Home » Eclipse Projects » GEF » createChangeConstraintCommand; weird values getting passed in...
createChangeConstraintCommand; weird values getting passed in... [message #120484] Thu, 04 March 2004 02:30 Go to next message
Originally posted by: smallpocks.yahoo.com
Hey Guys,
I have created a very simple graphical editor which allows the draging and
dropping of Figures. To this end, I have extended the XYLayoutEditPolicy,
and I have overridden the createChangeConstraintCommand(EditPart arg0,Object
arg1) method in this class. Everything seems to work, and when I drag a
figure and the createChangeConstraintCommand method figure is called, I cast
arg1 as a Rectangle. The only problem is, while the x and y of the rectangle
are the valid point that I dragged the figure to, the height and width of
the rectangle are both -1, and I need these values to be the valid height
and width of the dragged figure. I checked the archives but couldn't find an
answer to my problem. I'm using a XYLayout on my content Figure, if this
helps. Thanks in advance for any help.
Guy
Re: createChangeConstraintCommand; weird values getting passed in... [message #120617 is a reply to message #120484] Thu, 04 March 2004 12:16 Go to previous messageGo to next message
If you've just dragged a figure, then only its location would change, not
its size. Then why do you need the size of the rectangle? Take a look at
LogicXYLayoutEditPolicy to see what it does.
If you really must figure out the size of the rectangle, you can always get
the Figure from the EditPart (cast it to GraphicalEditPart) that is passed
as a parameter to that method.
"Guy Beckman" <smallpocks@yahoo.com> wrote in message
news:c26lic$k7k$1@eclipse.org...
> Hey Guys,
arg0,Object
cast
rectangle
an
> Guy
Re: createChangeConstraintCommand; weird values getting passed in... [message #120878 is a reply to message #120617] Thu, 04 March 2004 20:31 Go to previous messageGo to next message
Well upon further examination, it seems as if you are right here. Resize the
figure, the rectangle passed to createChangeConstraintCommand has valid
height, width, x and y. However if I just try and drag the figure, the
height and width are both -1. Is this just to let me know that the size
hasn't changed? This is a little awkward for me because if means that I'll
have to check to see if the size is -1, instead of just automatically
setting it...
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:c27o2h$5g2$1@eclipse.org...
get
> > Hey Guys,
and
XYLayoutEditPolicy,
> arg0,Object
> cast
> rectangle
of
height
find
> an
> > Guy
Re: createChangeConstraintCommand; weird values getting passed in... [message #120967 is a reply to message #120878] Fri, 05 March 2004 13:37 Go to previous messageGo to next message
Hmm, what version of GEF are you using? I just looked at
LogicXYLayoutEditPolicy.createChangeConstraintCommand(Reques t, EditPart,
Object) and I see the correct size being passed everytime, irrespective of
whether it's a move or resize.
news:c28kt0$5oa$1@eclipse.org...
the
> setting it...
> Thanks
not
at
> get
passed
> > > Hey Guys,
> and
> XYLayoutEditPolicy,
> > arg0,Object
a
I
> > cast
> > rectangle
> of
> height
> find
> > an
this
> > > Guy
Re: createChangeConstraintCommand; weird values getting passed in... [message #120992 is a reply to message #120967] Fri, 05 March 2004 14:40 Go to previous messageGo to next message
It is possible that the current size (of the constraint) it -1,-1, meaning
"auto-size" in XYLayout, in which case we preserve that during moves.
Re: createChangeConstraintCommand; weird values getting passed in... [message #121009 is a reply to message #120992] Fri, 05 March 2004 19:18 Go to previous messageGo to next message
Hmm, I think you might be on to something.
This is how I initially set the size of my figure, where "size" comes from
my model. And yes, I use an XYLayout for my layout manager.
FigureEditPart::refreshVisuals() {
fig.setPreferredSize(size);
Rectangle r = new Rectangle(location.x,location.y,-1,-1);
((GraphicalEditPart) getParent()).setLayoutConstraint(this, fig, r);
I know that those -1s mean to give the figure its preferred size. Is this
why I am getting -1 for width and height when I drag my figure?
Guy
"Randy Hudson" <none@us.ibm.com> wrote in message
news:c2aksg$gtl$1@eclipse.org...
Re: createChangeConstraintCommand; weird values getting passed in... [message #121146 is a reply to message #121009] Tue, 09 March 2004 13:41 Go to previous message
Yes.
news:c2b511$370$1@eclipse.org...
> Thanks
> Guy
meaning
Previous Topic:Model has undirected connections; ConnectionEditPart?
Next Topic:Why isn't the SelectionTool working?
Current Time: Sun Oct 26 22:32:35 EDT 2025
Powered by FUDForum. Page generated in 0.05117 seconds
