Re: p2 materializer content.xml [message #1220183 is a reply to message #1220134] |
Tue, 10 December 2013 09:30 |
On 2013-12-10 01:32, Philip Bedingfield wrote:
> Is there a way to get the p2 materializer to produce the content.xml file? I want to publish the resolved target
> platform to a p2 site.
No, that's not possible. The materializer produces a repository where all artifacts have been unpacked. It's not
suitable as a p2 site.
My recommendation would be to instead use the b3 aggregator to create the site that you want to publish. Then use
Buckminster to create the target platform from that site.
HTH,
- thomas
Re: p2 materializer content.xml [message #1220345 is a reply to message #1220301] |
Wed, 11 December 2013 08:41 |
On 2013-12-11 00:37, Philip Bedingfield wrote:
> Thanks Thomas, I found this tutorial as well ->
> http://nirmalsasidharan.wordpress.com/2010/10/09/provisioning-your-target-platform-as-local-p2-site/
There's a (in some cases serious) drawback that the tutorial fails to mention.
The target platform consists of artifacts expanded into their directory form (true for all features and also for some
common plug-ins like the org.eclipse.platform, the launchers, and the gtk fragments). Creating an update site based on
directory based content implies repacking them into jars. The resulting jars will be different from their original which
means that they can not retain their original signing. You must either resign them yourself or use unsigned jars.
- thomas
Re: p2 materializer content.xml [message #1222730 is a reply to message #1222595] |
Sat, 21 December 2013 07:12 |
On 2013-12-20 22:28, Philip Bedingfield wrote:
> I used b3 to create a mirror target platform but when I try and resolved from it I get the following error ->
> An internal error occurred during: "p2 materializer".
> Illegal character in opaque part at index 7: file:C:\Users\Zach/mirror/rcp/final
> Any ideas?
That URL is illegal. A URL cannot have backslashes in it. Not even on windows. Where does it stem from?
- thomas
Re: p2 materializer content.xml [message #1223302 is a reply to message #1222730] |
Mon, 23 December 2013 02:37 |
Philip Bedingfield Messages: 43 Registered: August 2011 |
Member |
Its part of Lorenzo's tutorial, the b3 aggregation uses a property defined as ->
eclipse.target.platform=file:${user.home}/mirror/rcp/final
which is reference in his rmap
<rm:searchPath name="eclipse">
<rm:provider componentTypes="eclipse.feature,osgi.bundle"
readerType="p2" source="false" mutable="false">
<rm:property key="buckminster.source" value="false" />
<rm:property key="buckminster.mutable" value="false" />
<rm:uri format="{0}">
<bc:propertyRef key="eclipse.target.platform" />
</rm:uri>
</rm:provider>
</rm:searchPath>
[Updated on: Mon, 23 December 2013 04:05] Report message to a moderator
Re: p2 materializer content.xml [message #1225708 is a reply to message #1223302] |
Mon, 30 December 2013 15:06 |
> defined as ->
ops then it might be my fault ;)
To be honest I use Linux most of the time, but when I use Windows I have
similar problems too, because Windows replaces ${user.home} with its
backslashes and p2 does not like them.
I use the following tricks when on Windows (I think the first / after :
is required anyway)
eclipse.target.platform=file:/C:/Users/${user.name}/mirror/rcp/final
(note user.name instead of user.home) at least this allows your
properties file to be used by different users (though it cannot be
reused in Unix systems).
Alternatively, you may want to try to pass that property from an ant
script. In particular if you define a property in ant with "location"
(instead of "value"), ant will use slashes instead of backslashes.
Does this help?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: p2 materializer content.xml [message #1231188 is a reply to message #1231186] |
Tue, 14 January 2014 02:38 |
Member |
Here is the error ->
ERROR [0002] : An error occurred while collecting items to be installed
ERROR [0002] : session context was:(profile=D:\Jenkins\jobs\SSDI Continuous\workspace\target.platform, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR [0002] : Problems downloading artifact: osgi.bundle,org.eclipse.ant.core,3.2.401.v20121204-162022.
ERROR [0002] : File has invalid content:C:\Users\tmbadmin\AppData\Local\Temp\signatureFile1058611373455808892.jar
ERROR [0002] : Invalid content:lib/antsupportlib.jar
ERROR [0002] : Problems downloading artifact: osgi.bundle,org.eclipse.core.resources,3.8.1.v20121114-124432.
ERROR [0002] : File has invalid content:C:\Users\tmbadmin\AppData\Local\Temp\signatureFile8308315021821319356.jar
ERROR [0002] : Invalid content:ant_tasks/resources-ant.jar
ERROR [0002] : Problems downloading artifact: osgi.bundle,org.eclipse.equinox.p2.publisher.eclipse,1.1.0.v20120913-155635.
ERROR [0002] : File has invalid content:C:\Users\tmbadmin\AppData\Local\Temp\signatureFile2587780145237898809.jar
FUDForum. Page generated in 0.04112 seconds
