Unable to creat Lua Project [message #1385608] |
Mon, 09 June 2014 18:27  |
I've tried installing the LDT plugin through the marketplace and through the 'install new software' option directly, and it always appears to run smoothly but when I open the Lua perspective and try to create a new project nothing happens. I've checked the preferences and I get a 'the currently displayed page contains invalid values' warning when I select the Execution Environment option at first, although this disappears when I clear the warning.
I'm running it on 64-bit OS 10.6.8 and Kepler Eclipse, which should be fine. I've downloaded the standalone application which works perfectly, but I was wanting to run everything from within Eclipse so I'm just a bit confused and would love some advice as to what I'm doing wrong?
FUDForum. Page generated in 0.02543 seconds
