Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with RWTLifeCycle / disposed context and Jaas Example implemetation
Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #129195] |
Tue, 21 April 2009 13:25 |
Originally posted by: phiamo.gmail.com
I tried to implement a simple JAAS Callback Handler from the JAAS
Tutorial with RAP. I got many things working. But i have a stange
behavior if i try to open a second browser window (another session):
The first time i request the URI i yust get a blank workbench, the
second time the server goes into a exception loop (see end of post)
I am not sure what i did wrong i think it is no bug in rwt i think its
the way i am working with it.
as far as i understand i should try to make sure aother session gets
created for the other browser window. i thought its done but if i change
the asyncexec call into an synced exec call i got other exceptions.
Can you tell me where the new session is created, so i could try to do
this explicitly and the display i use to show my jaashandlerdialog would
perhabs use the right one.
And is there any further documentation where i could find such topics?
sincerely philipp a. mohrenweiser.
async run:
Authentication failed:
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadTerm inatedError
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLif eCycle.java:303)
at org.eclipse.swt.widgets.Display.sleep(Display.java:742)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:177)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:374)
at org.xterm.auth.AbstractLoginDialog.handle(AbstractLoginDialo g.java:96)
at
javax.security.auth.login.LoginContext$SecureCallbackHandler $1.run(LoginContext.java:955)
at
javax.security.auth.login.LoginContext$SecureCallbackHandler .handle(LoginContext.java:951)
at org.xterm.auth.SampleLoginModule.login(SampleLoginModule.jav a:120)
at
at
at javax.security.auth.login.LoginContext.invoke(LoginContext.j ava:769)
at javax.security.auth.login.LoginContext.access$000(LoginConte xt.java:186)
at javax.security.auth.login.LoginContext$4.run(LoginContext.ja va:683)
at javax.security.auth.login.LoginContext.invokePriv(LoginConte xt.java:680)
at javax.security.auth.login.LoginContext.login(LoginContext.ja va:579)
at org.xterm.auth.XtermAuthHandler.login(XtermAuthHandler.java: 47)
at
org.xterm.lounge.XtermLoungeApplication.createUI(XtermLounge Application.java:24)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:619)
java.lang.IllegalStateException: The context has been disposed.
at
org.eclipse.rwt.internal.service.ServiceContext.checkState(S erviceContext.java:154)
at
org.eclipse.rwt.internal.service.ServiceContext.getRequest(S erviceContext.java:82)
at
org.eclipse.rwt.internal.service.ContextProvider.getRequest( ContextProvider.java:129)
at
org.eclipse.rwt.internal.service.ContextProvider.getSession( ContextProvider.java:148)
at org.eclipse.swt.widgets.Display.getCurrent(Display.java:142)
at org.xterm.auth.AbstractLoginDialog.handle(AbstractLoginDialo g.java:59)
at
at
at
at
at
at
at
at
Synced run:
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2572)
at org.eclipse.swt.SWT.error(SWT.java:2492)
at org.eclipse.swt.SWT.error(SWT.java:2463)
at org.eclipse.swt.widgets.Widget.error(Widget.java:832)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:762)
at org.eclipse.swt.widgets.Control.getBounds(Control.java:774)
at org.eclipse.jface.window.Window.constrainShellSize(Window.ja va:416)
at org.eclipse.jface.window.Window.open(Window.java:805)
at org.xterm.auth.AbstractLoginDialog$1.run(AbstractLoginDialog .java:64)
at
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:119)
at org.eclipse.swt.widgets.Display$2.run(Display.java:649)
at
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 455)
at
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:647)
at org.xterm.auth.AbstractLoginDialog.handle(AbstractLoginDialo g.java:60)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #129222 is a reply to message #129195] |
Tue, 21 April 2009 13:45 |
Ok a little bit reading and i got it myself. i was using a singleton i
implemented myself... so it did not create another one but used the
same.. using SessionSingletonBase solved the problem.
public class MySingleton extends SessionSingletonBase {
public static MySingleton getInstance() {
return (MySingleton)getInstance(MySingleton.class);
// all the other stuff comes here
I found it in the book Eclipse Rich Ajax Platform but nowhere in the
web, could someone tell me where to find such things ? i would also like
to collect and publish them in some wiki, the rap wiki seems to be a
good idea?
thanks phil
Philipp Mohrenweiser schrieb:
> Hello,
> async run:
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Synced run:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #129249 is a reply to message #129222] |
Tue, 21 April 2009 14:27 |
OK now i am experiencing the old
but only if i try to refresh a browser window after more than 30sekonds
(session timeout?)
i think its a wrong approach in my app but i do not know where.
thanks for any suggestions
phil
> good idea?
