Home » Eclipse Projects » Remote Application Platform (RAP) » Memory-Problems
Re: Memory-Problems [message #119519 is a reply to message #119506] |
Sat, 24 January 2009 22:44 |
Andrej Dimic Messages: 77 Registered: July 2009 |
Member |
Hi Benny
first of all, thanks for your reply.
I don't let a OOME occur, i do restart Tomcat before. But that is not the
point.
What you suggest i already did, not with MAT but with Netbeans (in
development Environment) and with jvmstat / jconsole in production
environment.
The classes that use up most memory are char[], TreeMap and Hashmap. Also,
memory consumption of these classes is growing.
Strange enough, we do not use any Hashmap's at all, and rarly TreeMap's or
char-Array's. And i checked several times that i release al elements in my
TreeMap's. And also, considering the load on the Homepage, it would be
impossible to use up all the Heap with the TreeMap's we used in our code.
Our application uses extensivly images (Graphics.getImage(...). Could that
be a problem?
Andrej
Re: Memory-Problems [message #119532 is a reply to message #119519] |
Sat, 24 January 2009 22:57 |
Benjamin Muskalla Messages: 338 Registered: July 2009 |
Hi Andrej,
the char[] arrays are most likely due to usage of Strings.
Why I suggested to use MAT is because it can show you a dominator tree
of your objects which in turn could reveal who is holding all these
objects. I don't say that RAP has no memory leaks so I would suggest to
check that - maybe the workbench code has a leak somewhere.
In general using images should be no problem as they are only references
by their pathname.
Cheers and have a nice weekend!
Benny
adiinfo wrote:
> Hi Benny
> the point.
> environment.
> Also, memory consumption of these classes is growing.
> or char-Array's. And i checked several times that i release al elements
> in my TreeMap's. And also, considering the load on the Homepage, it
> would be impossible to use up all the Heap with the TreeMap's we used in
> our code.
> that be a problem?
> Thanks
> Andrej
Re: Memory-Problems [message #119764 is a reply to message #119698] |
Tue, 27 January 2009 12:17 |
Hi Andrej,
it would be very interesting who references the objects mentioned in
point 2 and 3. Without having a path to the gc root I can't tell what
the source of the retained heap usage is.
btw: how do you create your images? do you use the ImageRegistry of
JFace? Do you use ImageData in any way?
Cheers
Benny
adiinfo wrote:
> Hi Benny
> after analyzing the Heapdump with MAT i can make these statements:
> 1. 72% of retained heap usage was due to a bug on my side
> 2. 11% of retained heap usage was due to java.util.Hashmap. References
> to jpeg-files were the vaste majority of entries (i do not use Hashmap
> at all).
> 3. 7% of retained heap was due to
> org.apache.naming.resources.CacheEntry. Again, only references to
> jpeg-files (ok, i'didnt check every single entry, but these i checked
> were all jpeg-files).
> This snapshot was taken after one single day!
> If i am interpreting the entrys in java.util.Hashmap and
> org.apache.naming.resources.CacheEntry correctly, you do not only cache
> a string to a file (as i have read in the newsforum and i was also told
> so), but there is also for each cache and hashmap entry a byte[] with
> the imagedata.
> MAT shows me for each java.util.Hashmap-Entry the class
> org.apache.catalina.loader.ResourceEntry with the members byte[],
> java.net.URL, java.net.URL. The byte[] array is exactly the size of the
> jpeg-file given in the java.net.URL.
> If i am right this is a desaster for me as i do have hundreds of images
> that are dynamically read from a database with over 2.5GB of image data.
> I can't cache all these images in the JVM heap.
> Do you rally cache the images in a byte[]? MAT makes be believe that.
> If so, is there any internal method so i can clear the image cache from
> time to time?
> Thanks
> Andrej
Antw: Re: Memory-Problems [message #119869 is a reply to message #119764] |
Tue, 27 January 2009 19:15 |
Originally posted by: admin.kabe-farben.ch
Hi Benny
i did send you the screenshots from MAT directly to your email account - i
was not able to post it to the newsgroup because of size restrictions.
You can see how images are created in my code in the snippet below:
public void saveThumbnail(File file, String imageType) {
if (thumb != null) {
BufferedImage bi = new BufferedImage(thumb.getIconWidth(), thumb
.getIconHeight(), BufferedImage.TYPE_INT_RGB);
Graphics g = bi.getGraphics();
g.drawImage(thumb.getImage(), 0, 0, null);
try {
ImageIO.write(bi, imageType, file);
} catch (IOException ioe) {
System.out.println("Error occured saving thumbnail");
} else {
System.out.println("Thumbnail has not yet been created");
Andrej
>>> Benjamin Muskalla<bmuskalla@eclipsesource.com> schrieb am 27.01.2009 um
13:17 in Nachricht <glmu04$tla$1@build.eclipse.org>:
> Hi Andrej,
> Cheers
> Benny
> adiinfo wrote:
>> Hi Benny
>> at all).
>> the imagedata.
>> time to time?
>> Thanks
>> Andrej
Re: Antw: Re: Memory-Problems [message #120040 is a reply to message #119869] |
Thu, 29 January 2009 11:50 |
Hi Andrej,
the next time please use an image service (eg. ImageShack) so everyone
can follow the discussion on the newsgroup.
To the memory problem: there are no references to anything RAP related.
As you can see the HashMap Entrys and
org.apache.naming.resources.CacheEntry all belong to the Catalina
classloader. It seems that catalina caches some of the images for
delivering them later. But there seems to be no leak in your app / in
RAP itself.
Cheers
Benny
Andrej Dimic wrote:
> Hi Benny
> try {
> } else {
> Thanks
> Andrej
>> Hi Andrej,
>> Cheers
>> Benny
>> adiinfo wrote:
>>> Hi Benny
>>> at all).
>>> the imagedata.
>>> time to time?
>>> Thanks
>>> Andrej
Re: Antw: Re: Memory-Problems [message #120052 is a reply to message #120040] |
Thu, 29 January 2009 12:56 |
Hi Benny
Sorry for that, i know it's bad behavior. I just didn't know how to do
otherwise, the only newsread i have is groupwise.
I don't know what ImageShack is but i will have a look at it.
I also suspectecd that it was tomcat doing this.
A great thank you for your help
Andrej
>>> Benjamin Muskalla<bmuskalla@eclipsesource.com> schrieb am 29.01.2009 um
12:50 in Nachricht <gls561$c03$1@build.eclipse.org>:
> Hi Andrej,
> RAP itself.
> Cheers
> Benny
> Andrej Dimic wrote:
>> Hi Benny
> i
>> try {
>> } else {
>> Thanks
>> Andrej
um
>>> Hi Andrej,
>>> Cheers
>>> Benny
>>> adiinfo wrote:
>>>> Hi Benny
>>>> at all).
>>>> the imagedata.
data.
>>>> time to time?
>>>> Thanks
>>>> Andrej
Current Time: Sat Oct 19 21:57:41 GMT 2024
Powered by FUDForum. Page generated in 0.06245 seconds
