Problem during meta-data refresh [message #1385374] |
Thu, 05 June 2014 19:51  |
With Juno, we are able to create build artifacts, but we try with Kepler 4.3, then we get this exception:
Problem during meta-data refresh: No component named _feature_gov.nasa.arc.spife is known to Buckminster
org.eclipse.buckminster.core.metadata.MissingComponentException: No component named _feature_gov.nasa.arc.spife is known to Buckminster
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath(LocalResolver.java:179)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath(LocalResolver.java:185)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.refreshProject(MetadataSynchronizer.java:295)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.workspaceCatchUp(MetadataSynchronizer.java:394)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$WorkspaceCatchUpJob.run(MetadataSynchronizer.java:185)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Has anyone experienced this issue with Kepler?
Re: Problem during meta-data refresh [message #1385390 is a reply to message #1385374] |
Fri, 06 June 2014 02:11   |
> at
> at
> at
> at
> at
OK, I see you opened another thread, so I'll answer here as well :)
do you get this error in the IDE or during the headless build? Are you
using Buckminster for Kepler?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Problem during meta-data refresh [message #1409392 is a reply to message #1408551] |
Sun, 17 August 2014 21:56  |
Glad that helped in your case!
I still have cases where I run into the same "No component named <foo> is known to Buckminster" problem and don't know what the issue is. The plug-ins in question are clearly part of the target platform, but there is no logging from Buckminster which would help me pin this down. If I get time I will try to debug it...
FUDForum. Page generated in 0.03761 seconds
