Re: [TCS] TCSRuntime doitForContext ambiguity [message #12372 is a reply to message #12361] |
Mon, 21 April 2008 16:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Frédéric Jouault![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=frederic.jouault%40univ-nantes.fr) Messages: 572 Registered: July 2009 |
> So this looks to me as if in case no suitable modelelement was found in
> the given context, you extend the search in the parent context.
> My problem with that is: How would you find ambiguous references this
> way? Meaning should there ever be two suitable candidates, on the
> current context and one in the parent context, should TCS not rather
> report a problem than taking the first candidate as reference?
The notion of context in TCS is related to the notion of scope.
There cannot be collisions within a given scope, but an element defined
at a local scope may mask what exists in any outer scope.
A typical example is the C language, in which global variables are
visible in functions, but functions can mask global variables with local
variables. In this case, the overwall C file is a context, and so are
functions. Moreover, C supports arbitrary nesting of scopes (each
statement block defines a new one).
If you want to make sure an element cannot be masked, then you may only
define one global context (i.e., the root of the model).
Frédéric Jouault
FUDForum. Page generated in 0.02872 seconds
