Layout exception when opening editor [message #119409] |
Fri, 23 January 2009 16:55 |
Hi all,
I have the following simple editor:
public class MyEditor extends EditorPart
public void doSave(IProgressMonitor monitor){}
public void doSaveAs(){}
public boolean isDirty(){return false;}
public boolean isSaveAsAllowed(){return false;}
public void init(IEditorSite site, IEditorInput input) throws
PartInitException
setSite(site);
setInput(input);
public void createPartControl(final Composite parent)
Composite container = new Composite(parent,SWT.NONE);
container.setLayoutData(GridDataFactory.fillDefaults().grab( true,true).create());
public void setFocus(){}
When I open the editor the following exception is thrown:
Jan 23, 2009 11:44:07 PM org.eclipse.rwt.internal.lifecycle.RWTLifeCycle
afterPhaseExecution
SEVERE: Could not execute PhaseListener after phase 'PROCESS_ACTION'.
java.lang.ClassCastException: org.eclipse.swt.layout.GridData cannot be
cast to org.eclipse.swt.layout.FillData
at org.eclipse.swt.layout.FillLayout.flushCache(FillLayout.java :180)
at org.eclipse.swt.widgets.Composite.changed(Composite.java:493 )
at
org.eclipse.swt.internal.graphics.TextSizeDeterminationHandl er$1.doVisit(TextSizeDeterminationHandler.java:79)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor$AllWidget TreeVisitor.visit(WidgetTreeVisitor.java:32)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:46)
at
org.eclipse.swt.internal.widgets.WidgetTreeVisitor.accept(Wi dgetTreeVisitor.java:51)
at
at
at
at
at
org.eclipse.swt.internal.graphics.TextSizeDeterminationHandl er.afterPhase(TextSizeDeterminationHandler.java:126)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.afterPhaseEx ecution(RWTLifeCycle.java:390)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.continueLife Cycle(RWTLifeCycle.java:191)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.sleep(RWTLif eCycle.java:297)
at org.eclipse.swt.widgets.Display.sleep(Display.java:706)
at
org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(Wo rkbenchAdvisor.java:361)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2347)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at
com.farbeyond.input.ui.application.DemoEntryPoint.createUI(D emoEntryPoint.java:12)
at
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:619)
What's wrong ?
Setya
Re: Layout exception when opening editor [message #119461 is a reply to message #119448] |
Fri, 23 January 2009 18:15 |
Originally posted by: benjamin.wolff.web.de
the exception is only thrown once because the layout is only created once, when starting the editor for the first time.
regarding the layouting, setting a LayoutData on a composite is also connected to the Layout of its parent composite! the LayoutDate defines how the composite, 'container' in this case, behaves inside
the parent composite. FillLayout is the default Layout when nothing else is set, therefore the parent comp, which is contributed by the method call, has a FillLayout and can't use the GridData of the
container comp. adding the Line
parent.setLayout(GridLayoutFactory.swtDefaults().create());
should avoid the exception if i'm not mistaken.
greetings,
ben
Setya schrieb:
> Besides, the exception only thrown when I open the editor for the 1st time.
> Setya
Re: Layout exception when opening editor [message #119474 is a reply to message #119461] |
Fri, 23 January 2009 18:30 |
i have to correct my last posting, since it is not a good idea to modify the Layout of the parent comp it would be best if you don't set a LayoutData on the container comp. Simply add a GridLayout to
the container comp and use the container to layout the children (buttons etc.) using Grid Layouting. that's how do it.
greetings,
ben
Ben W. schrieb:
> how the composite, 'container' in this case, behaves inside the parent
> a FillLayout and can't use the GridData of the container comp. adding
> the Line
> greetings,
> ben
> Setya schrieb:
>> Hi,
>> time.
>> Setya
Re: Layout exception when opening editor [message #119546 is a reply to message #119474] |
Sun, 25 January 2009 06:48 |
Thanks for your advice. Actually removing the GridLayoutData assignment
makes no difference.
But, I've put the same editor part in my RCP app to test, no exception was
thrown, should I expected incompatibility here ?
Setya
FUDForum. Page generated in 0.05432 seconds
