Home » Language IDEs » Java Development Tools (JDT) » Problem by resolving typs by HalloWorld(typ handling problem)
Problem by resolving typs by HalloWorld [message #1434763] Tue, 30 September 2014 15:00 Go to next message
Franz Raaber is currently offline Franz RaaberFriend
After mine starting with Java, did I have by the Realisation of "HelloWorld.java" treyed to realise "HelloWorldSWT". But this Windows Version of HelloWorld [
public class HelloWorldSWT {
// TODO Auto-generated method stub
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("Hello world!");
shell.open();
while(!shell.isDisposed()) {
if(!display.readAndDispatch())
display.sleep();
display.dispose();
] didn't be compiled or interpreted in mine sense.
I get in the line "Display display = new Display();" the message/errore "Display can not resolved to a type", and in the "Shell shell = new Shell(display);"-line the errore "Shell shell = new Shell(display);" in the similar way!
What do I've to do? What is wrong?
I think and thought that the problem the missing definition of the variables "Display" and "Shell" is, but is that realy the fact, by the reason that I found these code on a book and a popluar web-page?
Cu
Franz Sad
Re: Problem by resolving typs by HalloWorld [message #1435055 is a reply to message #1434763] Wed, 01 October 2014 01:04 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
Most likely you need to add the swt.jars in your projects build path.
Tom
> public static void main(String[] args) {
> shell.open();
> display.sleep();
> display.dispose();
> Cu
> Franz :(
Previous Topic:eclipse error
Next Topic:jzy3d Setup in Eclipse Tips
Current Time: Fri Dec 27 02:28:48 GMT 2024
Powered by FUDForum. Page generated in 0.04170 seconds
