Home » Archived » Visual Editor (VE) » Override property problem
Override property problem [message #119489] Wed, 01 March 2006 09:38 Go to next message
I have class which has String attributes
For example
public class Person{
String name;
public String getName(){
return name;
public String setName(String name){
this.name=name;
Let's say that this class is visualised in the VE editor and the
attribute "name" is displayed and can be edited in the Properties view.
I do not know how to associate my own cell editor (for the Properties
view) with the attribute name.
I have tried to use the approach from the "Extending The Visual Editor:
Enabling support for a custom widget tutorial" I made something like this:
I created the Person.override file and made all things to make it work.
<xmi:XMI xmi:version="2.0"
xmlns:org.eclipse.ve.internal.cde.decorators="http:///org/eclipse/ve/internal/cde/decorators.ecore"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:event="event.xmi">
<event:Add featureName="eStructuralFeatures">
<addedEObjects xsi:type="ecore:EReference" name="name"
unsettable="true">
<eAnnotations
xsi:type=" org.eclipse.ve.internal.cde.decorators:BasePropertyDecorator "
cellEditorClassname="me.testpackage/me.myTestPackage.MyPersonCellEditor "/>
</addedEObjects>
</event:Add>
</xmi:XMI>
The problem is that the "name" attribute of the Person class is still
edited by the default editor for the Strings:-(. (The override is
applied to the person class).
Re: Override property problem [message #119533 is a reply to message #119489] Wed, 01 March 2006 10:44 Go to previous messageGo to next message
That should of worked. Were there any errors logged in the .log file? Do
a clear cache and try again, we may of cached the old override file and
so didn't know it had changed.
To clear the cache:
1) Open a VE then close it and all VE's.
2) Do a Project->Clean...->Clean All Projects
3) Wait for build to finish
4) Open your VE.
Another possibility is that your override file is not being picked up.
First are you sure your container is in your classpath? That is how we
determine which overrides to process.
Rich Kulp
Re: Override property problem [message #119897 is a reply to message #119533] Mon, 06 March 2006 04:38 Go to previous message
I have found the problem, indeed the errors were logged, there was an
syntax error in my .override. I must admit that I hate editing those
files:-).
Thanks for help
> To clear the cache:
> 4) Open your VE.
Re: Override property problem [message #612229 is a reply to message #119489] Wed, 01 March 2006 10:44 Go to previous message
To clear the cache:
4) Open your VE.
Rich Kulp
Re: Override property problem [message #612258 is a reply to message #119533] Mon, 06 March 2006 04:38 Go to previous message
files:-).
Thanks for help
> To clear the cache:
> 4) Open your VE.
Previous Topic:Visual Edior 1.2M2 not working @ me
Next Topic:Tabbed properties
Current Time: Mon Mar 31 20:12:58 EDT 2025
Powered by FUDForum. Page generated in 0.03437 seconds
