Home » Eclipse Projects » e(fx)clipse » Persistence of part state(@PersistState has no effect ?)
Persistence of part state [message #1444008] Mon, 13 October 2014 14:29 Go to next message
Thomas Elskens is currently offline Thomas ElskensFriend
I'm trying (all day already...) to get the ui-persistence of a part to work.
public class StructuresPart
	private static final String KEY_TEXTFIELD = "input_text" ;
	private TextField field = new TextField();
	@PostConstruct
	public void postConstruct(MPart part, GridPane parent)
		Map<String, String> state = part.getPersistedState() ;
		field.setText(state.getOrDefault(KEY_TEXTFIELD, "Aucun texte sauvegardé"));
		parent.add(field, 1, 0);
	@PersistState
	private void persistState(MPart part)
		Map<String,String> state = part.getPersistedState() ;
		state.put(KEY_TEXTFIELD, "Petit test...") ;
On restarting the application, the part state never contains any value for my key ?
I've not forgotten to :
  • remove the "-clearPersistentState" argument
  • make sure the clear checkbox in the launch configuration properties is unchecked.
Any other things to check ... ? Some special dependencies to add ... ?
Thomas
Re: Persistence of part state [message #1444054 is a reply to message #1444008] Mon, 13 October 2014 15:22 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Yep there's something odd going on - File a bug I've already started
investigating why this fails!
Tom
On 13.10.14 16:29, Thomas Elskens wrote:
> Hello,
> work.
> public class StructuresPart {
> @PostConstruct
> public void postConstruct(MPart part, GridPane parent) {
> sauvegardé"));
> @PersistState
> for my key ?
> unchecked.
> Thomas
Re: Persistence of part state [message #1444064 is a reply to message #1444054] Mon, 13 October 2014 15:34 Go to previous messageGo to next message
Filed myself https://bugs.eclipse.org/bugs/show_bug.cgi?id=446933 - Fix
to follow in a few minutes!
Tom
> Tom
>> Hello,
>> work.
>> @PostConstruct
>> sauvegardé"));
>> @PersistState
>> for my key ?
>> unchecked.
>> Thomas
Re: Persistence of part state [message #1444073 is a reply to message #1444054] Mon, 13 October 2014 15:44 Go to previous messageGo to next message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=446935
Re: Persistence of part state [message #1444074 is a reply to message #1444064] Mon, 13 October 2014 15:44 Go to previous messageGo to next message
Fixed and new build has been published - it now works in my test.e4 app.
Tom
> Tom
>> Tom
>>> Hello,
>>> work.
>>> @PostConstruct
>>> sauvegardé"));
>>> @PersistState
>>> for my key ?
>>> unchecked.
>>> Thomas
Re: Persistence of part state [message #1444078 is a reply to message #1444073] Mon, 13 October 2014 15:49 Go to previous messageGo to next message
The fix as so easy that I filed myself and fixed already. We saved the
file to disk before shuting down the workbench, I only had to flip 2
lines :-(
Tom
Re: Persistence of part state [message #1444787 is a reply to message #1444078] Tue, 14 October 2014 14:55 Go to previous message
Perfect it works nicely now.
Many thanks !
Thomas
Previous Topic:Fixed versions update site?
Next Topic:Drag and drop
Current Time: Wed Feb 05 18:02:59 GMT 2025
Powered by FUDForum. Page generated in 0.04153 seconds
