Change The Locale [message #135253] |
Wed, 24 September 2003 11:45  |
What, if any, mechanism is provided by eclipse for changing locales?
If there is a way to change locales might there be a way to do it
dynamically while eclipse is running?
Any help with eclipse locale changing would be greatly appreciated.
Thank you,
Greg
Re: Change The Locale [message #136037 is a reply to message #135881] |
Thu, 25 September 2003 13:04  |
You can scan the file system, look for properties files and come up with a
rough guess?
Some plugins may support German, some French, some both, but no
garantuees anywhere....
Chris
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bkuocq$1f0$1@eclipse.org...
> Greg wrote:
> > Daniel Megert wrote:
> > Thank you very much. I have one other question you may also know the
> > answer to:
> > Do you know if there is a place I could find a list of all the locales
> > that eclipse supports?
> That's not so easy since it depends on each plug-in how many languages
> it supports i.e. for which languages it delivers the *.properties files.
> I don't know of any API that would help you here.
> Dani
> I want to create a UI button that would allow a
> > user to change locales (even if it has to restart eclipse when one is
> > selected) I need to test some stuff out though and I can't seem to get
any
> > of, what I thought where, standard locales to work.
> >>You can startup eclipse using -nl <Locale>
> >>Currently there's no UI that would allow the user to do this and
> >>existing views/dialogs don't change dynamically.
> >>HTH
> >>Dani
> >>>Thank you,
> >>>Greg
FUDForum. Page generated in 0.30236 seconds
