Fwd: Re: display problem of TreeMapper [message #1338578] |
Wed, 07 May 2014 09:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On 05/06/2014 02:55 PM, Jingang Zhou wrote:
> I use the latest TreeMapper widget, but found the mappings is not
> displayed after I setInput(leftProvider, rightProvider, mappings) (the
> mappings is not null), which force me to expand all the treeitems
> manually to make the mappings show. I debugged the source code of
> treeMapper and found that the treeMapper use the testFindItem method to
> find mapping elements, but this methods always return null. So, how to
> solve this problem?
This seems to be a bug or a limitation in the TreeMapper, most likely
because a specific behaviour of your content provider or tree. It's not
obvious to figure out what's wrong with this description.
Can you please open a bug on bugs.eclipse.org and attach to the report a
very minimal piece of code that allows to reproduce the issue? Even
better, do you think you could write a simple JUnit test case to
highlight this issue?
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
FUDForum. Page generated in 0.03202 seconds
