Re: RAP integration into WebSphere Portal [message #119608 is a reply to message #118466] |
Mon, 26 January 2009 09:25 |
Marian Seitner Messages: 5 Registered: July 2009 |
Hi Stefan,
> I'm not sure if re-rendering the widget makes sense to perform something
> like a refresh. In fact, you want to refresh the model of your widgets
> (e.g. perform a DB query or whatever), don't you? However, this can
> hardly be done genericly.
Maybe I didn't clearly point out what I'd like to achieve. Consider a very
simple RAP application with just a view with a checkbox inside. Clicking
on that checkbox causes a roundtrip to inform the server that the checkbox
has been checked or unchecked, so the server-side "knows" about the
widget's state. Now if you refresh the current page it should be possible
to render that checkbox again with it's current state, because the
relevant information should be available in the session. The same should
work if a portal page gets rendered again.
> In general, you also might run into trouble if you have more than one
> portlet, each containing a separate RAP application. The framework can't
> handle this at the moment.
This is another issue ;-)
Kind regards,
Marian
Re: RAP integration into WebSphere Portal [message #119659 is a reply to message #119608] |
Mon, 26 January 2009 13:57 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Marian,
please see my comments below.
Rüdiger
Marian Seitner wrote:
> Hi Stefan,
>> something like a refresh. In fact, you want to refresh the model of
>> your widgets (e.g. perform a DB query or whatever), don't you?
>> However, this can hardly be done genericly.
> very simple RAP application with just a view with a checkbox inside.
> Clicking on that checkbox causes a roundtrip to inform the server that
> the checkbox has been checked or unchecked, so the server-side "knows"
> about the widget's state. Now if you refresh the current page it should
> be possible to render that checkbox again with it's current state,
> because the relevant information should be available in the session.
You are right, the relevant information is available and it would be
possible to enhance RAP so that it would update the client with the
current server-side state.
> The same should work if a portal page gets rendered again.
I don't know much about portlets but I currently see two obstacles:
* qooxdoo, the client-side Javascript library used by RAP, in its
current version assumes to be alone on the client document
* refreshing is significantly slower then usual request and if it
occurs frequently will probably make for a bad user experience
>> can't handle this at the moment.
> Kind regards,
> Marian
FUDForum. Page generated in 0.03204 seconds
