Home » Language IDEs » Java Development Tools (JDT) » Windows PATH variable(How to set the PATH variable inside Eclipse to find Python?)
Windows PATH variable [message #1386494] Tue, 17 June 2014 20:45 Go to next message
Bjoern Thiel is currently offline Bjoern ThielFriend
maintaining a Maven project that auto generates part of its code using a Python script I need the PATH set up properly.
Working on Windows 7 with different Python versions installed I want none of these hard coded in the global PATH variable.
So I usually set the variable within a batch or shortcut and start the Application afterwards. But unfortunately with Eclipse this does not work:
SET path=%path%;C:\Python27
START C:\eclipse\eclipse.exe -vm "C:\Program Files\Java\jdk1.7.0_60\bin\javaw.exe"
Python is only found if I set PATH globally.
What can I do?
Re: Windows PATH variable [message #1386543 is a reply to message #1386494] Wed, 18 June 2014 08:15 Go to previous message
As this only occurred using a shortcut and disappeared after modifying the global PATH variable (removing a duplicate) it seems to be a Windows problem.
Previous Topic:Unable to save .java files
Next Topic:JDT Source Code Repository
Current Time: Thu Dec 26 21:16:48 GMT 2024
Powered by FUDForum. Page generated in 0.06274 seconds
