JBuilder to EClipse [message #12235] |
Thu, 08 January 2004 15:50 |
Originally posted by: ALin.doe.state.nj.us
I have a project in JBuilder 7 and would like to migrate into
EClipse 3. After copying the folder into EClipse workspace,
what should I do next ?
Alex Lin
Re: JBuilder to EClipse [message #12237 is a reply to message #12235] |
Thu, 08 January 2004 16:35 |
Originally posted by: nospam.cops.net
Hi!
First of all, this kind of questions are more appropiate for the
eclipse.platform newsgroup.
Second of all, you can import the project. Just go to File->Import, then
choose File system. Then, point to the directory that contains the
project, and from there it is pretty straightforward.
Stelian Iancu
"They say we are thinking in bits ..."
Alex Lin wrote:
> Alex Lin
Re: JBuilder to EClipse [message #12441 is a reply to message #12237] |
Fri, 09 January 2004 08:53 |
Originally posted by: daniel.megert.gmx.net
Stelian Iancu wrote:
> Hi!
> then choose File system. Then, point to the directory that contains
> the project, and from there it is pretty straightforward.
> Stelian Iancu
> Alex Lin wrote:
>> Hi,
Given the fact that you already copied it into the workspace you can
also try to directly create the Java project using New > Java Project.
The wizard is smart and tries to correctly setup your Java build path.
Dani
>> Thanks,
>> Alex Lin
FUDForum. Page generated in 0.03388 seconds
