XML schema saving is slow [message #119641] |
Tue, 12 July 2005 07:18 |
Originally posted by: mslocins.gmail.com
I have problems with newest M5 WTP version on linux machine (all
dependencies are downloaded and installed correctly, I don't use any other
plugins concurrently with WTP). When I try to modify and save XML schema,
sometimes it takes even few minutes, no matter how big schema is. Eclipse
just hangs in that moment.
I checked logs in my workspace but I don't see anything suspicious. Do you
know any possibilities to see what is exactly done in background? I'm
looking for something like decreasing log level ...
cheers
Michal
Re: XML schema saving is slow [message #119720 is a reply to message #119669] |
Tue, 12 July 2005 07:54 |
Yes, I have caching enabled, hovewer I'm working in wired environment
where Eclipse doesn't have direct internet access so it cannot download
anything from internet. Anyway - I don't include any other schemas which
are located in the network. I use only those ones defined by default in
XML catalog which are placed in jar files or other eclipse resources.
I used also tcpdump to check if eclipse is trying to connect somewhere
while saving schema, but no packets were sent.
Michal
Re: XML schema saving is slow [message #119799 is a reply to message #119786] |
Tue, 12 July 2005 09:55 |
as I said I don't use any type of internet connection (and as I see,
Eclipse doesn't trying to send any packets into the network). I use
jdk1.5_04, I think most useful information for me would be how to enable
some more debugging and tracing in Eclipse.
Michal
FUDForum. Page generated in 0.03920 seconds
