Home » Language IDEs » C / C++ IDE (CDT) » Problems installing CDT 1.2.1
Problems installing CDT 1.2.1 [message #131342] Sat, 11 December 2004 09:54 Go to next message
I'm re-posting this message to this tread as the question is more about the
problem with CDT then with Eclipse.
I'm trying to install CDT 1.2.1 on Eclipse 2.1 I'm doing this
because I'm using QNX and as you know Eclipse 3 is not supported for QNX.
I've downloaded the following accumulative version of CDT from here
( http://update.eclipse.org/tools/cdt/updates/release/dist/cdt -1.2.1.zip)
I've unpacked it to the "/" directory and found 2 folders "features" and
"plugins"
I've moved them to "/opt/share/eclipse/plugins" - where I have all my
eclipse files.
However when I start eclipse I see pending configuration changes (see
attached
screenshot as it contains all debug info I have right now)
Can you please help me as I though that i've downloaded everything I need in
order to run CDT plug-in in eclipse
Thanks a lot,
Roman.
  • Attachment: ss.jpg
    (Size: 69.37KB, Downloaded 101 times)
Re: Problems installing CDT 1.2.1 [message #131611 is a reply to message #131342] Tue, 14 December 2004 09:29 Go to previous messageGo to next message
I think your problem is that the "features" folder you got out of your
zip needs to go on top of /opt/share/eclipse/features.
So the end result is something like:
/opt/share/eclipse/features/org.eclipse.cdt.*
/opt/share/eclipse/plugins/org.eclipse.cdt.*
-Andrew
Roman Yankin wrote:
> Hello,
> "plugins"
> eclipse files.
> attached
> Thanks a lot,
> Roman.
Re: Problems installing CDT 1.2.1 [message #133002 is a reply to message #131342] Wed, 29 December 2004 19:29 Go to previous message
Could this be a permission problem? i.e. In my Linux if the normal user has
no read permission to the files.
Roman Yankin wrote:
> Hello,
> the problem with CDT then with Eclipse.
> "plugins"
> eclipse files.
> attached
> in order to run CDT plug-in in eclipse
> Thanks a lot,
> Roman.
Previous Topic:CDT 2.1 and bug 27663
Next Topic:CDT 2.1 won't work in AIX 5.1
Current Time: Tue Apr 29 03:38:34 EDT 2025
Powered by FUDForum. Page generated in 0.48578 seconds