> thanks phil
>> Hello,
>> change the asyncexec call into an synced exec call i got other
>> exceptions.
>> would perhabs use the right one.
>> async run:
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Synced run:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #129550 is a reply to message #129249] |
Thu, 23 April 2009 01:40 |
i came to the conclusion that this is related with the bug
ProgressMonitorDialog causes an Exception on page reload
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258102
i am using a open method for the callback window:
could someone verify this ? or give me another approach
while hitting f5 i get uithreadterminated error and IllegalStateExceptions
sincerly philipp a. mohrenweiser
package org.xterm.auth;
* Copyright (c) 2005, 2007 IBM Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* IBM Corporation - initial API and implementation
import java.io.IOException;
import javax.security.auth.callback.Callback;
import javax.security.auth.callback.CallbackHandler;
import javax.security.auth.login.LoginException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.jface.dialogs.TitleAreaDialog;
import org.eclipse.jface.operation.IRunnableWithProgress;
import org.eclipse.jface.operation.ModalContext;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.widgets.*;
import org.eclipse.ui.PlatformUI;
public abstract class AbstractLoginDialog extends TitleAreaDialog
implements CallbackHandler {
boolean processCallbacks = false;
boolean isCancelled = false;
Callback[] callbackArray;
protected final Callback[] getCallbacks() {
return this.callbackArray;
public abstract void handleLoginException(LoginException loginException);
public abstract IProgressMonitor getProgressMonitor();
public abstract void internalHandle();
public boolean isCancelled() {
return isCancelled;
protected AbstractLoginDialog(Shell parentShell) {
super(parentShell);
/* (non-Javadoc)
* @see
javax.security.auth.callback.CallbackHandler#handle(javax.se curity.auth.callback.Callback[])
public void handle(final Callback[] callbacks) throws IOException {
this.callbackArray = callbacks;
Display display = null;
try{
display = Display.getDefault();
catch(Exception e){
display = PlatformUI.createDisplay();
System.out.println("created display !?");
System.out.println("Got display:");
System.out.println(display);
display.syncExec(new Runnable() {
public void run() {
setBlockOnOpen(false);
open();
final Button okButton = getButton(IDialogConstants.OK_ID);
okButton.setText("OK");
okButton.addSelectionListener(new SelectionListener() {
public void widgetSelected(final SelectionEvent event) {
processCallbacks = true;
public void widgetDefaultSelected(final SelectionEvent event) {
// nothing to do
final Button cancel = getButton(IDialogConstants.CANCEL_ID);
cancel.addSelectionListener(new SelectionListener() {
isCancelled = true;
// nothing to do
try {
ModalContext.setAllowReadAndDispatch(true); //Works for now.
ModalContext.run(new IRunnableWithProgress() {
public void run(final IProgressMonitor monitor) {
// Wait here until OK or cancel is pressed, then let it rip. The
event listener
// is responsible for closing the dialog (in the loginSucceeded event).
while (!processCallbacks) {
try {
Thread.sleep(100);
} catch (final Exception e) {
//do nothing
// Call the adapter to handle the callbacks
if (!isCancelled())
internalHandle();
}, true, new NullProgressMonitor(), Display.getDefault());
final IOException ioe = new IOException();
ioe.initCause(e);
//throw ioe;
> (session timeout?)
> phil
>> like to collect and publish them in some wiki, the rap wiki seems to
>> be a good idea?
>> thanks phil
>>> Hello,
>>> its the way i am working with it.
>>> exceptions.
