Home » Eclipse Projects » GEF » GEF 3.0 Installed but not in my plug-in list?
Re: GEF 3.0 Installed but not in my plug-in list? [message #145651 is a reply to message #145632] |
Fri, 30 July 2004 09:12 |
Originally posted by: yogender.globalworldtech.com
Download the gef plugin first and then extract it ur in eclipse directory
try this
window->Preferences-Plug-in-Developemnt->TargetPlatform->Reload
remember the location should be the eclipse/plugin .
Then Restart the eclipse
Steve Jones wrote:
> I've downloaded and installed the GEF 3.0 plugin using
> Help->Software_Updates, without any problems.
> I can see the plugins & features in my eclipse-3.0/features and
> eclipse-3.0/plugins folders, and Eclipse says they are enabled.
> When I list the plugins using Windows->Show_View->Plugins, the GEF plugin(s)
> are not listed.
> Additionally the GEF examples I'm trying to build cannot resolve their GEF
> plugin dependency.
> I'm new to eclipse and know I must be doing something wrong.
> Any hints would be very wellcome.
> Thanks, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145668 is a reply to message #145659] |
Fri, 30 July 2004 09:55 |
Dwnload the GEF3.0. Its ZIP file and then extract it. If you have done
this then go to
help->software update->Manage Configuration
there u can see the file under eclipse platform.
When u click the file u will see gef installed ,right click over that and
make it enable
try this may be it can help u
yogender
Steve Jones wrote:
> Yogender wrote:
> > Hi
> I'm not sure what you mean by "extract it".
> I'm using the eaclipse default workspace.
> > try this
> When I do this the dialogues location edit input is set to the default
> "/local/apps/eclipse-3.0", and when I rescan I just get the default plugins
> (84 of them) even though the sub-directories ./plugins and ./features
> contain the standard plugins as well as the down loaded GEF plugins.
> > Steve Jones wrote:
> >> Hi,
> >> plugin(s) are not listed.
> >> GEF plugin dependency.
> >> Thanks, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #145880 is a reply to message #145632] |
Mon, 02 August 2004 06:38 |
Steve Jones Messages: 95 Registered: July 2009 |
Member |
Steve Jones wrote:
Hi, me again.
Having failed to get GEF working using Help->Software_Updates, I've now
deleted all the GEF elements from my plugins & features folders.
From the site:
http://download.eclipse.org/tools/gef/downloads/drops/R-3.0- 200406251257/index.php
I've downloaded all the GEF zip files.
Having unzipped:
GEF-runtime-3.0.zip
GEF-examples-3.0.zip
I restart eclipse and enable the GEF plugins using Help->Software
Update->Manage Configuration.
If I now restart eclipse, guess what, the GEF plugins are in my plugin list,
and the GEF logic example is no longer reporting a dependency problem.
This was not the case when I downloaded the plugins directly using the
"official" Help->Software_Updates method.
I'm new the eclipse so I will not investigate what's different when using
Help->Software_Updates but something is definitely amiss.
Onward and upward.
Cheers, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #149240 is a reply to message #145880] |
Tue, 31 August 2004 17:00 |
Originally posted by: bgrieder.NOSPAMquadrem.com
Steve,
Same thing happened to me: I am running a Eclipse 3.0 (same behaviour
with 3.1M1) on Linux GTK2.
I removed manually the folders downloaded using the Update features,
downloaded the zip and extracted them manually. It fixed the issue too.
I have downloaded other plugins and they do not seem to have the same
issue. This sounds GEF specific to me.
Cheers
Steve Jones wrote:
> Steve Jones wrote:
>>Hi,
> Hi, me again.
> From the site:
> Having unzipped:
> GEF-runtime-3.0.zip
> Onward and upward.
> Cheers, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #149598 is a reply to message #149240] |
Wed, 01 September 2004 15:13 |
Pratik Shah Messages: 1077 Registered: July 2009 |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71823
This should be fixed in the latest integration build. If you have an older
Eclipse build, you can just delete those META-INF folders in the different
plug-ins.
"Grieder Bruno" <bgrieder@NOSPAMquadrem.com> wrote in message
news:ch2akj$3b2$2@eclipse.org...
> Steve,
> Cheers
> Steve Jones wrote:
> > Steve Jones wrote:
> >>Hi,
> > Hi, me again.
> > From the site:
> > Having unzipped:
> > GEF-runtime-3.0.zip
list,
using
> > Onward and upward.
> > Cheers, Steve.
Re: GEF 3.0 Installed but not in my plug-in list? [message #149607 is a reply to message #149598] |
Wed, 01 September 2004 15:36 |
Thanks.
> plug-ins.
>>Steve,
>>Cheers
>>Steve Jones wrote:
>>>Steve Jones wrote:
>>>>Hi,
>>>Hi, me again.
>>>From the site:
>>>Having unzipped:
>>>GEF-runtime-3.0.zip
> list,
> using
>>>Onward and upward.
>>>Cheers, Steve.
Current Time: Wed Feb 05 04:37:39 GMT 2025
Powered by FUDForum. Page generated in 0.03586 seconds
