Home » Archived » BIRT » 2.0 M3 to 2.0.0 issues
2.0 M3 to 2.0.0 issues [message #119038] Fri, 27 January 2006 18:07 Go to next message
No real name is currently offline No real nameFriend
I just migrated my RCP installation and my Report Engine deployment from
2.0 M3 to 2.0.0 and have encountered the following two issues:
1)BIRT_VIEWER_REPORT_ROOT is no longer using the value I supply.
In M3 I have this set to c:/appServer/myWebAppRoot/reports
When I try this in 2.0.0 it will only find reports that sit
in myWebAppRoot. I have also tried a relative path to /reports
but I get the same behavior.
2)Charts are not displaying. I have opened these charts in the 2.0.0
RCP and have been able to preview fine there, but when I invoke using
the ViewerServlet I just get a blank page. No errors are generated and
the page contains nothing at all, viewing source displays nothing as
well. My tabular reports are displaying correctly.
Anyone with similar issues or ideas?
thanks in advance.
Brian
Re: 2.0 M3 to 2.0.0 issues [message #119090 is a reply to message #119038] Fri, 27 January 2006 19:22 Go to previous messageGo to next message
Jun Zhai is currently offline Jun ZhaiFriend
Member
For 1) set same value to "BIRT_VIEWER_WORKING_FOLDER".
Re: 2.0 M3 to 2.0.0 issues [message #119118 is a reply to message #119090] Fri, 27 January 2006 20:07 Go to previous messageGo to next message
Excellent, thank you!
Not sure how I missed this change, is it documented somewhere? I have
been using the web.xml that is included in the Web Viewer
Example/WEB-INF directory for the parameter definitions, which obviously
needs updating as it still refers to BIRT_VIEWER_REPORT_ROOT
Re: 2.0 M3 to 2.0.0 issues [message #119131 is a reply to message #119118] Fri, 27 January 2006 20:22 Go to previous messageGo to next message
Originally posted by: zhai.actuate.com
This is a bug. We need to make sure the packaged web.xml has right
parameter name too.
Re: 2.0 M3 to 2.0.0 issues [message #119287 is a reply to message #119038] Fri, 27 January 2006 23:03 Go to previous messageGo to next message
Wenfeng Li is currently offline Wenfeng LiFriend
For the chart issue, what browser and OS you are using? Does it support SVG,
if not, you can disable SVG in the chart wizard.
Wenfeng
"Brian Kallay" <brian.kallay@bricsnet.com> wrote in message
news:drdnhq$nrs$1@utils.eclipse.org...
> thanks in advance.
> Brian
Re: 2.0 M3 to 2.0.0 issues [message #120060 is a reply to message #119287] Mon, 30 January 2006 16:45 Go to previous messageGo to next message
Thanks for the reply Wenfeng, I am using firefox 1.5. I did test by
changing the output format from svg to gif, jpeg and png but I get the
exact same behavior with each setting. It is also my understanding that
if a report set to svg is requested from a non-svg supported browser
the engine is smart enough to display using a different format, but I
may be wrong on that.
Brian
> Wenfeng
>>thanks in advance.
>>Brian
Re: 2.0 M3 to 2.0.0 issues [message #121819 is a reply to message #119038] Tue, 31 January 2006 17:36 Go to previous message
Thanks for the responses,
In regards to #2 (Charts not displaying) it appears to be some cruft
from 2.0 M3 left in the plugins dir causing the issue. I did a
completely clean install and was able to resolve the issue.
thanks again,
Brian
> thanks in advance.
> Brian
Previous Topic:Trying to get the pooled db connection working
Next Topic:Cross table support in BIRT 2.0
Current Time: Sat Nov 09 03:37:52 GMT 2024
Powered by FUDForum. Page generated in 0.03759 seconds
