Home » Modeling » EMF » Using JFace data binding with an EMF List which maby be null
Using JFace data binding with an EMF List which maby be null [message #1429804] Tue, 23 September 2014 15:41 Go to next message
I am using JFace data binding to bind an EMF list to another observable list. The problem I'm having (I think) is that the list is null before any items are added. Is there an easy way to do the databinding so that it creates the list when the first element is being added to it? Is there a way to null out the list when the last item is removed?
Thanks in advance for any help.
Re: Using JFace data binding with an EMF List which maby be null [message #1429855 is a reply to message #1429804] Tue, 23 September 2014 16:56 Go to previous messageGo to next message
El 23/09/2014 21:41, Justin Weir escribió:
EMF generated code will make sure the list is not null when you access it.
Do you want to decrease footprint or get your databinding working? :)
Felix
Re: Using JFace data binding with an EMF List which maby be null [message #1430125 is a reply to message #1429804] Wed, 24 September 2014 00:06 Go to previous message
Justin,
Comments below.
On 23/09/2014 9:41 PM, Justin Weir wrote:
I doubt that's a problem. The getter for a multi-valued feature always
returns a list. Internally, the field will be null until the first time
the getter is called, but no one can see that via the API...
How is the list accessed that anyone would ever see null?
No, because you can't ever know who else has asked for the list and is
still referencing it. The list itself is the state of the model instance.
Previous Topic:[CDO] cast error from string to cdoid
Next Topic:Missing class in CDOExplorer
Current Time: Wed Mar 12 00:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.03606 seconds
