Home » Eclipse Projects » EclipseLink » Updating Child Table when updating parent entity(How to manage relationship in Eclipselink(jpa2)?)
Updating Child Table when updating parent entity [message #1182397] Tue, 12 November 2013 06:47 Go to next message
udhyan mahaju is currently offline udhyan mahajuFriend
public class Legendtype implements Serializable {
    private static final long serialVersionUID = 1L;
    @Id
    @Basic(optional = false)
    @NotNull
    @Size(min = 1, max = 100)
    @Column(nullable = false, length = 100)
    private String legendname;
    @Size(max = 500)
    @Column(name = "LEGEND_DESC", length = 500)
    private String legendDesc;
    @NotNull
    @Size(min = 1, max = 50)
    @Column(nullable = false, length = 50)
    private String legendfor;
    @OneToMany(cascade = CascadeType.PERSIST, mappedBy = "legendnameFk", fetch = FetchType.LAZY)
    private List<Legend> legendList;
public class Legend implements Serializable {
    @Id
    @GeneratedValue(strategy = GenerationType.IDENTITY)
    private Integer sn;
    @Column(name = "LEGEND_SN")
    private Integer legendSn;
    @NotNull
    @Column(nullable = false)
    private double lowerrange;
    @NotNull
    private double upperrange;
    @Size(max = 500)
    @Size(max = 45)
    @Column(length = 45)
    private String color;
    @JoinColumn(name = "LEGENDNAME_FK", referencedColumnName = "LEGENDNAME", nullable = false)
    @ManyToOne(optional = false, fetch = FetchType.LAZY)
    private Legendtype legendnameFk;
when I call
public void mergeLegendType(Legendtype lt) {
em.merge(lt);
It only updates legendtype but not legend. How to cascade update and delete? I have cascade.all defined.
Re: Updating Child Table when updating parent entity [message #1182981 is a reply to message #1182397] Tue, 12 November 2013 15:02 Go to previous message
Chris Delahunt is currently offline Chris DelahuntFriend
The em.merge(lt) call will cascade to any legend referenced within the legendList. Can you give an example of an update that is not being picked up by the merge? What is in the legendList list when you are calling merge?
Previous Topic:JavaDbGenerator error on Luna Release
Next Topic:add list of entities
Current Time: Wed Feb 05 04:42:53 GMT 2025
Powered by FUDForum. Page generated in 0.02779 seconds