>>> do this explicitly and the display i use to show my jaashandlerdialog
>>> async run:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Synced run:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #130175 is a reply to message #129550] |
Fri, 24 April 2009 16:32 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
to me it looks like you ran into this problem:
262220: Invalid Thread Access
https://bugs.eclipse.org/bugs/show_bug.cgi?id=262220
Philipp Mohrenweiser wrote:
> * Contributors:
> loginException);
> return isCancelled;
> super(parentShell);
> /* (non-Javadoc)
> * @see
> try{
> catch(Exception e){
> public void run() {
> open();
> event) {
> // nothing to do
> event) {
> isCancelled = true;
> // nothing to do
> try {
> it rip. The event listener
> try {
> Thread.sleep(100);
> //do nothing
> if (!isCancelled())
> internalHandle();
> ioe.initCause(e);
> //throw ioe;
>> 30sekonds (session timeout?)
>> phil
>>> i implemented myself... so it did not create another one but used the
>>> be a good idea?
>>> thanks phil
>>>> Hello,
>>>> exceptions.
>>>> jaashandlerdialog would perhabs use the right one.
>>>> async run:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Synced run:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #130291 is a reply to message #130175] |
Sun, 26 April 2009 21:26 |
Hello Rüdiger,
thanks for your help, but i tred the patch and verifiyed that i run into
the patched code. but i still get a loop with the IllegalStateException
while trying to PlatformUI.createDisplay();
and prior to that a UIThreadTerminatedError
atm i am tring to rearrange the code and the logic but did not get any
results yet.
if you have any clues i would be very grateful.
cheers phil
>> Hi,
>> * Contributors:
>> loginException);
>> return isCancelled;
>> super(parentShell);
>> /* (non-Javadoc)
>> * @see
>> try{
>> catch(Exception e){
>> public void run() {
>> open();
>> event) {
>> // nothing to do
>> event) {
>> isCancelled = true;
>> // nothing to do
>> try {
>> let it rip. The event listener
>> try {
>> Thread.sleep(100);
>> //do nothing
>> if (!isCancelled())
>> internalHandle();
>> ioe.initCause(e);
>> //throw ioe;
>>> phil
>>>> the same.. using SessionSingletonBase solved the problem.
>>>> be a good idea?
>>>> thanks phil
>>>>> Hello,
>>>>> gets created for the other browser window. i thought its done but
>>>>> if i change the asyncexec call into an synced exec call i got other
>>>>> exceptions.
>>>>> async run:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Synced run:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: Problem with RWTLifeCycle / disposed context and Jaas Example implemetation [message #130357 is a reply to message #130291] |
Mon, 27 April 2009 07:40 |
Phil,
feel free to file a bugzilla if you can reproduce the problem. See
[1] for bug reporting guidelines.
Rüdiger
[1] http://wiki.eclipse.org/RAP_Bug_Reporting_Howto
> Hello Rüdiger,
> results yet.
> cheers phil
>>> Hi,
>>> * Contributors:
>>> loginException);
>>> return isCancelled;
>>> super(parentShell);
>>> /* (non-Javadoc)
>>> * @see
>>> try{
>>> catch(Exception e){
>>> public void run() {
>>> open();
>>> event) {
>>> // nothing to do
>>> event) {
>>> isCancelled = true;
>>> // nothing to do
>>> try {
>>> try {
>>> Thread.sleep(100);
>>> //do nothing
>>> if (!isCancelled())
>>> internalHandle();
>>> ioe.initCause(e);
>>> //throw ioe;
>>>> phil
>>>>> singleton i implemented myself... so it did not create another one
>>>>> but used the same.. using SessionSingletonBase solved the problem.
>>>>> the web, could someone tell me where to find such things ? i would
>>>>> also like to collect and publish them in some wiki, the rap wiki
>>>>> seems to be a good idea?
>>>>> thanks phil
>>>>>> Hello,
>>>>>> the second time the server goes into a exception loop (see end of
>>>>>> post)
>>>>>> other exceptions.
>>>>>> to do this explicitly and the display i use to show my
>>>>>> topics?
>>>>>> async run:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Synced run:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Current Time: Sat Oct 19 17:05:02 GMT 2024
Powered by FUDForum. Page generated in 1.41036 seconds
