Re: Testing External App. using AGR [message #143408 is a reply to message #143388] |
Thu, 23 July 2009 11:03 |
Originally posted by: rahulghai84.gmail.com
Hey Paul,
You said target application should be an Eclipse
application.
Does it means that target application must be developed in eclipse IDE
environment?
Rahul Ghai
Re: Testing External App. using AGR [message #143481 is a reply to message #143396] |
Mon, 27 July 2009 11:46 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Gopal,
You can use the AGR to record and playback tests in an external Eclipse
applcaition assuming the AGR and its dependencies are installed in the
external Eclipse applcaition. For more information, see:
http://www.eclipse.org/tptp/test/documents/gettingstarted/Au tomated_GUI_Recorder_Getting_Started.html#2.0
Note, in TPTP 4.5, the AGR was moved from a Technology Preview component to
an As-Is component. As-Is components are primarily provided for prior users
but imply no support (for example, defects, news group, and mailing lists).
Paul
"Gopal " <gopal.pagrut@gemalto.com> wrote in message
news:49765787196f16d97b920494cc91f444$1@www.eclipse.org...
> Hi Paul,
> Thanks for ur reply.
> I have a some doubts.
> 1)Can u please explain little bit more about, how can we test external
> eclipse application using AGR?
> 2)Can u please explore ur point saying When recording, ensure the AGR is
> installed in the Eclipse instance launching the target application?
> Regards
> Gopal
Re: Testing External App. using AGR [message #143490 is a reply to message #143408] |
Mon, 27 July 2009 11:50 |
Hi Rahul ,
Yes. The target application must be an Eclipse application. That is, an
IDE environment, as opposed to an Eclipse RCP or stand-alone SWT
application. For more information, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=114159
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-5-0.html#3.0
Paul
"Rahul Ghai" <rahulghai84@gmail.com> wrote in message
news:0ca5617bff04ea6c5fe2e488019c61ee$1@www.eclipse.org...
> Hey Paul,
> application.
> environment?
> Regards
> Rahul Ghai
Re: Testing External App. using AGR [message #143500 is a reply to message #143474] |
Mon, 27 July 2009 11:52 |
Hi Gopal,
Yes. You need to install TPTP/AGR and its dependencies (e.g. EMF/XSD) in
the
external Eclipse application before recording/playback. For more
information, see:
Paul
news:7941a665eaeb7d978cd7dee1a750ae5e$1@www.eclipse.org...
> Dear Sir,
> Thanks for ur last reply.
> I downloaded TPTP all-in-one Package. Then downloaded AGR and installed in
> the TPTP all-in-one Package.
> I have an eclipse application that I want to test in the downloaded TPTP
> all-in-one Package
> I have some doubts.
> 1)Can u please explain little bit more about, how can I test external
> eclipse
> a) How can I specify the path of the external eclipse application?
> b) Can u please explore ur point saying When recording, ensure the AGR is
> c) Any other setting that I need to test the external eclipse application
> in TPTP all-in-one Package.
> Or
> 2) Does it like that, I need to install TPTP in my eclipse application and
> then need to install AGR in my application? (Then only I able to test my
> eclipse application using AGR)
> Regards
> Gopal
FUDForum. Page generated in 0.04186 seconds
