CVS problem [message #144887] |
Thu, 16 October 2003 14:23 |
Originally posted by: bidon.email.com
I just installed CVS 1.11.9 on a Linux RedHat 8.0 server. I want to access
the repository from a Windows PC.
When I create a new project (cvs ... import ...) in the repository with
WinCVS, all works fine. When I try to do that with Eclipse (Team > Share
Project ...), I get the message :
Module XXX already exists remotely. Would you like to synchronize your
local project
with the existing remote module ?
The module doesn't exist remotely !
If I answer No to the question I return to the CVS wizard. Nothing appens.
If I answer Yes then select the tag HEAD to synchronize with, all seems to
work fine. But if I try to refresh the Eclipse CVS view, nothing appear. If
I look at the CVS repository, none of my project directories have been
created.
Another problem : I can't see, with Eclipse, the projects already present in
my repository.
Does anybody have an idea of the source of these problems ?
How can I see which cvs command Eclipse sends ?
AR
Re: CVS problem [message #145762 is a reply to message #144887] |
Fri, 17 October 2003 14:17 |
Originally posted by: Michael_Valenta.oti.com
What Eclipse ebuild are you using? If you are usin a recent 3.0 build,
there is a CVS preference for displaying the communications trace to the
console. You must start Eclipse using java.exe and the -consolelog
-debug flags as well. If you're using a 2.x build, then the CVS FAQ
describes how to see the trace
( http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-vcm-home/docs/online/cvs_features2.0/cvs-faq.html#misc_ 0).
Michael
ar wrote:
> Hello,
> local project
> created.
> my repository.
> Thanks
> AR
Re: CVS problem [message #145819 is a reply to message #144887] |
Fri, 17 October 2003 14:38 |
Chris Watson Messages: 2 Registered: July 2009 |
AR,
I had the same problem as you did. I could get into projects I already
defined, but the CVS Repository view would not show my modules or files.
I just recently upgraded to CVS 1.11.9 and the newest version of Eclipse 3.0
and discovered that the two were incompatible. Since I wanted the most
recent Eclipse, I tried installing a back version of CVS to get it to work.
When re-installed, CVS 1.11.6, everything seemed to work and all my modules
re-appeared in my CVS Repository view.
Chris
"ar" <bidon@email.com> wrote in message news:bmm9fs$n6i$1@eclipse.org...
> Hello,
> local project
If
> created.
in
> my repository.
> Thanks
> AR
Re: CVS problem [message #146201 is a reply to message #145819] |
Sat, 18 October 2003 14:16 |
Originally posted by: daniel.megert.gmx.net
Chris Watson wrote:
>AR,
Please file a bug report if you didn't already do so.
Dani
>Chris
>>Hello,
>>local project
>If
>>created.
>in
>>my repository.
>>Thanks
>>AR
Re: CVS problem [message #146393 is a reply to message #145762] |
Mon, 20 October 2003 07:43 |
Hello Michael,
I use 2 versions of Eclipse => 2.0 and 2.1.
I activated debug as described in the FAQ. Here is the result :
Root /u/cvs/projects
CMD> cvs version
version
M Concurrent Versions System (CVS) 1.11.9 (client/server)
ok
RESULT> Status OKorg.eclipse.team.cvs.core code=0 ok null
CMD> cvs version
version
ok
I LOVE YOU
Valid-responses ok error M E Checked-in Valid-requests Template Set-sticky
Clear
-static-directory Module-expansion Set-static-directory Clear-sticky
New-entry R
emoved Merged Remove-entry Updated Update-existing Copy-file Notified
Created Mo
d-time
valid-requests
Valid-requests Root Valid-responses valid-requests Repository Directory
Max-dotd
ot Static-directory Sticky Entry Kopt Checkin-time Modified Is-modified
UseUncha
nged Unchanged Notify Questionable Case Argument Argumentx Global_option
Gzip-st
ream wrapper-sendme-rcsOptions Set Gssapi-authenticate expand-modules ci co
upda
te diff log rlog add remove update-patches gzip-file-contents status rdiff
tag r
tag import admin export history release watch-on watch-off watch-add
watch-remov
e watchers editors init annotate rannotate noop version
ok
CMD> cvs -n update -d ""
Global_option -n
Argument -d
Directory .
/u/cvs/projects/TestDebug
Argument .
Directory .
update
E cvs update: Updating .
E cvs update: cannot open directory /u/cvs/projects/TestDebug: No such file
or d
irectory
E cvs update: skipping directory
ok
RESULT> Status ERRORorg.eclipse.team.cvs.core code=1 The following warnings
were
reported while performing the "cvs update" command. null children=[Status
ERROR
org.eclipse.team.cvs.core code=-14 cvs update: Updating . null Status
ERRORorg.e
clipse.team.cvs.core code=-14 cvs update: cannot open directory
/u/cvs/projects/E
ssaiDebug: No such file or directory null Status
code=-14 cvs update: skipping directory null]
Is there anything to do now ?
Alain
"Michael Valenta" <Michael_Valenta@oti.com> a
FUDForum. Page generated in 0.04027 seconds
