DND on text editor [message #139120] |
Mon, 21 June 2004 16:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: turker.keskinpala.vanderbilt.edu
Hi all,
I am working on a plugin where I need to drag from a graphical editor and
drop onto a regular editor where my source code is. I know it is possible to
drop onto a graphical editor but I am not sure if it is possible to drop
onto a regular editor.
Is this possible? If yes, what would be the way to go for that?
Turker Keskinpala
Re: DND on text editor [message #139144 is a reply to message #139120] |
Mon, 21 June 2004 18:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
It is possible, but it conflicts with normal interaction of the graphical
editor. You could require a modifier key like CTRL to be pressed?
"Turker Keskinpala" <turker.keskinpala@vanderbilt.edu> wrote in message
news:cb72be$2jg$1@eclipse.org...
> Hi all,
to
> Turker Keskinpala
Re: DND on text editor [message #139154 is a reply to message #139144] |
Mon, 21 June 2004 18:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thank you for your quick reply. It can require CTRL to be pressed.
I guess where I am having problem understanding is that how it will be
possible to add a listener to the java editor. May be I should just extend
the original java editor and create my own editor???
Do I just add the listener to an editor like adding a listener to a
graphical editor?
I am confused because most of the articles that I read refer to viewers and
graphical editors.
I appreciate your help...Thanks...
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cb78pm$hbn$1@eclipse.org...
> > Hi all,
and
possible
> to
> > Thanks,
> > Turker Keskinpala
Re: DND on text editor [message #139163 is a reply to message #139154] |
Mon, 21 June 2004 20:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I was referring to the "drag from graphical" part. Drop on Text editor
would require an extension point. It may not exist.
news:cb796q$icd$1@eclipse.org...
> graphical editor?
and
> graphical editors.
graphical
> > > Hi all,
> and
> possible
> > to
drop
> > > Thanks,
> > > Turker Keskinpala
FUDForum. Page generated in 0.04045 seconds
