GenModel Doc in Ecore Diagram Editor [message #139266] |
Mon, 27 July 2009 15:57 |
Originally posted by: formatzeh.gmx.de
I want to know for what this option is good for in the properties view
of the Ecore Diagram Editor? I'm asking because I want to add some
documentation to the metaclasses in my metamodel. I thought that this
options is good for this as the name suggests it. But when I start the
second Eclipse instance with the generated editor I can't see my text in
that field on the elements being instances of the metaclass where I
added the documentation. So for what is it good for?
regards
Gilbert
Re: GenModel Doc in Ecore Diagram Editor [message #139303 is a reply to message #139291] |
Mon, 27 July 2009 17:13 |
Ed Merks wrote:
> Gilbert,
> I think you need to change Suppress GenModel Annotations to false.
Ok I did it. And where do I see the documenting text of the metaclass in
the second eclipse instance containing the generated editor?
Re: GenModel Doc in Ecore Diagram Editor [message #369108 is a reply to message #369100] |
Tue, 28 July 2009 16:06 |
Jacques LESCOT wrote:
> If you wish to customize the message shown in the bottom status bar of
> the generated tree structure editor when you select an attribute in the
> Properties View, you can perform that in the *.genmodel file, through
> the "Property description" field when you have selected a Feature.
Thanks Jacques, this is a beginning :)
Re: GenModel Doc in Ecore Diagram Editor [message #621260 is a reply to message #139266] |
Mon, 27 July 2009 16:38 |
Ed Merks Messages: 33188 Registered: July 2009 |
Gilbert,
> regards
> Gilbert
Ed Merks
Re: GenModel Doc in Ecore Diagram Editor [message #621262 is a reply to message #139291] |
Ed Merks wrote:
> Gilbert,
Re: GenModel Doc in Ecore Diagram Editor [message #621277 is a reply to message #369100] |
FUDForum. Page generated in 0.04155 seconds
