Ctrl-Shift-R shows files in .deployables [message #117887] |
Fri, 08 July 2005 09:41 |
Originally posted by: didier.alves.gmail.com
When I try to open any file that is deployable using Ctrl-Shift-R, I
always get twice the same file because that the "Open Resource" window
also shows files that are deployed in the hidden .deployables folder. This
behaviour is very annoying because you may be mislead to open the wrong
file.
Is there a way to hide the files in the .deployables folder so that they
dont appear in the "Open Resources" window?
Thanks.
Re: Ctrl-Shift-R shows files in .deployables [message #117938 is a reply to message #117887] |
Fri, 08 July 2005 11:39 |
Sure. Select .deloyables in Navigation, open Properties, check "Derived"
box in the Info pane. Repeat for each project in your workspace.
Then Ctrl-Shift-R, make sure "Show derived resources" box is unchecked.
Stuff under .deployables should be invisible.
Enjoy
Rafal
Re: Ctrl-Shift-R shows files in .deployables [message #118066 is a reply to message #117887] |
Fri, 08 July 2005 14:30 |
Originally posted by: cooll.free.fr
Didier Alves wrote:
> Hello,
I have other problems with .deployables:
- CVS directories seems to be deployed
- .deployables appears in synchronisation view
Re: Ctrl-Shift-R shows files in .deployables [message #119155 is a reply to message #118066] |
Mon, 11 July 2005 07:45 |
apparently a bug in WTP, these directories are somehow marked as Team
specific, because they don't show up in Navigator view etc. I would
suggest reporting it to Bugzilla.
this should be easy to solve using "Add to .cvsignore..."
Re: Ctrl-Shift-R shows files in .deployables [message #119209 is a reply to message #119155] |
Mon, 11 July 2005 08:09 |
Strangely, I can't find them anymore in .deployables (full rebuild cleaned
up ?)
I hadn't try to add each file to cvsignore (option not available on
directories) until today.
At first file, I got a message "operation not available" and all the
..deployables resources desappeared form the synchronization tree :)
Re: Ctrl-Shift-R shows files in .deployables [message #119221 is a reply to message #119209] |
Mon, 11 July 2005 08:31 |
Another one:
I get errors on JSP's of the .deployables directory that I do not have on
same resource in the webContent dir.
(variable cannot be resolved when accessing a variable defined by a
bean:define)
Re: Ctrl-Shift-R shows files in .deployables [message #119480 is a reply to message #117938] |
Mon, 11 July 2005 19:16 |
Originally posted by: joe.herbers.ugs.com
Related question: I'm new to WTP and trying to debug JSPs. Unexpectedly,
the first time I hit a breakpoint in a regular Java file, it doesn't know
where to find the source, even though this project contains the source file
and it had been built successfully. I clicked the button that appears in
the pane where the source file should be, and did an Add and selected the
source dir in my project. Now I can step through Java classes just fine.
However, when I hit a breakpoint in a .jsp, it brings up the copy of the
..jsp from the .deployables dir instead of the original source file - why?
(and as someone else noted, this version of the jsp has more errors). I had
a similar problem when I tried debugging a JSP in one of the tutorials, but
I had gotten around it by somehow choosing the source path differently (but
I can't recall now exactly how).
Any good instructions on debugging JSPs in WTP?
Re: Ctrl-Shift-R shows files in .deployables [message #119493 is a reply to message #119480] |
Mon, 11 July 2005 20:12 |
Replying to my own post: it seems that when choosing source to add during
debug, if I choose Folders and then "WebContent" folder and add this, then
JSPs come up fine in the debugger. However, it's when I chose "Projects"
that it was pulling up the copy of my JSP in .deployables which caused
issues.
How do I get back to the source chooser for this anyway?
"Joe Herbers" <joe.herbers@ugs.com> wrote in message
news:daugi0$tbt$1@news.eclipse.org...
> file and it had been built successfully. I clicked the button that
> appears in the pane where the source file should be, and did an Add and
> selected the source dir in my project. Now I can step through Java
> classes just fine.
> had a similar problem when I tried debugging a JSP in one of the
> tutorials, but I had gotten around it by somehow choosing the source path
> differently (but I can't recall now exactly how).
Re: Ctrl-Shift-R shows files in .deployables [message #119579 is a reply to message #119480] |
Mon, 11 July 2005 22:43 |
Is this with M4 or M5? Bug 93174 added a fix for this when you have
multiple modules in the same project, but I suspect that's not your
setup?
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: JSP Debugger points to ".deployables" version of the .jsp file (was Ctrl-Shift-R shows [message #119851 is a reply to message #119579] |
Tue, 12 July 2005 12:37 |
Nitin, this bug sounds just like the problem I'm seeing. I'm running with
M5, so this should have been fixed, right? BTW how can I get back to the
source mapping so I can play with this?
Thanks for your help. I've used Eclipse but am new to WTP, and should learn
to search the bug lists. And is there a way to search archives of this
group? Here's what I downloaded last week when I started this: Eclipse 3.1,
WTP 1.0M5 (I20050627-1435), GEF 3.1RC4, EMF/JEM 0623, JDK 1.4.2_08, tried
Tomcat 5.0.28 and 5.5.
> multiple modules in the same project, but I suspect that's not your setup?
FUDForum. Page generated in 0.04426 seconds
