) at
org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source) at
org.eclipse.birt.report.viewer.servlet.ViewerServlet.doGet(U nknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:697) at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:810) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
at
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:81)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
at
org.jboss.web.tomcat.security.CustomPrincipalValve.invoke(Cu stomPrincipalValve.java:39)
at
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:153)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(A uthenticatorBase.java:407)
at
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:59)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:856)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:744)
at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
at
org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(Maste rSlaveWorkerThread.java:112)
at java.lang.Thread.run(Thread.java:595)Caused by:
data.engine.BadFetchScriptReturnType at
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 109)
... 50 more
Re: spring and birt [message #146730 is a reply to message #146703] |
Wed, 22 March 2006 07:21 |
Hey, I solved the problem. It was due to wrong return statement in fetch
method.
Now, I correct it as -
return false;
node = iter.next();
return true;
FUDForum. Page generated in 0.09371 seconds
