this. in getter and setter methods [message #122330] |
Wed, 26 November 2003 13:59 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: kl.itec.uni-klu.ac.at
is it possible to customize the "Generate Getter and Setter" functionality
by adding a "this." before the attribute to set/get?
Example:
What Eclipse does:
public void setSomething(int i) {
something = i;
What I want:
this.something = i;
Thanks in advance,
Klaus
Re: this. in getter and setter methods [message #122378 is a reply to message #122330] |
Wed, 26 November 2003 14:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: eclipse.tkilla.ch
Klaus Leopold wrote:
> Example:
> What Eclipse does:
> something = i;
> What I want:
> this.something = i;
In the preferences, go to Java->Code Generation->Code and Comments tab
and modify the getter and setter bodies.
-tom
Re: this. in getter and setter methods [message #122387 is a reply to message #122378] |
Wed, 26 November 2003 14:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
That was the first place where I looked for it but I couldn't find these
settings. I just have following entries:
Comments:
Constructors
Types
Methods
Overriding methods
Code:
New Java files
Catch block body
Method body
Constructor body
No getter and setter stuff here :(
Klaus
>> Hi,
>> functionality by adding a "this." before the attribute to set/get?
>> Example:
>> What Eclipse does:
>> something = i;
>> What I want:
>> this.something = i;
> -tom
Re: this. in getter and setter methods [message #122398 is a reply to message #122387] |
Wed, 26 November 2003 15:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Comments:
> Constructors
> Types
> Methods
> Overriding methods
> Code:
> New Java files
> Catch block body
> Method body
> Constructor body
What build are you on? AFAIR, this has been added around M3 or M4.
-tom
Re: this. in getter and setter methods [message #122409 is a reply to message #122398] |
Wed, 26 November 2003 15:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
My about says:
Version: 2.1.2
Build id: 200311030802
So, I'll have to update?
Klaus
>> Comments:
>> Constructors
>> Types
>> Methods
>> Overriding methods
>> Code:
>> New Java files
>> Catch block body
>> Method body
>> Constructor body
> -tom
Re: this. in getter and setter methods [message #122429 is a reply to message #122398] |
Wed, 26 November 2003 15:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> -tom
Is it just me or is this broken in M5? When I choose "Generate
Getters and Setters" nothing happends. No dialig appears and
no errormessage. Any ideas?
Michael
Re: this. in getter and setter methods [message #122526 is a reply to message #122429] |
Wed, 26 November 2003 17:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Works fine for me
-tom
Re: this. in getter and setter methods [message #122560 is a reply to message #122478] |
Wed, 26 November 2003 19:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
With 3.0M5 it works perfekt!
Klaus
Adam Kiezun wrote:
>> Version: 2.1.2
> big time
> you're sitting on some old stuff
> get M4 or M5
> a.
Re: this. in getter and setter methods [message #122714 is a reply to message #122429] |
Thu, 27 November 2003 15:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Colin Sampaleanu![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=colinml1%40exis.com) Messages: 22 Registered: July 2009 |
>>-tom
This appears to be 'half' broken in M5. If I right click on a field
variable and do 'Source|Generate Getters and Setters', then it works
absolutely ok. On the other hand, if I right click on some empty space
in the class and do the same thing, or if I try to use the Eclipse menu
option for this, I get no visible results, and some errors appear in the
Error Log, as follows:
!ENTRY org.eclipse.ui 4 4 Nov 27, 2003 10:01:47.980
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Nov 27, 2003 10:01:47.980
!MESSAGE null argument;
!STACK 0
org.eclipse.jface.util.Assert$AssertionFailedException: null argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:139)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:116)
at
org.eclipse.jface.viewers.AbstractTreeViewer.reveal(Abstract TreeViewer.java:1233)
at
org.eclipse.jdt.ui.actions.AddGetterSetterAction$GetterSette rTreeSelectionDialog.createDialogArea(AddGetterSetterAction. java:972)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 573)
at org.eclipse.jface.window.Window.create(Window.java:305)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:883)
at
org.eclipse.ui.dialogs.SelectionStatusDialog.create(Selectio nStatusDialog.java:143)
at
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.access$sup erCreate(CheckedTreeSelectionDialog.java:215)
at
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.access$0(C heckedTreeSelectionDialog.java:214)
at
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog$1.run(Chec kedTreeSelectionDialog.java:240)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
at
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.create(Che ckedTreeSelectionDialog.java:238)
at org.eclipse.jface.window.Window.open(Window.java:555)
at
org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.open(Check edTreeSelectionDialog.java:209)
at
org.eclipse.jdt.ui.actions.AddGetterSetterAction.run(AddGett erSetterAction.java:255)
at
org.eclipse.jdt.ui.actions.AddGetterSetterAction.run(AddGett erSetterAction.java:505)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:196)
at
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:172)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:542)
at
org.eclipse.jface.action.ActionContributionItem.access$4(Act ionContributionItem.java:494)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:466)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2187)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1877)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1381)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:237)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:299)
at org.eclipse.core.launcher.Main.run(Main.java:767)
at org.eclipse.core.launcher.Main.main(Main.java:601)
Re: this. in getter and setter methods [message #122723 is a reply to message #122714] |
Thu, 27 November 2003 15:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Please file a bug report agains jdt ui.
-tom
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.05175 seconds
