Subversive browsing [message #146048] |
Sat, 01 April 2006 11:33 |
Originally posted by: hansm.science.uva.nlDELETE
I have installed subversion and the subversive plugin (1.0.0.M8), but did not
succeed in browsing to a repository on my local disks.
Choosing from SVN Repository Exploring "New Repository Location" I was not able
to reach my repository in /usr/local/svn/project.
Using button "Browse" for the field "Root URL" gives only the message "< There
is an error occured while accessing the repository entry >" The dialog message
says "Select a remote resource location".
Manually filling in the Root URL with (all sorts of variations from)
http://localhost/path did not work either. I could reach no further than a
repository search leading to error message "No part of path ... was found in
repository HEAD".
Typing solely: Root URL = "http:" gives the eclipse directory as "not under
version control".
Trying "file:path" shows the message "malformed URL: unknown protocol file'.
So, I have been unable to reach my (local) repository on disk.
I hope someone can point me in the right direction.
Your help will be appreciated.
Hans van der Meer
Re: Subversive browsing [message #146154 is a reply to message #146048] |
Sun, 02 April 2006 16:51 |
> repository HEAD".
> version control".
> Hans van der Meer
I will be interested if you get this working, as I would rather use
subversion than cvs... anyway, here is my €0,02:
The easiest way I found to use subversion was to use the subversion
protocol (ie, urls like svn://localhost/myProject) having started the
server with svnserve.
In other words, if you type the following:
svnserve -d -r /usr/local/svn
to start the server, the URL to access your project will be:
svn://localhost/project
Please let us/me know if you have any luck!
Martin
Re: Subversive browsing [message #146163 is a reply to message #146154] |
Sun, 02 April 2006 17:09 |
In article <e0oveu$unq$1@utils.eclipse.org>,
> > not
FUDForum. Page generated in 0.11115 seconds
