Home » Modeling » EMF » [Oomph] Preferences not copied and NPE on init
[Oomph] Preferences not copied and NPE on init [message #1297285] Tue, 15 April 2014 11:01 Go to next message
I have tried the newest version of the Oomph installer, as it looks like a very useful tool for us as well. I tried to set it up for Authoring based on this: https://wiki.eclipse.org/Eclipse_Oomph_Authoring
However, at the end of the Installing Development Environment step, it says it cannot copy a non-existent settings file ...net.prefs from the .metadata folder of the installer.
When the new IDE starts, it also throws an NPE when it cannot load preferences. As a result, it cannot perform the setup steps.
I know that the project is in the proposal phase, but maybe you have some suggestions for a workaround (e.g. manually creating the prefs file)? I can also create a BugZilla if that's better.
!ENTRY org.eclipse.emf.cdo.releng.setup 4 0 2014-04-15 14:24:56.333
!MESSAGE java.lang.NullPointerException
!STACK 0 java.lang.NullPointerException at org.eclipse.emf.cdo.releng.internal.setup.SetupTaskPerformer.resolveSettings(SetupTaskPerformer.java:631) at org.eclipse.emf.cdo.releng.internal.setup.SetupTaskPerformer.initNeededSetupTasks(SetupTaskPerformer.java:311) at org.eclipse.emf.cdo.releng.internal.setup.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:817) at org.eclipse.emf.cdo.releng.internal.setup.SetupTaskPerformer.perform(SetupTaskPerformer.java:751) at org.eclipse.emf.cdo.releng.internal.setup.Activator$1.run(Activator.java:127)
Re: [Oomph] Preferences not copied and NPE on init [message #1300205 is a reply to message #1297285] Thu, 17 April 2014 08:03 Go to previous messageGo to next message
Abel,
Eike has been heads-down working on the new version that will be its own
project...
On 15/04/2014 5:01 PM, Abel Hegedus wrote:
Yes, there's code that copied network preferences... If one needs to
set a proxy server to access outside a firewall, that needs to be done
already in the installer and the installed IDE will need those same
settings. The code should be more careful to check that the folder
really exists. I assume it's this code here:
PreferenceNode configurationPreferences =
PreferencesUtil.getRootPreferenceNode().getNode("configuration");
if (configurationPreferences != null)
PreferenceNode networkPreferences =
configurationPreferences.getNode("org.eclipse.core.net");
if (networkPreferences != null)
ResourceCopyTask resourceCopyTask =
SetupFactory.eINSTANCE.createResourceCopyTask();
URI sourceLocation =
URI.createFileURI(networkPreferences.getLocation());
resourceCopyTask.setSourceURL(sourceLocation.toString());
int segmentCount = sourceLocation.segmentCount();
URI targetURI = URI.createFileURI(new File(getEclipseDir(),
"configuration").toString()).appendSegment(sourceLocation.segment(segmentCount
- 2))
.appendSegment(sourceLocation.segment(segmentCount - 1));
resourceCopyTask.setTargetURL(targetURI.toString());
if (resourceCopyTask.isNeeded(this))
resourceCopyTask.perform(this);
> at
> at
> at
> at
It sounds like something is wrong with the preference file that it fails
to load properly. Perhaps try deleting
<user.home>\.eclipse\org.eclipse.emf.cdo.releng.setup\setup-eclipse.xmi
and letting the installer create a new one...
Re: [Oomph] Preferences not copied and NPE on init [message #1300338 is a reply to message #1300205] Thu, 17 April 2014 10:00 Go to previous messageGo to next message
Ed Merks wrote on Thu, 17 April 2014 08:03
really exists.
Yes, after creating an empty file with the correct name, the installer copies it happily.
If I get this right, this is unrelated to the failed copy of the other file. The preferences field is filled from the "originalSetup" in AbstractSetupTaskContext.initilaize(), and I guess that original is supposed to be the file you mentioned. I tried deleting it, but it still fails.
The contents of the above file is:
<?xml version="1.0" encoding="ASCII"?>
<setup:Preferences setup:toolVersion="8" xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:setup="http://www.eclipse.org/CDO/releng/setup/1.0" installFolder="[...]\Oomph"/>
Unfortunately, I use Windows 8 and my user directory has accents (which I cannot change), could this be the problem? Is there a way to copy this file somewhere else and have it load from there?
Re: [Oomph] Preferences not copied and NPE on init [message #1300394 is a reply to message #1300338] Thu, 17 April 2014 10:43 Go to previous messageGo to next message
Abel,
Accents! I see that the resource factory doesn't set set UTF-8 as the
default encoding so ASCII is used. It really should default to UTF-8.
Does the file contain non-ASCII characters? If you change it manually,
I think that setting should be respected from then on, but we write
other resources too, and any one of them could have this problem. In
particular the setup.xmi has a reference to the preferences, so you'd
have to change that manually too and start the IDE again.
Please open a bugzilla. Eike could fix that in the old code and
definitely it needs to be fixed in the new code...
>> The code should be more careful to check that the folder really exists.
> copies it happily.
>> fails to load properly. Perhaps try deleting
> still fails.
Re: [Oomph] Preferences not copied and NPE on init [message #1300441 is a reply to message #1300394] Thu, 17 April 2014 11:23 Go to previous message
Thanks for your help, Ed!
I created a bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=433018
I'm happy to provide more details or testing if you need it.
Previous Topic:too big for int
Next Topic:[CDO 4.1] Not active: CDOTransactionImpl
Current Time: Thu Nov 06 00:06:19 EST 2025
Powered by FUDForum. Page generated in 0.04230 seconds
