Re: Dynamic Parameter in BIRT 2.0RC [message #143612 is a reply to message #105678] |
Mon, 13 March 2006 20:59 |
Originally posted by: David.Peterson.mtvnmix.com
This has happened to me twice. The first time I just copied the report
over, deleted all of the datasets and started over recreating them and
didn't run into it. This time, I'm trying to find a workaround.
"Melissa Crist" <melcri@comcast.net> wrote in message
news:dpmnr4$sr9$1@utils.eclipse.org...
>I am trying to modify an existing report parameter and make it a dynamic
>parameter, so that I can populate a list of values based on who is running
>the report. However, when I click the Dynamic radio button in the Edit
>Parameter dialog, there are no entries in the "Data set" list. I already
>have 2 data sets defined to the report, and the same problem happens even
>if I try to create a new data set with the "Create new" button on the Edit
>Parameter dialog.
> Any ideas?
Re: Dynamic Parameter in BIRT 2.0RC [message #143619 is a reply to message #105678] |
Mon, 13 March 2006 21:01 |
It also gives the error on my previously created dynamic parameters: There
is no column avialble (sic).
If anyone has seen this before.
>Parameter dialog.
> Any ideas?
Re: Dynamic Parameter in BIRT 2.0RC [message #143833 is a reply to message #105678] |
Tue, 14 March 2006 21:28 |
Okay, I'm still not certain why this happens periodically, but the fix is to
delete the Dataset that the dynamic parameter depends upon. You'll get a
warning that it has a parameter dependency, but just okay and ignore that.
Go back to the parameter, edit, and create a new dataset setting it up again
as before.
FUDForum. Page generated in 0.03613 seconds
