Home » Eclipse Projects » GEF » Re: save resize figure
Re: save resize figure [message #118440] Thu, 19 February 2004 09:50 Go to next message
Originally posted by: yong.dong.sympatico.ca
Me too, since the new attribute size is not saved to the xml file. According
to the same reason,
other new shapes can not be saved in xml either. Now I try to serialize the
model object
to the disk and save it to the DB, then XML.
Michael
Hi Micheal,
I am still fighting with resizing. I am able to resize
and I can see the
resized image on the screen. When I close the editor,
it does not get saved
and shows up with the default size. Did you modify
NetworkPackageImpl.java's
CreatePackageContents() or InitializePackageContents()
methods? I included
the getNetworkNode().setSize() method in
NetworkNodeEditPart.java but it
does not help. It has to do with some minor change in
the model
(NodeImpl.java or NetworkImpl.java) that I am missing.
Let me know & Thanks in advance!
Bharath
Re: save resize figure [message #118450 is a reply to message #118440] Thu, 19 February 2004 10:47 Go to previous messageGo to next message
Originally posted by: bharath.starthis.com
Michael,
The "size" attribute is modeled as an EClass ONLY because it makes it
serializable! I must be missing out an extra method or so required to
enable its serialization and I am trying to find it. I will let you know
as soon as I get it working.
Thanks.
> to the same reason,
> model object
> Michael
> Hi Micheal,
> and I can see the
> methods? I included
> the model
> Bharath
Re: save resize figure [message #214404 is a reply to message #118450] Mon, 17 April 2006 12:00 Go to previous message
Originally posted by: micha.m2visio.de
Hello Guys
have you found a solution for this problem?
I'm working at the same issue at the moment and just can't get it.
Michael
"Bharath" <bharath@starthis.com> schrieb im Newsbeitrag
news:c12lqg$4f8$1@eclipse.org...
> Michael,
> Thanks.
>> According
>> to the same reason,
>> the
>> model object
>> Michael
>> Hi Micheal,
>> and I can see the
>> methods? I included
>> the model
>> Bharath
Previous Topic:Removing children reference
Next Topic:Dispose of an image within a Draw2D Label
Current Time: Thu Oct 23 13:41:45 EDT 2025
Powered by FUDForum. Page generated in 0.05785 seconds
