Creating links between links [message #121343] |
Mon, 23 April 2007 15:49 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jendrik.johannes.mailbox.tu-dresden.de
Hello all,
I am trying to build an editor, with the possibility to create links
between links. For this link type, I defined Source and Target Features
(in the Link Mapping) that reference elements which are represented by
links themselves. I also added a creation tool for the links.
However, in the generated Editor, I am not allowed to create a link.
(When I select the creation tool and mouse-over a link that should act
as source element creation is not allowed).
My question is, if it is possible to define such behavior with GMF (I
guess it should be, since it is possible to attach node links to other
links). If it is, is there something special I have to take into
consideration here?
Thanks a lot,
Jendrik Johannes
Re: Creating links between links [message #121477 is a reply to message #121369] |
Tue, 24 April 2007 10:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello Alex,
>> consideration here?
> It is possible to create link from link-1 to link-2 with GMF. Nothing
> special - just check your mapping model.
Thank you for the information. I updated GMF to the latest milestone and
now it works fine. :)
Jendrik
FUDForum. Page generated in 0.05140 seconds
