Home » Modeling » GMF (Graphical Modeling Framework) » Labels for connections are missing with RC2
Labels for connections are missing with RC2 [message #133592] Thu, 07 June 2007 05:19 Go to next message
I've submitted a bugzilla for this problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191437
My solution is to change the createFigure() method of label's editparts
with old generated code of RC1. This works.
Jens
Re: Labels for connections are missing with RC2 [message #134191 is a reply to message #133592] Fri, 08 June 2007 14:26 Go to previous messageGo to next message
It turned out the old logic had some (unpleasant) dependency of processing
order which may lead to either incorrect figure being created (behavior one
may observe in builds prior to RC2) or no figure created at all, assigned by
parent (which is correct behavior, though there are few missed pieces that
were uncovered with RC2 change). We'll fix it with RC3, stay tuned.
Thank you,
Artem
"Jens Bachmann" <jens-bachmann@gmx.de> wrote in message
news:f48igs$4vc$1@build.eclipse.org...
> Regards,
> Jens
Re: Labels for connections are missing with RC2 [message #134242 is a reply to message #134191] Sat, 09 June 2007 08:43 Go to previous messageGo to next message
Is the following problem related to this one?
I'm experiencing another problem with the GMF tutorial (I'm using GMF
2RC): the generated visual editor does not show the label of the Topic
(although it permits inserting a label and actually shows the label
value in the property view)
see the image: http://img519.imageshack.us/img519/6048/nolabelshownin3.png
I've also tried with mindmap_tutorial_1.zip project, although I had to
re-generate the Diagram Editor Gen Model due to errors (e.g., the use
of "out_taget" which is mispelled) and then generate the Diagram editor code
but the problem is still the same.
Notice that by using the Diagram editor code that comes with
mindmap_tutorial_1.zip everything works fine, so I guess it's a problem
introduced in GMF generation wizards lately.
> Thank you,
> Artem
>> Hi,
>> Regards,
>> Jens
Lorenzo Bettini, PhD in Computer Science, DSI, Univ. di Firenze
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Labels for connections are missing with RC2 [message #134256 is a reply to message #134242] Sat, 09 June 2007 08:56 Go to previous messageGo to next message
This was recently fixed and works in the latest builds:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191303
Best,
Rich
On 6/9/07 8:43 AM, in article f4e7ae$hhn$1@build.eclipse.org, "Lorenzo
>> Thank you,
>> Artem
>>> Hi,
>>> Regards,
>>> Jens
Re: Labels for connections are missing with RC2 [message #134269 is a reply to message #134256] Sat, 09 June 2007 09:00 Go to previous messageGo to next message
By the way, you can work around it easily enough by just adding a FlowLayout
to the Topic rectangle.
- Rich
On 6/9/07 8:56 AM, in article C2901BD4.171FC%richard.gronback@borland.com,
> Best,
> Rich
>>> Thank you,
>>> Artem
>>>> Hi,
>>>> Regards,
>>>> Jens
Re: Labels for connections are missing with RC2 [message #134282 is a reply to message #134256] Sat, 09 June 2007 10:43 Go to previous messageGo to next message
mhhh... I'm pretty sure I performed the update yesterday... so I should
have the latetest build I guess...
> Best,
> Rich
Re: Labels for connections are missing with RC2 [message #134803 is a reply to message #134282] Tue, 12 June 2007 04:13 Go to previous messageGo to next message
I also updated o RC2 today and I still have this bug !
Re: Labels for connections are missing with RC2 [message #134924 is a reply to message #134803] Tue, 12 June 2007 05:50 Go to previous messageGo to next message
I downloaded the last nightly build (N20070612) from GMF Homepage and my
problem with labels of connections is solved.
Thanks to the developers ;)
So I'm looking forward to RC3 of GMF.
Jens
Re: Labels for connections are missing with RC2 [message #136103 is a reply to message #134924] Thu, 14 June 2007 11:09 Go to previous messageGo to next message
Originally posted by: sbecker.ipd.uka.de
I also had many problems:
* Link labels lead to NullPointerExceptions on initialising diagrams
(same as Jens' problem)
* Compartment labels gone (same as bug 191303)
and additionally:
* even normal node labels vanished for nodes which have more than a
single label as children
I'll try N20071406 soon to see whether it works there again.
Steffen
Re: Labels for connections are missing with RC2 [message #136126 is a reply to message #136103] Thu, 14 June 2007 16:14 Go to previous message
here are my results, not all are good news:
Is not resolved here for N20071406, but I get a different exception now
Is also not resolved, should I reopen it or wait until RC3?
> and additionally:
This works again.
Steffen
Previous Topic:ParserProvider - any examples ?
Next Topic:how to get notified about editor change with partitioned diagram
Current Time: Mon Nov 03 20:17:41 EST 2025
Powered by FUDForum. Page generated in 0.09271 seconds
