Saving (& Reloading) the ViewPort location [message #143040] |
Fri, 16 July 2004 19:44 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: brian.fernandes.codito.com
Hi Guys,
I'm trying to save the viewport location in my diagram - so if you edit and
close your diagram, if you start at the same location the next time you edit
the same diagram.
Saving it is a piece of cake -
calling this method in my editor seems to give me the right location of the
scrollbars.
((FigureCanvas)((ScrollingGraphicalViewer)getGraphicalViewer ()).getControl()
).getViewport().getViewLocation();
However, I dont' know when / where to set the scrollbar location using
).getViewport().setViewLocation(viewLocation);
on reload.
I cannot set it at after loading my model , becuase nothing has been drawn
yet - the viewport does not have it's final dimensions.
Seems rather simple - but I couldn't figure out where to call
setViewLocation after loading up a new editor.
Should I do this when the editPart of the last model is activated ?
I got it working to an extent by overriding GraphicalEditor#setFocus - I'm
sure there is a better place than this.
There was another issue with this, even though the diagram loads up with the
correct location, after losing focus, the editor scrolls back to (0,0) ?
Any suggestions appreciated,
Brian.
Re: Saving (& Reloading) the ViewPort location [message #145981 is a reply to message #143040] |
Mon, 02 August 2004 16:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Pratik Shah![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ppshah%40us.ibm.com) Messages: 1077 Registered: July 2009 |
Another possible way to do this is by adding a RangeModelListener. The
listener will be notified when the range model changes to be big enough to
fit the diagram and you could set the view location then (and remove the
listener once you are done). Of course, you'll get several notifications,
so you'll just have to ignore the ones that don't make sense (for instance,
if the max is less than the value you want to set). Where to add the
listener is your call.
"Brian Fernandes" <brian.fernandes@codito.com> wrote in message
news:cd9aoi$if8$1@eclipse.org...
> Hi Guys,
and
edit
> the same diagram.
the
> scrollbars.
> on reload.
the
> Brian.
FUDForum. Page generated in 0.04101 seconds
